Question about KitchenAid 24 in. KUDP02IR Dishwasher
Soap dispenser does not open while in washing cycle
  • KitchenAid Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Sep 07, 2010
Soap dispenser will not open during was cycle.
Probably a faulty solenoid on the dispenser. Not replacable new dispenser needed
Jan 20, 2010 | Dishwashers
My soap dispensar inside does not open during wash
its just a bad (failed ) dispenser. replace it . this should correct problem . mm
Dec 07, 2009 | Washing Machines
Model shy66co5uc/14 soap dispenser will not open during wash cycle. I can open it manually, but it does not open in any of the wash cycles.
Most likely the small sping that activates to open the soap dispenser is either broken or missing. You need to get this part from the manufacturer.
Dec 04, 2009 | Bosch Dishwashers
Soap does not dispense from cup.
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Sep 07, 2009 | KitchenAid KUDK03ITBK Built-in Dishwasher
Water does not dispense on wash cycle
this would be the soap/ water valve. it is stuck closed or isn't opened.( no cure for an non-opened valve, just replace.)
Jul 16, 2009 | Hoover F7220900 SteamVac V2 Upright Vacuum
Soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Sep 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Soap dispenser doesn't open for wash cycle
I noticed you didn't rate out chat and saw that your problem was posted. I'm happy to continue to help you if you encountered problems or were not happy with the solution in your chat session.
Jul 07, 2008 | Frigidaire FDS251RJ Free-standing...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
KitchenAid 24 in. KUDP02IR Dishwasher Logo
102 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
