Question about ASUS P5PE-VM Motherboard
Does this motherboard support overclock?
I am just asking, because i want to clock my cpu...
my configuration is:
mb: asus p5pe-vm ( of course)
cpu: intel celeron d 331@2.66Ghz
ram: 1.5 Gb
hdd: 160 Gb western digital
that's it?
can you help me
    Champion:
  • 207 Answers
Y do u want to clk it?
Posted on May 22, 2008
How much video card memory does the p5pe-vm board supports? cause i have installed the geforce 6600 256 mb , and it only detects 128mb.. and when i run dxdiag , it says there ( approximate memory: 1
Eyaa! Use www.systemrequirementslab.com ant take one random game to check your computer performance, there it will show your computer performances.
Mar 14, 2012 | ASUS P5PE-VM Motherboard
MAXI MUM RAM NOT SAPOT DDR 1 BOYS NOT SEVE EMEDATLE ENFRMESON PLIS
http://dlsvr03.asus.com/pub/ASUS/mb/socket775/P5PE-VM/e2609_p5pe-vm.pdf
The link above is the link for the manual for the Motherboard, this will tell you what ram is supported.
Nov 17, 2010 | ASUS P5PE-VM Motherboard
My mothar board are pspe.vm so i know which ram add my mothar bord 512mb ya 1 gb ya 2 gb sopart my motharbord
ASUS P5PE-VM - motherboard - micro ATX - i865G specifications
General
Product type (AE)
Motherboard
Form factor
Micro ATX
Width
9.6 in
Depth
7.6 in
Compatible Processors
Pentium 4 , Celeron D , Core 2 Duo , Pentium D
64-bit Processor Compatibility
Yes
Mainboard processor socket
LGA775 Socket
Mainboard / Multi-Core Support
Dual-Core
Chipset Type
Intel 865G / Intel ICH5
Data bus speed
800.0 MHz
BIOS type
AMI
Storage key information
Serial ATA-150 , ATA-100
Power connectors
4-pin ATX12V connector , 20-pin main power connector
Processor
Installed Qty (Max Supported)
0.0 ( 1.0 )
Memory
Cache Memory Type
None
Supported RAM Technology
DDR SDRAM
Supported RAM Integrity Check
Non-ECC
RAM Installed ( Max )
0.0 MB / 2.0 GB (max)
Supported RAM Speed
PC2700 , DDR266/PC2100 , PC3200
RAM Features
Dual channel memory architecture , Unbuffered
Video
Graphics Controller
Intel Extreme Graphics 2 Dynamic Video Memory Technology 2.0
Audio
Audio Output
Sound card
Signal processor
Intel 865G
Audio codec
AD1988
Sound Output Mode
5.1 channel surround
Telecom / Networking
Modem
None
Networking
Network adapter - Marvell Yukon 88E8001 - Fast Ethernet , - Ethernet , - Gigabit Ethernet
Features
BIOS Features
SMBIOS 2.3 support , ASUS EZ Flash , WfM 2.0 support , ASUS MyLogo , Hyper-Threading Technology , DMI 2.0 support
Manual Settings
CPU frequency
Sleep / Wake Up
Wake on LAN (WOL) , Wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall) , Green Edition , CrashFree BIOS 2
Expansion / Connectivity
Expansion Slots Total (Free)
1.0 AGP 8x - LGA775 Socket , 1.0 Memory - DIMM 184-pin , 3.0 PCI , 2.0 Processor
Storage Interfaces
Intel ICH5 : ATA-100 - connector(s): 2 x 40pin IDC - 2.0 device(s) , Intel ICH5 : Serial ATA-150 - connector(s): 2 x 7pin Serial ATA - 4.0 device(s)
Interfaces
1.0 x Audio - RS-232 - Mini-phone stereo 3.5 mm , 1.0 x Network - Generic - 34 pin IDC , 1.0 x Parallel - IEEE 1284 (EPP/ECP) - Mini-phone stereo 3.5 mm , 1.0 x Keyboard - Line-out (center/subwoofer)/line-in - 4 pin USB Type A , 1.0 x Audio - Line-out - 6 pin mini-DIN (PS/2 style) , 1.0 x Serial - Generic - 25 pin D-Sub (DB-25) , 1.0 x Mouse - Line-in - 6 pin mini-DIN (PS/2 style) , 1.0 x Hi-Speed USB - Ethernet 10Base-T/100Base-TX/1000Base-T - Mini-phone stereo 3.5 mm , 4.0 x Audio - Line-out (rear)/microphone - 4 pin MPC , 1.0 x Display / video - VGA - 15 pin HD D-Sub (HD-15) , 1.0 x Storage - Floppy interface - 9 pin D-Sub (DB-9) , 1.0 x Audio - RJ-45
Additional connectors (optional)
4 x Hi-Speed USB
Miscellaneous
Compliant Standards
RoHS , Plug and Play
Hope this helps,
If I have helped you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well Thank
you.
Oct 23, 2010 | ASUS P5PE-VM Motherboard
Type of procesor for ASUS P5PE-VM
LGA775 socket for Intel® Core2 Duo/65nm Pentium D/Pentium 4/Celeron CPU
Aug 23, 2010 | ASUS P5PE-VM Motherboard
I want to change my p5pe-vm processor
Open the link provided by Asus below;
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=specifications
Click on, CPU Supported List.
The Celeron D 347 (revD0,65nm,3.06GHz, 533 FSB, L2:512KB, LGA775) is the best CPU of the bunch.
http://www.nextag.com/3__06ghz-533/products-html?nxtg=b240a1c0517-ACEB31F851614D26
Cheers'
Mike
Feb 20, 2010 | ASUS P5PE-VM Motherboard
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
I have so fat
Here the Infos about your mainboard:
ASUS P5S800-VM Allgemein MPN: 90-MBL0K0-G0EAYZ, P5S800-VM
Produkttyp: Motherboard
Formfaktor: Mikro-ATX
Breite: 24.5 cm
Tiefe: 24.5 cm
Kompatible Prozessoren: Pentium 4, Celeron D
Prozessorsockel: LGA775 Socket
Chipsatz: SiS661FX / SiS964
Maximale Busgeschwindigkeit: 800 MHz
BIOS-Typ: AMI
Storage Controller: ATA-133, Serial ATA-150 (RAID)
Prozessor Installierte Anz. (max. unterstützte Geräte): 0 ( 1 )
Speicher Unterstützte RAM-Technologie: DDR SDRAM
Installierter RAM (Max.): 0 MB / 2 GB (Max)
Unterstützte RAM-Geschwindigkeit: PC2100, PC2700, PC3200
Video Grafik-Controller: SiS Mirage
Videospeicher: Shared Video Memory (UMA)
Audio Audioausgang: Soundkarte
Signalprozessor: SiS964
Audio Codec: Realtek ALC655
Soundmodus: 5.1 Channel Surround
Kompatibilität: AC '97
Telekommunikation / netzwerk Netzwerk: Netzwerkkarte - Ethernet, Fast Ethernet
Besonderheiten BIOS-Funktionen: Wiederherstellung nach Stromausfall (Wiederaufnahme bei Verlust der Wechselspannung), DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash, Hyper-Threading-Technologie, RAID-Unterstützung, DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash
Sleep / Wake up: Wake-On-LAN (WOL), Wake on Ring (WOR)
Hardwarefeatures: ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2, Jack Retasking, ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2
Produktbeschreibung des Herstellers Das P5S800-VM unterstützt die neuesten Intel Pentium 4 LGA775 Prozessoren. Mit 800Mhz FSB, 1MB L2 Cache, Hyper-Threading Technologie und Spitzenleistungen von 3.6GHz und mehr ist der LGA775 Pentium 4 einer der schnellsten Desktop Prozessoren, die es zur Zeit gibt.
Dec 31, 2008 | ASUS P5S800-VM Motherboard
D345AJ
Not sure what information you were requesting. So here is some information about your motherboard:
- LGA775 socket for Intel® Core2 Duo/65nm Pentium D/Pentium 4/Celeron CPU
- Intel 865G + Intel ICH5
- 1066(O.C)/800/533 MHz
- Dual-channel DDR400
- Intel® Extreme Graphics 2
- 1 x AGP 8X
- 2 *ATA133 ,2 x SATA
- 10/100/1000 LAN
- 6-Channel audio
Here is a link to all the drivers to your motherboard:
This includes the manual!
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P5PE-VM
If you need more help Let me know. :]
Dec 10, 2007 | ASUS P5PE-VM Motherboard
ASUS P5PE-VM Motherboard Logo
121 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
