Question about Miele T9820 Gas Dryer
I just had the softwear update for the miele dryer 9800 and it hasn't worked since, all it does is beeps and lights for the check vent come on. The vent is clean. Any suggestions?
  • Miele Master
  • 19,396 Answers
Hi.
Try holding down reset for several seconds. If that does not work, then there is a problem with sensitivity settings of the signal from the two sensors in the air duct. Call Miele and insist to get a tech at home, the problem is not your fault.
Here a discussion on the same issue.
Posted on Sep 10, 2010
Miele Touch Tropic 9800. Why is it making a loud grinding noise?
Hi dear. Regarding your information,it's a dryer. Most likely it has bearing damaged or problem with drum drive system. There are several bearings on the dryer (one at the back- two on the front support, tension pulley etc...) I can advised to get it check by Miele. Thanks.
Apr 10, 2016 | Miele Washing Machines
Anti crease light flashing, keeps stopping and beeping
Check the dryer vent to see if it is free and clear.
Jan 26, 2014 | Miele Dryers
I have Miele t9800 gas dryer . After 5 or ten minutes the check vent filter light blinks and beeps. Then unit turns off. No heat. The drum turns and air flows. Vent and filter have been thoroughly...
it is not sensing enough air flow. Remove the hose at the rear and check the whole pipe for fluff. Also check that the outside vent is not blocked and any opening flaps are okay.
Feb 25, 2018 | Miele T9800 Electric Dryer
Hi, The clean air vent light came on and shut the dryer off. We cleaned out the lint catcher and the space it sits in and the dryer vent to out side. Nothing of significance found. Dryer continues to...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 07, 2010 | Miele T9820 Gas Dryer
My Miele Touchtronic T 9800 Dryer progrma works but when the dryer has ocmpleted its cycle, the cloths are still damp and not dry.. .I have to run the cycle several times to even get near dry cloths. what...
Hi dear.Try this,that should help you to solve the problem.If you need to download the user manual please click the link below.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T9802_us.pdf
Problem:The laundry is still wet. The program runs too long.
Solution:The air flow is insufficient. Check the lint filter, air intake and vent for obstructions(REFER USER MANUAL)
Aug 25, 2010 | Miele T9800 Electric Dryer
The dryer doesn´t work
I had the same problem with my dryer. The Miele technician came and took a look at it. There was nothing wrong with any parts. My vent pipe was kind of crumbling, so he replaced that. He then scrubbed and washed the lint filter with dishwasher soap and
the green scrubber, He also did a PC update of the firmware. My
unit already had the latest version, but he did erase all the error codes.
After all these rather simple steps the dryer started working like a charm.
He said the most probable caused was gummed lint filter because of using the dryer sheets. Miele dryers are designed to prevent static cling and he advised not use these sheets as they contain wax-like substance.
I would suggest scrub cleaning the lint filter first and see if that helps.
Aug 02, 2010 | Miele T9820 Gas Dryer
Got a software update and now dryer is flashing all indicators
try turn power off to dry,if still not working call the tech back that did the software update
Apr 24, 2010 | Miele T9820 Gas Dryer
Clean filter / vent indicator stops unit after T9820 MIELE GAS DR
Call Miele and schedule a PC update. When the technician comes he will do the update, if needed, and will reset the error codes.
Apr 04, 2010 | Miele T9820 Gas Dryer
Problem with Miele Touchtronic T 9800 Dryer end indicator
You've most likely got a bad control board. You'll have to install a new one which can be a bit expensive but cheaper than a new machine by far. I recommend getting a service tech to replace it for you however if your handy you could replace it yourself. Just get the new control board from an appliance parts store, they should be able to look up which board you need as long as you bring them the model number.
Dec 15, 2009 | Miele T9800 Electric Dryer
Miele T9820 Gas Dryer Logo
153 people viewed this question
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
