My PC show please run thhe chkdskutility I do not know what it is
Right click my computer, clk explore,right click your C drive, go down to properties left clk it, the window that opens will have a tab marked Hardware, clk it, clk error checking, this is check disk utility
Posted on Sep 07, 2010
How can I update thhe software
Please explain what software you mean.
Jul 28, 2015 | Computers & Internet
Why does my computer show that pc needs to be repaired and if you know can you please tell me?
PC and Laptops will only say that if you have inadvertantly downloaded some malware. Run a decent anti spam/malware program to get rid of it.
Apr 25, 2014 | HP Pavilion Computers & Internet
Acer aspire 4730z touch pad does not work
many of the computer components need updated drivers to run windows 7. a look at your computers specs shows it came with vista( http://support.acer.com/acerpanam/notebook/0000/Acer/Aspire4730Z/Aspire4730Zsp2.shtml) here is acers drivers page for your computer ( http://support.acer.com/product/default.aspx?modelId=27 ) update all drivers to thhe latest versions. be awre though that not all manufacturers updated all of their older units to accept win 7 so yours may not. good luck
Nov 18, 2011 | Computers & Internet
Battery drains when engine is running put new battery,alternater, negtive ground wire.please help
Check the cable from alternator to battery,and make sure there is no breaks, The charging system relies on the alternator voltage regulator,which is controlled by thhe PCMcansmo_203.gifcansmo_204.gifOn a very rare occasion its the PCM check the fuses
Sep 12, 2011 | 1998 Cadillac DeVille
Had front-end collision damage fixed and drove the 1997 grand caravan home; turned it off; and later it wouldn't start. Turns over ok, but not getting gas. I think it is the fuel pump relaty. There...
There is a relay for the fuel pump its controled by thhe ASD relay sure you plug a new relay or even swap it out with other relay in the distribution area but you need to make sure why you are not getting fuel check thhe fuel pump fuse is it open if it is replace it and does it blow easy now turn the key and cycle the switch you should hear the fuel pump humming if it doesnt go ahead find the relay take thhe relay cover out and expose the switch are and put it back in its socket key on or off if you collapse the realy to close thhe switch you should hear the fuel pump running if it doesnt you either have a failed fuel pump a bad connection or something not allowing the ASD to engage
Aug 21, 2011 | 2000 Dodge Caravan
Ford aerostar '96 3.0 L check engine on all the time, code P1443 and P0171
P01443 means evap control system control valve, P0171 fuel trim is lean bank 1. Here is te fix and yes you can do this yourself go to thhe right hand side of thhe vehicle and use your ears with the vehicle running you should hear a loose or disconnected vacuum hose if its not at the right side turn off the vehicle and go to the front right or left but thhe front area there you will see a square black canister look at the hose and repair the broken vacuum hose I am very sure you can hear it hissing when the vehicle is running the fix is easy listen and look also your under hood sticker will point out the evap area
Aug 18, 2011 | Ford Aerostar Cars & Trucks
Cannot download pictures from my camera.
Let me know does your PC recognize camera via USB port ?
Do you see any error when you connect camera with PC?
Is there any file corrupted message comes when you transfer files / pictures to PC?
Dec 12, 2008 | Panasonic Lumix DMC-LZ2 Digital Camera
No power
All lights come on HP Pavilion dv1000 but will not boot. looked at motherboard and by power connector there is a blown part the number on the board shows PD27. I need to know what thhe part is or a schematic showing
Jun 23, 2008 | HP Pavilion dv1000 Notebook
I have a sansui tv set and I need thhe tv code to program my remote control
Hi there shelly
I will need to know the make and model of your remote control to get you the code. Can you post that here for me please.. :)
robotek
May 06, 2008 | Televison & Video
Computers & Internet Logo
David Payne
David Payne
