What does F1 mean for a whirlpool cabrio - Washing Machines
  • 122 Answers
F1 error code is for main board failure, replace main board
Posted on Sep 07, 2010
  • 552 Answers
This error code means the main control board has failed, this is a simple repair. The link below provides a video that explains how to access and replace the washers main control board.
http://www.appliancerepairlesson.com/2011/02/23/cabrio-bravos-oasis-f1-error-washer-repair/
Posted on Mar 05, 2011
SOURCE: Whirlpool Cabrio Washer Error message code F1
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Posted on Aug 02, 2008
SearsTechToo
  • 261 Answers
SOURCE: wtw6600sw whirlpool cabrio
First off I hope you have a Sears unit and second you did not pay a penny. Your F 1 error is a Primary control failure. Part W10104830 and one other do F1 and a oL code.
If you own a Sears machine you qualify for a recall under sf26-779B.
There is two parts to this call the board and a washplate
MCU part # W10201186
Washplate # W10077050
Recall will need your name and phone number and the machine model and serial number.
If you meet all of these conditions to the letter call Sears Recall at 1-800-659-7026
Posted on Sep 13, 2008
  • 1028 Answers
main control under console ..replace
Posted on Sep 19, 2008
canbruce75
  • 1776 Answers
SOURCE: f1 code on whirlpool cabrio top load
This is from a service bulletin. This may be of interest to you. There have been many problems with these machines in this area. Anyway, I sympathize and hope this helps. Best wishes.
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 – CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A – C above, and verified that there are no issues
with the air pressure system.
Posted on Aug 09, 2009
canbruce75
  • 1776 Answers
SOURCE: My Cabrio dryer is flashing f1. What does this
CORRECTION:
HE Top Load Washers
Models:
F1 Error Code
the tub.
Comments: - I don't know what satifaction they will give you, but you could contact Whirlpool. I don't know if it's fact, but some folks with this problem said that they were able to get the cost of repair covered in some cases, while others complained that they got no proper assistance from the manufacturer at all, so I really don't know for sure what good it will do, but it's worth a try. I'm sorry for your trouble and hope you find a good resolution to your problem. Best of luck and best wishes.
Posted on Sep 10, 2009
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    What does F1 mean on a whirlpool cabrio dryer
    You can google whirlpool cabrio dryer codes and find the code that you are looking for. I just looked it means your dryer is not heating.
    http://dryernotheating.net/whirlpool-cabrio-dryer-f1-error-code/
    Aug 02, 2014 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
    What does code f1 mean
    Hello
    Error code F1 means that the control of washer has either gone bad or about to go bad. This is a common issue with Whirlpool Cabrio washers. I have also seen them replacing the control without any charge, don't really know about the labor charges but they usually won't charge for the part. Please get back to me if you have any other questions.
    Kevin
    Nov 16, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    What does the code F1 mean?? We seem to be getting it a lot when starting a load
    The "F1" error code on the Whirlpool cabrio is quite common, and generally has to do with the control board. Replacing the control panel may resolve this issue. However, I believe Whirlpool is aware of the F1 issue with the Cabrio, and is fixing some machines for free. Please call 1-800-253-1301 for more details and see if you are eligible for a free repair.
    Thank you !!
    Jul 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
    Whirlpool Cabrio Washer : What is the F1 error code that I am getting occassionally mean?
    Hi
    Thanks for using FixYa. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. This error should be fixed by whirlpool as its a common issue with whirlpool Cabrio washers, you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Please do rate the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
    Jun 09, 2010 | Whirlpool Washing Machines
    F1 code whirlpool
    whirlpool F1 code - Appliance Repair Forum THERE IS A RECALL ON YOUR WASHER,CALL THE FACTORY AND GET IT FIXED FOR FREE
    Dec 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    I have a cabrio whirlpool washer and a F1 code keep's on coming up what doe's it mean
    i just called on mine for the f1 code and they said its a defect and would fix it call 18002531301
    Oct 04, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 error on Whirlpool cabrio
    it means that the control board is not sensing the water pressure (this tells the machine how much water to put in the washer) in my experience you have to replace the control board which will cost over 200 plus labor which will be over a 100
    Dec 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    Washing Machines Logo
    577 people viewed this question
    Top Washing Machines Experts
