Question about Ovens
GE Spectra XL44 - Model JGBP 35WEA - Gas Oven/Stove. Oven won't turn on. Top stove burners work. Oven turns on to clean, but can't get regular oven to start up.
  • Ovens Master
  • 2,605 Answers
Welcome to FixYa.
Based on your description, I`d suggest the hot surface ignitor for the bake burner is likely the problem.
Here's what you can try to verify if it's indeed the ignitor...if you're mechanically inclined.
**Turn off the breaker or unplug the range and turn off the gas to the appliance before attempting any service...safety first**
Since your boiler has the same ignitor ( some do some don't ) one could swap the ignitor`s ( very carefully, they are very fragile and don`t like to be handled ) this will allow you to use the bake burner, but it will leave you without the broil function...until you can purchase another.
This will confirm or dismiss if the ignitor is at fault...99% of the time this is the case.
You should be able to find one at most brick & mortar appliance parts vendors or on-line depot's such as "repairclinic.com", "searspartsdirect.com" to name a couple.
You can ask for part number WB13K21, That is the bake & broil ignitor and is for your GE, but built by "Norton" for gas oven`s.
I would still double check with your model number with the part`s professional`s.
Hope that help`s. Let me know if I can assist you further and good luck.
Thank`s for visiting "fixya" for your repair needs.
Regards,
Macmarkus :)
Posted on Sep 07, 2010
I have a GE True Temp XL44 oven the stove burners work fine but the oven will not light. When I turn it on the oven, I do not smell any gas. What is the problem and how do I fix it?
could be a problem with the ignitor. take the racks out of the oven. remove bottom panel in oven. remove metal plate covering the flame spreader. the ignitor should now be visible. turn the oven on. the ignitor should begin to glow. if it doesn't glow bright white, or bright glow, ignitor is bad and needs to be changed.
Feb 13, 2011 | GE Ovens
GE Spectra XL44 Oven Overheating
It is a thermistore problem, if you replace the faulty thermic switch inside oven, it should work fine a gain
May 25, 2008 | Ovens
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
Jan 25, 2011 | GE Ovens
Bottom burner in my oven barely comes on, in turn, not heating my oven to the temperature that is selected. Top burner (or broiler seems to work fine). The gas stove is a GE XL44 and is 6 years old. Please...
You need a new t-stat control. Your element is fine. Give us a call with your complete model number and we'll get the right part out to you asap to get you ready for the winter.
Oct 18, 2009 | Ovens
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
How do you light the pilot on a GE stove The top of the stove works
Hi, If this model has a standing pilot, use a lighter and put the flame to the back center next to the burner assembly. Most newer models have electric ignitors now. It is fastened to the burner assmbly on the laft side.
If this an electric ignitor, turn the oven on and see if the ignitor glows. These ignitors are a very common problem and will probavly need replaced.
Please let me know if I can assist youu further.
Vic
Jul 03, 2009 | GE JGRP17 Gas Single Oven
Ge xl44 oven not igniting but burners ignite
The most common failure for a nobake on this type of oven is the bake ignitor. turn unit on and look at the bottom of the oven, you should after about 30-45 seconds see an ORANGE glow, if you do not, chances are you have a failed ignitor.Remove lower part of oven and if you have a meter, place one lead on each terminal and check for continuity( a closed circuit)
If you have an "open" circuit, the ignitor is bad
Feb 26, 2009 | GE JGRP17 Gas Single Oven
Bake ignitor Location
ok jimmy not as bad as you think you access it through the oven cavity remove all the racks look for two screws on the bottom panel i believe they are at the front remove them then remove the bottom panel next you will see a lame spreader which is an angled plate remove it then you will see the burner bar at the back is the ignighter just match it with the new one
Feb 11, 2009 | GE Ovens
Oven burner flame is low
0000000.jpgOn top of that safety valve is a nut. Get a good fitting wrench. Turn on the oven and use that good fitting wrench on that nut. Turn it counterclockwise till the flame comes up about midways of the flame spreader. Don't get the flames too high. Midways of the spreader now. LOL
Jan 02, 2009 | Ovens
GE Oven does not ignite, bute Broiler does.
Your problem is with the oven igniter. You have the stove MODEL# so you should have no problem finding the part you need.Shop around to get your best price. Good Luck Friend.
Oct 14, 2017 | GE JGRP20 Gas Single Oven
Ovens Logo
121 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
