Question about Whirlpool Washing Machines
I have a Whirlpool 6245E Top Load machine. Every time I wash lately I end up with lint / fluff on my clothes. I have looked at the manual which indicates there is a magic filter at the bottom of the tub. I have also checked the inside of the agitator but there is no lint bag. Is there anything that can be done or installed?
Buffalo12980
  • 625 Answers
SOURCE: Fluff left on clothing
try using a fabric softener
Posted on Aug 23, 2007
Jimster
  • 240 Answers
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Posted on Oct 24, 2007
  • 27 Answers
SOURCE: Top load Whirlpool washing machine
Many Whirlpool built 'direct drive' washers use a 2 piece agitator. There are cogs called 'dogs' or 'dog ears' and a cam between the two halves of the agitator which can wear leading to a clicking/ticking sound and reduced movement of the top agitator section during the wash cycle leading to poor cleaning results. In most cases these worn parts can be replaced without much cost or difficulty. If you have this style of washer this should help.
Posted on Nov 02, 2007
aborcass
  • 2651 Answers
SOURCE: Whirlpool 6245E top of agitator
youll need to replace the gears, agitator dogs.unable to find that model you supplied , but the normal number is 80040 probably about $5
Posted on Nov 21, 2008
mindreader
  • 578 Answers
SOURCE: How do I removethe lint? Clothes are coming out
Sorry for the obvious.....
Fluff on the cloths is from the lint trap not capturing it from the air flow.
Air is passed into the clothes from the laundry room. It is heated and then passed over the clothes... then filtered air is forwarded to the outside exhaust.
If you are seeing lint on your clothes, then the air coming in from your laundry area is not lint free.
1. check the back/bottom of the dryer for lint accumulation.
2. Remove the lint trap and clean out the duct work.
3. Inspect all the flooring and areas around the dryer for dust/lint - and clean any that you find.
I believe that you will then have a clean and dry load.
The proceedure of cleaning described above should be repeated every 6 months or so....
-Jim
Posted on Nov 05, 2009
Model 3LSC8255EQ. TYPE111. When my wife uses the washing at present,and when shs removes the clothes their a lot of fluff on all the washed items,my wife has then to brush each item which takes a good...
TJIS DUE TO YOUR NEW WASHER SPINS AT AF FASTER RATE THAN OLD WASHER AND NFLUFF IS BEING EXTRACTED OUT OF CLOTHING IT WILL EVENTUALLY STOP AFTER A COUPLE OF WASHINGS OF EACH ARTICLE OF CLOTHING THIS IS NORMALL
Jan 24, 2011 | Whirlpool Washing Machines
I have a whirlpool top load washing machine model no. 6ALSQ8000JQ2. it is about 7 years old and does not have an area that collects the lint in the machine. Previously this was not a problem, but in the...
You have taken the necessary steps to reduce the lint problem. It seems they have not worked sufficiently. Another lint factor is due to HARD WATER.
You may have to disassemble the washer and remove the inner wash tub. On the bottom of the wash tub is a self cleaning lint filter. It may be gummed up with detergent and lint not allowing it to do its job. It will have to be manually cleaned.
Oct 06, 2009 | Washing Machines
Fluff on left on clothes
the lint filter is your problem needs to be cleaned out, the agitator which is the thing in th middle of the machine houses the lint filter the top should just pull off
Jun 07, 2009 | Whirlpool Washing Machines
After a washing cycle on wool wash, some items are not completely wet - machine is not overfilled. there is also fluff on some of the items
Look in the area where you place the clothes. in the back area about the 2o'clock posistion there is a small hole. usually this hole which recirculates the water becomes clogged with lint. If there is n othing there, you could have a pump failure,and it is not letting the water get back onto the clothes.
Feb 20, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Clothes covered in lint
You need a new timer. Reducing the cycle time will help the lint and not having a timer stuck on wash will help too.
Oct 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Black Stains on my whites
At the end of the cycle, the wash plate nutates for
approximately 30 seconds to fluff the clothing after the
final spin. The action of fluffing causes the outer wash
plate seal to rub against the stainless steel basket while
they are both relatively dry. This condition causes the gray
discoloration.
RESOLUTION:
An updated machine control, part number 8542693, is
now available. The updated control reduces the fluff time
from 30 seconds to 8 seconds, allowing the clothing to be
fluffed, without causing discoloration.
Gray marks or smudges can be washed out of clothing
after wiping down the basket. The consumer should use
the recommended amount of HE detergent and the hottest
water safe for the fabric or hand wash the garment under
running water. In either case, the fabric must be cleaned
prior to running through the dryer
Feb 13, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine lint
fluffed up,
If you have a manual filter..make sure it's clean. If you do, and it is, the tub drain could be blocked.( it is under the agitator and basket, requires disassembly) If you don't have a manual filter, the self-cleaning filter/ trap could be clogged.(it is underneath, also requires some disassembly. If you have tools and feel comfortable with things mechanical, get a repair manual from the library, maybe you can tackle the fix.
hope this helps,
handiman518
Jan 04, 2008 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool top loader 9 kg - I can't see any serial no.
There are no lint filters on this machine. The lint is pumped out with the water. There may be a restriction in the drain line starting where it connects to the tub or the small drain holes in the inner tub may be clogged.
Jan 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag Performa Washing Machine!!
All our clothes are being ruined with continuos fluff sticking to items.Have tried hot wash -no clothes, same problem.
Have tried not using Fabric Softener still no solution.
guest
Aug 14, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
349 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
