Question about Garmin GPS
Can,t find address on my garmin gps - Garmin GPS
I have aready registered my GARMIN on another computer. how do I update it on this computer?
The GPS is registered to your email address, not to your computer. Download and install Garmin Express from Garmin and plug your GPS into your computer. The program will identify the GPS and allow you to update it.
Mar 12, 2017 | Garmin GPS
Unlock garmin 1390t gps forgot 4 diget pin
    • 1 Enter your four-digit personal identification number that you used to lock your Garmin GPS. When your Garmin GPS is locked, you need to enter the four-digit PIN every time you turn the device on.
    • 2 Drive to the security location that you set when you locked your Garmin GPS. Turn your Garmin GPS on and pull the GPS antenna up so that your GPS is able to acquire the satellite. Once your GPS recognizes that you are at your security location, it will unlock itself.
    • 3 Contact Garmin if you forgot your PIN and security location. You will need to send your GPS to Garmin to have it unlocked. You will also need to send a valid product registration or proof of purchase for Garmin to unlock your GPS. Call Garmin at (800) 800-1020 and get the shipping address and specific instructions from an authorized Garmin representative.
Jun 09, 2011 | GPS
Wont calculat route
sat nav needs a valid gps signal to start calculating route, even if it found entered address. Address is searched on built-in map, not live gps position. That means, sat nav may have problem with gps signal. Try to reset device to its factory settings first. hope this helps
Nov 01, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
My address is 596 Moores Mill Rd., Midway, Ky. No one can program this address into their Garmin. Why not?? The Garmin will go to 1000 Moores Mill, but not below this address.
This has to do with the mapping information. The map does not provide enough detail to resolve ur specific address. Its not a hardware problem with the GPS. I have the same problem with my address. Best thing to do is drive to your address and then save that location as HOME or set your HOME to those coordinates.
- Jim
Oct 26, 2009 | Garmin Nuvi 350 Car GPS Receiver
Save addresses to SD card
yep if you have an usb cable you can do that
connect it to the pc (personal computer)
Apr 23, 2009 | Garmin nuvi 260W GPS Receiver
Blackberry 8320 address book unable to import to Garmin Nuvi 265TW AT the start of pairing it did import it but once blacberry out of connection  from garmin or disabled, when enabled pairing address is...
The address books may not be compatible with each other regardless of pairing or not. Best bet is to check on garmin.com in the support section. If it isn't they you can use the dial up on the GPS as well as any other enhanced features that require bluetooth services.
Feb 13, 2009 | GPS
Innacurate Garmin Nuvi
The accuracy of your garmin is actually good. The accuracy is only as good as the accuracy of the addresses that Garmin got from every municipality.
You can not recalibrate the unit but you can reset the "home" setting by parking exactly where you want to call home and then setting that location as home.
Please rate my answer as a FixYa! Thanks
Feb 08, 2009 | Garmin nuvi 200W GPS Receiver
Trouble with garmin 660 GPS
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Jul 14, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
306 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
