Question about Dell 1320c Laser Printer
How to clear flashing exclamation error light
  • 67 Answers
Taker out the toner/cartridge, the paper and then unplug the power.. Also open the printer cover and look for any paper which could be jammed.. take out the paper as well ..
Ensure that all the papers are properly stacked in each tray.
Also fan out the paper before loading in the printer.
After about 10 seconds, plug the power back in and reinsert the ink/toner and paper.
Posted on Sep 07, 2010
  • 567 Answers
Looks like you have the wrong paper paper size selected.
The paper in the printer tray and the paper size selected for the print job needs to be the same.
Please change it in the Dell Color Laser 1320c Properties window and set it to the defined setting on the printer (A4, in most cases) and this error will go away.
I will look forward to your feedback for this question and your rating for the same.
  • Patrick Bruce Sep 02, 2011
    I know that the paper needs to be A4 NOT US.
    But how do you actually do it ?
Not working. Power on but shows a red flashing exclamation. Doesn't start making coffee.
Did you try to put grease on the brew unit to make it movement easy?
Feb 05, 2016 | Saeco Odea Go
Samsung 1915 printer: the red light with the double artrows and the exclamation in a triangle is flashing. What's up? John
1. A minor error has occurred and the machine is waiting for the error to be cleared. When the problem is cleared, the machine resumes.
or
2.Small amount of toner is left in the cartridge. The estimated cartridge life[a] of toner is close. Prepare a new cartridge for replacement. You may temporarily increase the printing quality by redistributing the toner.
Nov 01, 2010 | Samsung LASER Printer
How do I reset waste ink tank full on Smartbase mp390?
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Jan 05, 2010 | Canon SmartBase MP390 All-In-One InkJet...
Tank for used ink is full - how do I change it?
Dec 14, 2009 | Canon PIXMA iP2000 InkJet Printer
Printer won't print. Says to contact service
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ink well transformer full
Dec 02, 2009 | Canon PIXMA iP2200 InkJet Photo Printer
Absorber tank is full
Dec 01, 2009 | Canon Office Equipment & Supplies
The exclamation sign flashes and then the green light but no printing
The service Manual says that if both the ready (Bulb) light and the exclamation light are both on it is a invalid engine
code /Invalid network code. But to clarify that you say they are both on and solid and not blinking. If they are you have a bad main board.
If they are blinking then the error is a Flushing /Resolution reduced error.
The cause is:
Printer is processing data or printing pages,but the resolution of a page in the current print job is reduced from 600 dots per inch (dpi) to 300 dpi to prevent a memory full error.
Solution is:
Wait until the ready light is displayed to print other jobs.
• Press and release the triangle button to cancel print job. It is the lower of the two buttons.
• Press and hold the traiangle button again to reset printer.
Hope this helps
Bruce
Jul 14, 2009 | Lexmark E232 Laser Printer
Flashing triangular light with the exclamation mark inside it.
Clear the printer queue on the computer (double-click the printer icon in the tray or in the Printers and Faxes folder and cancel all documents listed). Then power off the printer and disconnect the power - remove the paper from the paper tray until you have the printer memory cleared as to not waste paper.
Jan 22, 2009 | HP LaserJet 1320 Printer
Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Dec 22, 2008 | Dell 1110 Laser Printer
Dell 1320c Laser Printer Logo
3,796 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
