Question about Garden
Need a manual for a McCullough 600018U chainsaw.
  • 19 Answers
SOURCE: need parts and manual
YES.
Posted on Apr 29, 2009
SOURCE: Trying to determine gas-to-oil ratio on a chain saw.
Confirmation to #1: Recommended for all McCulloch chain saws at 40 to 1 ratio. 3 oz. per U.S. gal.
Posted on Jul 17, 2009
dontbother10
  • 2220 Answers
SOURCE: mccullough mac 4600 chainsaw gas line connections
This is an example of a typical fuel system with a few suggestions:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Your basic model number is 600465. I only saw 11- prefixes used with 600465s, no promises I did not miss any. There are a few different suffixes with the 600465s. I think the suffix is on your saw immediately after the basic model number somewhere (On older Macs it is usually on the bottom along with the serial number. The dash of the serial is often the correct prefix). I must defer to you to find your exact IPL, here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.htm
I chose "11-600465-09" as an IPL example:
http://www.ordertree.com/modelinfo/MCC/11-600465-09-MAC-4600-10%2F94-to-Current-IPL-211594/139.11-600465-09-MAC-4600-10%2F94-to-Current-IPL-211594.1.59.1.html
I find these helpful when getting into an area of repair I am unfamiliar with. Also all components are displayed and part numbers listed.
If you find different size hose a small sample of each taken to a local saw outlet should provide something suitable. Please ask how long they feel any replacement should be (usually 12" ample). HTH
Lou
If you have additional questions you can reply below and I will assist you further.
Posted on Feb 04, 2010
dontbother10
  • 2220 Answers
SOURCE: my McCullough chainsaw series 3200 is leaking oil,
Operator Manuals for McCulloch are difficult to find and will not help with this problem unless you want a repair facility. You can try here:
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
You provided no model number; this one was given in a 3200 fuel problem I answered earlier. An IPL for the model you provided follows (this is actually a 3214, I have never found a 3200):
http://www.ordertree.com/modelinfo/MCC/11-600032-32-Mac-3214-06%2F93-IPL-211229/139.11-600032-32-Mac-3214-06%2F93-IPL-211229.1.59.1.html
It is the only 600032-32 here:
McCulloch IPLs (all)
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There is a less detailed print here:
Chainsaws 32cc-35cc
On this block of saws the oil pump is under the flywheel and there are many hoses. Please use the IPL to identify and locate oiler parts. I hope you find a burst hose. There are oil pump repair kits listed. Unless the pump has an obvious crack or hole I would not attempt to change it until I had exhausted all other possibilities.
This works for older MCs but MTD (this one) saws often deviate from the explanation. It will give you a little guidance if you try to locate a different IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
I know it is not plugged but this may also be helpful.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
These are very difficult to work on, most saw shops will not attempt a repair. I hope the chainsaw Gods smile on your undertaking. Good Luck. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa HTH
Lou
Posted on Mar 27, 2010
  • 2239 Answers
SOURCE: I am thinking of buying
Sorry to tell you this but this machine is a domestic machine,it is not intended for extened use, just a few logs on a weekend
Posted on Jun 02, 2011
Where in Corpus Christi, Tx can I get service for my McCullough 14" electric chainsaw?
check the yellow pages for a mower shop that is an authorized service agent for mccullough products
check also in appliance repair section for the same thing
Oct 22, 2015 | Electric Garden
Mcculloch Owners Manual Looking for a manual for a
go to http://www.mcculloch.com and at the top right of the screen is their support link. The owners manual link will get you to their download links.
Aug 16, 2013 | Garden
Need manual 14" mccullough electric chainsaw eager beaver
McCullough 14" Electric Chainsaw User Manual
(NOTE: This is also useful for the EagerBeaver Electric Chainsaw)
Online Manual:
http://www.manualagent.com/mcculloch/ms1415/users-manual
McCulloch MS1415 User Manual
PDF Manual to download:
https://libr2.com/get/mtd-ms1415-2409
Oct 24, 2012 | Garden
Spark plug gap for Mccullough 2.0 eager beaver chainsaw
Refer to your service manual.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jun 02, 2012 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I am thinking of buying a McCullough MAC 335 Chainsaw but want to see a manual, find out how old it is and whether it is more than a householders toy
Jun 01, 2011 | McCulloch Garden
Jun 28, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
