Question about Dryers
My timer does not turn on my gas dryer. the dryer would stay on forever.
  • Dryers Master
  • 43,501 Answers
Your timer has gone bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 07, 2010
My maytag gas dryer work on dry cloth and stays hot but as soon as i put wet cloths in it they wont dry ?
My dryers timer wouldn't work correctly and the clothes were taking forever to dry. I decided to check the vent. My advice....Always check your dryer vent before spending any money on unnecessary parts or service calls. This Nest was pulled out of my vent with my shop vac sucking out and my house vac blowing out from inside. It finally broke free and now my dryer works like new.
Sep 24, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
Timer not working....turn knob to 30 minutes and it stays on forever! Knob never moves from 30 mins....please help!
Most likely the timer motor or the main thermostat is bad (some dryers hold the timer off until the thermostat says the dryer is warmed up). I assume you have adequate heat since you do not mention any problem with the clothes not drying in the usual time.
Usually there is a wiring diagram hidden inside the control panel or posted inside the back panel. If you can read it, you can figure out whether a thermostat controls the timer motor. (I've never had to work on a Whirlpool dryer control problem, so I can't tell you.)
Mar 08, 2011 | Whirlpool LER5636P Electric Dryer
Dryer has low heat, not enough to start the timer, tub turns and heat may be 95-100 deg. only and takes forever to dry
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 21, 2011 | Maytag MDE5500AYW Electric Dryer
What ever you set the dryer to and turn it on it stays. It will run at the setting forever unless you turn it off or open the door.
you dont give a model#. if it is mechanical the timer is bad. if electronic replace the main board.
Feb 12, 2011 | Kenmore Dryers
I have model # crgr7900A31 gas dryer front end loading. The dryer will not shut off. It continues to run.
Hi, If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system.
Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
Apr 14, 2010 | Frigidaire FGQ332ES Gas Dryer
Kenmore gas dryer doesn't stay on
I think it is probally the thermocouple not holding letting gas valve work properly, timers do not go out very often, its not getting hot enough to release the gas, valve wont let it, chheck thermocouple, let me know im not there, but its in the heat not getting hot enough
Feb 25, 2010 | Kenmore Dryers
Gas dryer wont trun off after drying
  • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
  • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
  • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
May 08, 2009 | Dryers
Kenmore Electric dryer runs on cool down forever.
Call the mfr and ask them about it. This problem may be pretty complicated. There may be a problem with your board that tells it to go to cool down. Can you set the timer for 45-60 minutes and it stay on heat for that long?
Feb 11, 2009 | Kenmore Dryers
No heat and the timer won't turn the dryer off
The timer runs thew the heat cycle with no heat it will run forever the heat runs thew the timer and thew thermstats and thermal fuses be for going to the heat elament check for 220volts at the heater if the heater has 220volts to it and not heating the elament is bad
Nov 30, 2008 | Roper RGX4634KQ Gas Dryer
Whirlpool Gas Dryer, LGR5636EQ2, timer not moving on Auto (DryMis
If that is a 3 wire gas assembly then the timer is screwed.The orange wire when removed from the mix will make the thing advance. The trouble is in the timer. If that is a 2 wire gas operator you need to change the high limit and open up the outside vent. My opinion.
Nov 14, 2008 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
