Question about Whirlpool GHW9400 Front Load Washer
The drum fills with water when not in use. - Whirlpool GHW9400 Front Load Washer
  • Whirlpool Master
  • 43,501 Answers
You have kind of the opposite problem of these tips... the soleniod valve has dirt under it and will not shut off tight...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 07, 2010
Where is the water sensor located? Error message IE. Sensor might be faulty.
The water sensor is a pressure switch that sits on top of the drum and monitors the pressure of air in the drum. As water fills the drum, air moves out and this creates a pressure on the switch which works out proportionately how much water has filled the drum.
See video.
Washing Machine pressure switch
Sep 25, 2014 | LG Dishwashers
Water continues to fill into the washer drum on the spin cycle.
Hi
You could have a stuck solenoid valve
Try this: Set the water temp on cold. Turn on only the hot water.
Does hot water try and fill the drum?
If so then there is a problem with the hot solenoid.
Next set the water on hot. Turn on only the cold water. Does cold water try and fill the drum ?
If so then there is a problem with the cold solenoid.
Jan 05, 2011 | Whirlpool LTE6234D Top Load Stacked...
Drum fills withe water when machine is not in use
Can you turn off water to machine? The water seleniod needs to be replaced this lets water in the switch sounds like it's stuck open.
Jul 26, 2010 | Zanussi ZWF1420W Front Load Washer
Will not stop filling water
Your fill hose that runs off the drum to the fill control controller on the front panel either has a leek an needs replaced or the controller its self need replacing, the line is cheaper, also look on the drum were the line go to, make show there is no leaks, this is a low presser an vacuum line,
Nov 26, 2009 | Washing Machines
Washing Machine Rinse and Spin lights are on
its the problem of drum getting blocked by any clothes getting tucked up.also try to move the drum manually with the machine off.if it makes any noise its the faulty motor.or drum has lost its alignment.it needs to be reseated properly in that case. -------------- The water fill valve - The water fill valve is a mechanical and electrical part, the coils on the valve need electricity to mechanically open the valve to allow the water to flow into the washer....myth....the washer pumps water into itself...no, it does not. The fill valve opens and the house water pressure pushes the water into the washing machine.
No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can No cold water or no hot water - The fill valve has two coils, one for the hot water and one for the cold water. It is possible that one of the coils can fail and you loose that filling ability. If the cold water coil quits, the hot will still work and during warm fill you will get hot water only and during a cold fill you will get no water at all. If the hot coils quits, you will still have cold water fill, cold water only on a warm setting and no water on a hot fill setting. You can test a fill valve live for 120 volts, power to a fill valve coil and no fill = a bad fill valve. You can also test the coils for continuity, no continuity = a bad fill valve. Some Maytag washers have a fuse in the fill valve circuit, if this fuse let go the washer will not fill. Fill valves can also from time to time stick open and not stop filling. If you have to shut off the fill valves to stop the water from filling in the washer, you have a bad fill valve and you will have to replace it.
Jul 23, 2009 | Tricity Bendix AW1400W Front Load Washer
Drum is filling with water after each wash
There is only 2 possibilities for the drum to fill with water after it has finished.
Firstly, if the empty pipe is connected to the sink outlet pipe, the water can syphon back into the washer if the pipe is too low, thereby slowly filling the washer when not in use.
Solution is to lift the outlet pipe higher.than the bottom of the sink.
The other reason is the inlet valve is not shutting off properly.
To prove if this is the case, turn the water off at the valve, if it is hot and cold fill, then turn the hot off only, and wait and see if water comes in over a period of time, if it does not then you need to replace the hot valve.
If water stills comes in with hot turned off, then you need to replace the cold valve.
If cold fill only , turn off cold and wait to see if any water comes in, if it does not, then replace cold valve.
Plz rate my solution.
Thanks.
Jan 29, 2009 | Washing Machines
Water leaks
I had similar issue. Fill tube running from the bottom of detergent tray to the washer drum was plugged.... (by a sock!!!). How did it get there? I'll tell you. You see the drum seal (around the inside of the door) is not a tight seal. You can actually reach up behind it from where it meets the top of the drum. Anyway in my case, a sock made it's way through that seal and outside the drum and into the drum containment vessel. So when the drum spun (to dry the clothes and empty the water) it made a terrible noise. The sock became lodged at the base of the fill tube opening and plugged it thus not allowing any water into the drum. Instead, when filling, the water just flowed out from the bottom of the detergent tray and onto the floor. I hope this helps.
Jan 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WF860 drum filling with water
Normally I would think that the problem is with the drain system (faulty pump or clogged lines), but you told me that also "When the washing machine is not bein.g used the drum slowly starts to fill with water!!" therefor I think it can be a dafective inlet valve or a faulty control assembly.
In either case, you will need a technician to fix this.
Dec 23, 2008 | Hotpoint Ultima WF860 Front Load Washer
Drum filling up with water when not in use.....
only source is leaking inlet valves and only way to cure is to replace
May 14, 2007 | Tricity Bendix AW1000W Front Load Washer
Whirlpool GHW9400 Front Load Washer Logo
50 people viewed this question
Dan Webster
Dan Webster
Sal De
