Question about Electrolux Lux 5500 Canister Vacuum
How do you repair the hose if it is flattened in the mid way ?
  • 694 Answers
Due largely to the electrical wiring, vacuum hoses are very difficulty to repair. If the hose is flattened/damaged, the wiring may have been damaged and construes a shock hazard at the least. Trying to repair the hose increases the possibility of wiring damage.
However, you can try getting a lenth of PVC or similar pipe that is a slightly smaller diameter than the hose. Insert one end into the canister end of hose and gently push it to the flattened area. Slowly and gently use it to work the flattened area out.
I don't know if this will work, but it's worth a try. If it doesn't, a new hose is needed.
Posted on Sep 21, 2010
My shop-vac stopped mid-job with no warning
Maybe it over heated or the hose was jammed. Unplug it for a few minutes, check the hose for any stuck debris, then plug it back in. Shop vacs also come with a filter. If the filter is too dirty, it might have shut off as a safety precaution to not cause a fire. Follow directions to clean the filter. Hope this helped. Dee
Oct 13, 2014 | Craftsman Shop Vac 8 Gallon Replacement...
Dyson DC14 hose flattens while extened
The hose may have been stepped on or crushed while extended. Replacement of the hose may be necessary
Jun 28, 2013 | Dyson DC14 Animal Bagless Upright Cyclonic...
The flexible tube sucks the air out and flattens the tube
I'm sorry to hear you're having difficulties with your DC24. From your description of the issue, it sounds as if you may have a blockage somewhere in the hose or wand. The easiest way to check for this is to follow the steps shown in our online troubleshooting guide:
http://www.dyson.co.uk/support/help.asp?article=1492&product=DC24-ALLFLOORS
This should enable you to resolve the issue without further assistance. However, if you've tried this and are still concerned, it's probably best if you get in touch with us directly. You can call us free on 08002980298 (UK), or 1866MYDYSON (US) - one of our experts will be happy to provide the help you need.
Kind regards,
Jack
Dyson Online Customer Support
Sep 23, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I was using it with out wand attached to it and the tube started to go flat and tight. The sound changed too, like the canister was full, but it wasn't. What should I try?
Sounds like it took in something that clogged the hose. The obstructon will be located at the point where the hose begins contracting (flattening).
Jun 24, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
My FIL purchased an Electrolux bagless canister vacuum model EL5 76501 last year. When I tried to use it today, the hose keeps pulling out of the power brush whenever I pull it towards me. it doesn't seem...
I believe I've just had the same problem and after searching for a small gray horsehoe clip that needs to first be found and then inserted into the slot for it on the tube section that comes out of the beater bar. Insert this clip from the outside after placing the hose attachment over the tube. Once figured out it is an easy fix.
Oct 26, 2010 | Electrolux Vacuums
My 5200 hoover spin scrub all of a sudden stopped sucking in mid clean.i took the front clear cowling off and checked for blockage but couldnt see anything.there is nothing to these thiings,they are...
Most likely your vent for the suction container is plugged or the suction hose can of or is broken at the connection to the tank nozzle (very common on these. Clean the machine thoroughly, and check that all hoses are tight and connected.
Aug 01, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Bag was full, changed it, the unit now turns off
Try dialing the control valve to the mid way position. If the unit still shuts down with the bag full light on you have a damaged control valve under the dial on the top of the vac.
This valve failure is common in this model and can only be repaired by someone with original AERUS Electrolux repair parts, generally at an AERUS repair shop.
Oct 29, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Dyson DC17 Found the clog-how do I unclog it?
poke it out with a screwdriver this will dislodge the hair it might take a while to get it all out
Sep 27, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
The vacuum cord hose is able to **** up the dirt but the actual vacuum where the belt is does not work
sounds like you have a plug in your "duct hose" Remove the hose from the lower hose it hooks in and take a look inside. If you release the handle release lever and flatten the machine, hold it up and you should see light through it to the roller. If you don't, then you have a blockage. clear the blockage, and you will back in vacuum business! Let me know if this helps!
Aug 06, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore Cannister Vacuum Model 26312
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=109396&thid=552260
Kenmore Canister Vacuum Model 26312
Posted by Alecia Rojas on Apr 28, 2008
Kenmore 23612 Progressive PowerMate Canister Vacuum
Vacuum is not sucking. It is just over a year old.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
It sounds like you have a clogged hose or a full bag, or dirty filter. The best way to check your electric hose id to run a marble or steel ball thru the hose and if it goes thru all the way then check the bag and filter, most times it is the vacuum hose. If it id the hose you can try to pull apart the clog from both ends using another central or canister vacuum. If not and the ball stops mid way thru the hose then you can use a broom handle with a round hook on the end so that it does not puncture the hose is any place and the round hook can loosen or break up your clog and then your suction will return, if you poke a hole in the vacuum hose there are repair kits that go on the outside of the hose that will slide over the hose and then you use a heat gun and shrink the hose repair kit down to size therefore plugging the leak. (Hose repair kit). So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.sears.com/shc/s/home_10153_12605
National Customer Relations 1-800-549-4505
Home Services & Repairs 1-800-4-MY-HOME
1-800-469-4663
Parts Orders & Inquires 1-800-366-PART
1-800-366-7278
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 28, 2008 | Kenmore 23612 Progressive PowerMate Bagged...
Electrolux Lux 5500 Canister Vacuum Logo
95 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
