Question about Iomega 1000 GB Network Hard Drive
1TB EGO keeps beeping when powered on and does not appear on my computer
  • 67 Answers
The chip in the hard drive appears to have some technical fault. the hard disk needs to be replaced.
Posted on Sep 07, 2010
Iomega eGo Helium 1TB has a damaged PCB. Local 1TB Casing do detects the HDD and its Drives. BUT asks for Formating the Drives. Which case can be purchased. how to recover the data. ?
It might be tricky, but you can remove the hdd from its casing, and install into a pc with compatible connections as a slave drive. Make sure to handle the drive carefully, and try to copy any data you want to another drive on the pc, then run chkdsk X: /f /r on the affected drive.
Another possible solution is to rightclick on My Computer, Manage, go to the drive mangement menu, and rightclick on the drive, and import it into your system so that windows can recognize it.
Mar 07, 2015 | Iomega Corp iomega eGo Helium 1TB 2.5"...
I have two Iomega 1TB 2.0 USB eGo harddrives with the encyption utility. I have the Windows 7 O/S. Initially, I plugged both harddrives (eGo) into my laptop, and created the password for each of the...
Iomega Utility are not Specific to the current device.
My iomega ego external hard disk was working properly but when i connected it today the encryption utility show that-Iomega Utility are not Specific to the current device and no any area shown to type password. My drive contains lots of valuable data. How can I acess into my drive. But the virtual drive is shown.
Aug 25, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I have iomega eGo portable hard drive with encryption... how do I create new folders on the drive to backup my data to?.....
click start all programs accessories open windows explorer right click on your Iomega then usually you would just right click an array of options will open up select new folder you can name the folder to anything you want as long as its not the same as the ones you already have on your computer
hope this helps
Apr 12, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I can't connect iomega ego 1tb to my computer
Try removing all other connected usb devices. It may not be getting enough power.
Apr 06, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
How do i down load and view movies on my 1TB eGo Helium 2.0 portable hard drive?
You can't view them on it, it's just for storing the files. To store them you download the file to your pc, connect the drive to the pc and copy them to it in Computer.
Feb 21, 2011 | Iomega 1TB eGo Helium Portable USB 20 Hard...
How do i copy files into Iomega eGo 1TB? It is brand new but show no storage space left.
Well this method will destroy everything on it so make sure there's nothing on it. Go into computer, right click on your drive, click format, the options should be default unless you know what you're doing, this should restore all the space to usable space. If this doesn't work go to properties then tools and disc error checking, there might be a bad sector.
Nik
Jan 26, 2011 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
Is the Iomega 1TB eGo Helium Portable USB 20 Hard Drive compatible with the sony vaio laptop???
Yes, because it is a Plug-and-Play device, and because Windows supports Plug-and-Play.
Dec 23, 2010 | Iomega 1TB eGo Helium Portable USB 20 Hard...
Iomega eGo 1TB USB 3.0 Portable portable harddisk 500GB. while connected to PC show an error on desktop "insufficient power on USB hub port" . pls suggest
Few different things are possibilities.
1. Are you connecting the device via USB 3.0 to the USB 3.0 adapter on the computer? 2. Try switching out your USB 3.0 cable for a different one. 3. If you are using the USB 2.0 instead. Make sure you are using the USB Y cable for the device and not just a standard USB 2.0 straight cable. Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's into the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer as they will supply more power than the USB's on the front of the computer.
Dec 20, 2010 | Iomega eGo 1TB USB 3.0 Portable - Ruby Red...
I have the ego 1TB external hard drive. My computer does not know its there. When I plug it in. the Mozy icon appears in my computer but I do not see a drive for the HD. When I turn on the external HD the...
right click on my computer and click the manage. a pop up windows appears then click disk managment on left pannal, it will give you the option to resolve you problem.
Oct 21, 2008 | Computers & Internet
Iomega  1000 GB Network Hard Drive Logo
209 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
