Question about Shredder Secure Shred Shredder
Accidentally put in too many sheets, not it is clogged what can I do?
  • 43,501 Answers
When that happened to me I just grabbed the paper and pulled very hard backwards and pulled the paper back out...then plugged it in a couple of times to jog it and it freed its self...
heatman101
Posted on Sep 07, 2010
My 10 sheet shredder it not shred 2-4 sheets of paper. it stop in the middle of the paper. I have to put it in rev then back to auto and repeat
Inspection of the shredding mechanism probably will reveal it's clogged with all sorts of debris. It will take a great deal of patience to pick out every bit to restore operation.
Feb 07, 2017 | The Office Equipment & Supplies
How do I clear the paper clog from the rollers?
First try to run it backwards. Sometimes that will clear a clog. If not UNPLUG IT, and painstakingly pick out any paper lumps with tweezers, slowly. GOOD LUCK! I have spent a few hours in front of the TV just picking out paper bits. In the future, be sure not to put in more than two or three pieces of paper at a time, NO STAPLES, and use shredder oil ever fifty or so sheets you put through!!!
Aug 20, 2014 | Cross Sentinel 10 Sheet Cut Shredder
Removing lower front access panel
Put the colour sheet in an empty mesh garment bag. It should still do the trick but not go into the trap.
Jun 03, 2014 | Whirlpool WFC7500VW Washer
I accidentally put coffee powder into the water container and now it has clogged my coffee machine. what now?
Same thing happened for me today. What I did was , I added a lot of water, shook it hard and poured over, did that a couple of times and the clog got cleared. But
I suggest you do it immediately. Its actually the one at me office, and it would be very embarrassing if it stopped functioning. Thankfully the coffee machine is working. :)
Jul 08, 2011 | Vacuums
My whirlpool front load washer wfw9500tc01 washed a load of sheets and then at rinse cycle it put up "sud" and a few seconds later it had a F21 code come up and now it acts like the pump is working but it...
Ok here is whats happening. 14b0f4a.jpgTheir is too much soap in the machine. The machine only uses a gallon or 2 at a time.01f5935.jpg You go adding in too much soap and it is gonna detect suds.aa3f677.jpg F21 Long drain. Possible cause: Clogged filter, clogged/failed pump, too much dang soap. c5d1358.jpg
Jun 17, 2010 | Whirlpool WFW9500TC Front Load Stacked...
Honda umk431 trimmer:I accidentally put 50:1 gas, clogged
try replacing the spark plug first. it may have burned on carbon after the two stroke oil
Apr 01, 2010 | Garden
Is there a reason not to use dryer sheets?
only if you have someone who is allergic to the sheets.
Aug 28, 2009 | Asko Dryers
Bosch Wahing Machine 300 NEXXT Series
Sounds like a baby sock stuck in the drain. Remove the access door bottom right. Reach in and unscrew drain cover slowly and a little at a time. Put a sheet pan under it to catch the water as it drains. It’ll fill the sheet pan a couple of times so have patients. That’s where your clog will probably be.
May 17, 2008 | Bosch Nexxt 300 Series WFMC2201UC
My HP Photosmart C3100 printer won't print anything other than churning out test sheets
I had the same exact problem.  My printer would simply say, failed to print constantly, unless I turned my pritner off and then back on, but then it would only print me a test sheet and nothing else.  This started happening right when I got a new ink cartridge.
The problem: While I was putting in my new ink cartridge, I accidentally pulled my printer back too far, and it was unplugged.
Solution: Make sure your printer is plugged into the computer.  I know it is a simple mistake, but you are having the same problem, this is the solution.
Apr 10, 2008 | HP Office Equipment & Supplies
Shredder Secure Shred Shredder Logo
88 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
Gilbert Ruiz
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
