Question about Brother XL-3500
When I turn on my Brother xl3500i sewing machine, the light comes on but, when I press the presser foot nothing happens
    Genius:
  • 1,788 Answers
Do you have a stitch picked? Did you read your manual? I think that you should look at the brother-usa.com site if you do not have the manual. Unless you read the instructions you will get nowhere fast
Posted on Sep 08, 2010
My MACHINE TURNS ON BUT PRESSER FOOT DOES NOT GO UP WHEN I STEP ON PEDDLE IT DOES NOTHING. ARE THERE FUSES IF SO, WHERE CAN I FIND THEM? THANK YOU!
Um, confused... The foot control generally will not raise the presser foot. It should advance the feed dogs.
Aug 29, 2017 | Brother Sewing Machines
E 1 error message
Make sure you lower the presser foot before continuing the operation.
The foot controller was pressed (or the start/stop button
was pressed if the foot controller is not connected)
and the reverse/reinforcement stitch button
was pressed while the presser foot was raised.
Mar 01, 2014 | Brother CS6000i Computerized Sewing...
Can't raise the pressure foot on my Brother Project Runway Sewing machine. I raise the plastic lever but it does nothing
Open machine face cover you would be able to see what happen to your presser bar. If you can raise the lever but the presser bar not response Or if you can push up the presser bar easily with your hand, the presser bar tension screw is loose. Upper part of the bar would have the tension/presser spring, press up the presser bar till you can feel enough tension to press the material then tighten the tension screw which is located behind the bar.(Most machine you can access the screw thru a small entry at the back of machine, right behind the bar itself. You may have to repeat this until the bar have enough presser to press the material. Hope this is helpful.
Jan 17, 2014 | Singer Sewing Machines
Presser foot stopped working I turned
Did you connect your machine then press the foot control before you lowered you presser foot? I have a CS6000 and that is what E1 means on my machine. You did not put your model number in so I don't know. You can look in your manual or go online to www.brother-usa.com and look it up for your machine. Try unplugging and plugging it in again, but put your presser foot down then step on your foot pedal.
Oct 04, 2010 | Brother Sewing Machines
My brother CE 4000 sewing machine freezes. After some tinkering I can sew a little then in happens again. It makes a shuddering noise then freezes and shows an E6 error message?
Turn off the power and remove the needle and presser foot.
Remove the needle plate, bobbin and bobbin case.
Clean the shuttle and surrounding area.
Replace everything.
Make sure the flat side of the needle faces to the back of the machine.
Raise the presser foot and re-thread the machine.
Mar 06, 2010 | Brother Sewing Machines
The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
Apr 04, 2009 | Brother XL-5130 Mechanical Sewing Machine
Brother XL-3500 Logo
88 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
