Question about Music
I HAVE 2 PEAVEY SP2 g's. The same one and only that one keeps blowing its woofer. There is evidence of damage to the crossover although it continues to separate the highs and lows. Can a bad crossover cause the woofer to blow?
  • Anonymous Mar 12, 2014
    peavey sp 2g crossover no high
  • Music Master
  • 12,061 Answers
YES 100% YES. Even if it is passing signal, you will most likely find that the Capacitor has gone bad. Replace it with a new one, of the exact same Voltage and value. (Capacitors like this usually go either partial or full short or open circuit.)
But that is NOT the only cause of speaker coils blowing, there maybe a problem with your output devices. If after you replace all capacitors and resistors (If any) with exactly the same or better rated components, and there is NO change, then you most likely have an Output device issue.
There are indeed protection devices called MOV's or Polly switches, basically a device that goes in series with the wires, to positive and negative, now if the current exceeds the value you have chosen, it enters a Very High resistance stat in a nano-second or so, and cuts off the damaging signal from blowing the Voice Coils.
Posted on Sep 07, 2010
Peavey problems
I assume you mean the Pr-12RX passive? That seems wrong to me, too. Put an ohm meter across the terminals of the horn driver and the woofer seperatly to see which, if either, is blown. If they're OK, look for a bad solder joint on the crossover.
Jul 28, 2014 | Peavey PR 12 Speaker PA Passive
Sp 3g crossover wiring
In Peavey cabinets, the woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the mid the remaining two wires would be the lighter color + and the darker color -
Apr 21, 2014 | Peavey Music
PROPER WIRING FOR ATTACHING CROSSOVER TO PEAVEY SP4G SPEAKERS.
In Peavey cabinets, the lower woofer is always Yellow + and Blue - and the horn is always Red + and Black -. On the middle 15" the remaining two wires would be White + and Blue -
Mar 22, 2014 | Peavey Music
Is there a fuse in a peavey sp2 for horns
there are 2 of them in the new ones....but ya probably the blew diaphrams...unless they are old one...then it could still be in the crossover..need to know the exact SP2 model you have, as they have changed the speaker again and again over the years.
Jan 15, 2014 | Peavey SP2 PA Passive Speaker
Peavey sp2xt speakers horn makes no sound when plugged into normal input. Horn works fine when plugged into the high side of the crossover.
High side speaker input jack defective, as they are switch also and if you plug the wire from the amp in full range and no hf sound but connecting directly to the bi-amp hi does, then your female 1/4 plug at crossover is defective for sure.
Jul 28, 2012 | Peavey SP2 PA Passive Speaker
On my peavey pro 15 neo speakers i don't know which wire is for what. What is the black, red, blue and yellow wires for?
black and red will goto 1 speaker. and blue/yellow to the other. typically red and yellow are + and black and blue are -. the crossover board might tell you which is which where they solder to it. but i'm pretty sure the black/red goto woofer. try hooking up both to woofer and listen to it. 1 way is going to sound horribly wrong lol. that will mean you hooked up the tweeter leads to the woofer. but DO NOT HOOK UP WOOFER LEADS TO TWEETER. thats why i say to do it on woofer.
Aug 30, 2011 | Peavey PR15 400w PA Speakers
Could u please send me a circuit diagram of Peavey sp2 crossover with the exact rattings or values of the parts? cos the image of the bulb you have sent is different from the one in my speakers
Here is a link to forum that someone has posted the soundguard protection circuit down the page:
http://forums.peavey.com/viewtopic.php?f=26&t=2168&view=previous
The 1156 lamp MAY have slightly different shapes but is an automotive lamp. If the bulb is blown, the polyswitch fuse is likely blown as well.
Jan 14, 2011 | Peavey SP2 PA Passive Speaker
Whats the wattage of the bulb used in peavey sp2 crossover, my sp2 peavey speaker bulb is blown
The lamp is an "1156" lamp... replace with that part number. Here :
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=524517&k=lamp%201156
Or you can find it at auto parts store.
LIKELY the polyfuse device is ALSO gone... Probably similar to this one (1.1 amp, trip 2.2 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2010-ND
or this one (1.85 amp, trip 3.7 amp):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=F2013-ND
Jan 11, 2011 | Peavey SP2 PA Passive Speaker
Sp5 peavey stop working it is getting the signal and you can pulg another speaker in the normal port and the other speaker works
The "in" and "out" jacks on the speaker are connected in parallel, so the fact that the other speaker works really doesn't tell us much. If you are not getting any sound at all from either the woofer or the horn, than the internal crossover is probably the defective part. The easiest way to hunt this down is to remove the rear plate that has the connectors on it and try each speaker directly,. Assuming that each speaker works, replace the crossover. Parts should be availabel from, Peavey directly. Call them and speak to the service parts department.
Dan
Oct 03, 2009 | Peavey Music
Run a sub woofer to a peavey board
I would recommend using a separate active crossover such as the Peavey 23XO and a separate amp for your subs.
Jun 20, 2009 | Peavey Pv 2600 Power Amplifier
Music Logo
119 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
