Question about Mtd 22" Yard Machine Push Mower
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
  • 3,740 Answers
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
Posted on Sep 07, 2010
What kind of oil do you put in briggs and stratton lawn mower 450
generally, all B&S engines use SAE30 oil, however your local temperature range may make this an unwise choice. Google B&S Oil Chart
Jun 17, 2014 | Yard Machines 158cc Push Lawn Mower #11a...
My yard machines by mtd mower model number 11a-b13l029 won't start?
Fuel must be less that 30 days old! Air filter OK? oil level OK? Is the shut off cable streteched, If it is then is makes contact and will not allow the engine to start.
May 15, 2014 | Mtd 22" Yard Machine Push Mower
I have a Yard Machine lawn mower (Model # 11A-41MY229). I lost the manual. When I pull the chord the motor turns but it won't start. It has plenty of gas. Do these lawn mowers have a starter fuse that...
How old is this lawn mower, and have you replaced the spark plug recently?
Also, check to make sure the air filter is not clogged, preventing the engine from breathing.
May 02, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I have a yard machine mower model number 11A-549R729 that will not stay running. Have replace plug,drain fuel tank and clean carb. If you push the primer bulb it will continue to run. But once you stop...
Your carbs main jet is blocked. Using the primer supplements the fuel input and keeps the engine from becoming fuel starved.
You need to remove the main jet and run a strand of fine wire through the jet to clear it.
Aug 17, 2010 | Yard Machines 158cc Push Lawn Mower #11a...
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
If the oil in my lawnmower is overfull, how do I fix this?
should be a drian plug on the bottom of the mower engine, just drain and tighten up the plug and refill. they usually hold about 16 to 20 ounces of oil. Go buy briggs and stration oil at walmart or kmart just the right amount
Jun 13, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Oil
usually straight weight, either SAE 20 or 30 weight.
Aug 31, 2008 | Yard Machines 158cc Push Lawn Mower #11a...
Mtd 22" Yard Machine Push Mower Logo
1,068 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
