Question about GE Spacemaker JVM1640SJ Microwave Oven
I broke off the bottom door lock on the inside whiloe trying to close the microwave.
  • GE Master
  • 9,098 Answers
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Posted on Sep 08, 2010
I have a Panasonic 1250w microwave and the door won't close and latch and when it does the light stays on then once you do finally shut it and press start, the timer starts but microwave does not turn on!...
Sounds like an alignment problem with the door itself and/or the interlock switches which operate as the door is opened/closed. Recommend a factory authorized service center. You don't want to take the chance of a leaky door.
Nov 21, 2014 | Microwave Ovens
I have a Samsung SMH9187ST microwave, it is about 2 years old. The door won't stay closed. It is worthwhile to try to fix it or should I just replace it?
If you can lift the plastic door latch catches with no resistance, it is most likely the spring/plastic connector. I removed the inside black plastic bevel with a jewelers flat screw driver, prying from the latch side's external edge. Once it was started, I could pull it off with a gentle lift, watch the bottom and inside edge (Thanks Lukas Patterson). I took out the black plastic latch, drilled a hole near the broken piece and all was good. Updating, as my original fix wore out. I ordered a replacement latch prior to repairing the existing latch, same directions to gain access, just use the spring on the new latch and press on the plastic cover to re-seat.
Dec 31, 2010 | Samsung SMH9187ST Microwave Oven
The door latch won't close. The light stays on. Display kept saying close the door.
The problem is an engineering defect. The mechanism that engages the door latch is mounted to a steel plate that is "L" shaped and when you close the door it pushes against and bends this plate out of position. After a while the metal plate fatigues and stays bend out of position and the door stops engaging and locking so the two safety switches inside don't get depressed. Result door won't lock and light stays on. I had to re-engineer it by cutting the tube of a pen to size and placing it in as a support bracket to put pressure on the plate so it won't bend anymore. My wife was going to throw it in the trash. Note of caution: I did cut my hand in several places trying to get the bottom cover on and off the microwave as the metal edges are razor sharp!!! I love this microwave it is my second one.
Dec 22, 2010 | Panasonic NN-T990SA Microwave Oven
Inner Bootom Door Hinge Broke off...since then it will not turn on...Will that prevent microwave from functioning?
You probably mean the door LATCH broke off. Yes, that will prevent your oven from operating. The door latches operate switches inside to indicate that the door is closed. If the control board doesn't see the right switch settings, it thinks the door is open and won't allow cooking. Replacement latches are available, but you should check with a professional shop to do the repair. If door repairs aren't done correctly, there is a chance of microwave leakage and an unsafe oven.
Nov 20, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
We take turns replacing microwave ovens where I work. The latest one, a GE JES1358WL, stopped working after opening the door while running on a one-push (1 minute) start setting, and the control panel is...
Sounds like part of the peg broke off and is left inside the recepter slot area where the sensor switch is. If it is the lower door plastic hook thing (inside bottom) that broke off, it is possible to re-attatch it to the door if you save the broken piece. Drill a small hole the size of a small wire or nail you have lying around to make a splint - Cut the nail or wire to about 1/2" to use it as a hidden "bone" or skeletal support inside the broken plastic. Glue the nail half way into the broken plastic using modelers glue. Closely align the nail peg to where the plastic broke off and mark it for drilling. Drill carefully making sure you are centered so that your wire "bone" will allow proper alignment of your plastic. Insert the pinned piece into the newly drilled hole checking for alignment, if it looks close enough you can glue it in place and you should have a strong enough repair. Dangerous to use a wooden peg to fool the internal switch. As it will be running even when the door is open and you don't want to get zapped.
Nov 04, 2010 | GE JE1235 Microwave Oven
Hello I have a LG Microwave/grill/convention oven. I caught my bracelet on the bottom lug thing that is attached to the door and now the microwave runs all the time? Please help is this something i can...
Nov 04, 2010 | Microwave Ovens
900E Microwave Oven Door Won't Open even after
Your latch has come apart inside the door or inside the oven. Probably a spring separated or broke.
Remove the cover --WATCH OUT FOR THE SILVER CAN - LETHAL -- and try to release the lock that way. I think you will be able to open it from inside but I also think your trouble is inside the door, though I dont have experience on this model. If the trouble is in the door, you will have to disassemble it. Look for hidden screws or a plastic strip which must be removed to separate the door halves.
Good luck in your project.
Oct 19, 2009 | Emerson Black Microwave Oven
Broken latch microwave door - won't open
I have a semmins microwave working in great condition, last night the latch mechanism inside the microwave don't allow the door latch to close.Only the top portion, bottom portion is ok.
Sep 14, 2008 | Sharp R-1870 Convection/Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
18 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
