Question about Dell Latitude D600 Notebook
Looking for possible hard drive how hard is it to self install --with windows xp
    Brigadier General:
  • 10,406 Answers
A few simple steps:
0. find your original Dell "System Restore" set of CD/DVD disks, or order a replacement set from Dell, or run software on your computer to burn a set of "System Restore" disks.
1. do an "inventory" of installed programs (Adobe? MS Office?) and extract any "license-keys" you need (anti-virus software, purchased software).
2. backup your E-mail and contacts and music and other files, either to an external disk-drive, or burn some CD/DVD disks, or copy across your local network to another computer.
3. turn the computer off
4. disconnect the AC power
5. remove the battery
6. remove the old disk-drive
7. determine if it was an EIDE ("parallel-ATA") drive, or a SATA drive, and buy a new drive of the same type
8. mount the new disk-drive
9. reinsert the battery
10. reconnect the AC adapter
11. take your "System Restore" disks, and "boot" from the first disk, and reinstall Windows and the Dell applications
12. run Windows Update repeatedly (Service Pack 3, post SP3 fixes, Internet Explorer 8) to get all the fixes, and the fixes-to-the-fixes
13. install anti-virus software
14. install other purchased software, using license-keys you preserved
15. download the latest versions of "free" software (iTunes, Adobe Reader, WinAmp, et cetera)
16. import your "data" files
OR.................
if both the "old" and "new" disk-drives are SATA, and you have a desktop computer with two "unused" SATA ports, you can use software, such as the commercially-sold "Partition Magic", to "clone" the old disk-drive, and to "expand" the volume to span all the "unused/unallocated" space on the new drive, e.g., copy 20GB from "old" to "new", and then "expand" the 20GB partition to the full size of the "new" disk-drive. Install the new drive into your notebook computer, and enjoy the additional "free" space.
Posted on Sep 07, 2010
Ask jeeves
Depending on how you did the install it is possible to trash all your personal files. Hope you have some back ups.
Aug 09, 2014 | Microsoft Windows 8.1 - Windows
Ntldr is missing press ctlr+alt+ and delete to restar and i did and don't workz
First I have to assume that you are running Windows XP. This solution should work for other versions of Windows.
The "NTLDR is missing" error displays very shortly after the computer is first started, immediately after the Power On Self Test (POST) is complete. Windows XP has only initially begun to load when the NTLDR error message appears.
Causes of NTLDR Errors
There are a number of possible causes for NTLDR errors, including the most common "NTLDR is missing" error message.
The most common reason for this error is when your PC is trying to boot from a hard drive or flash drive that is not properly configured to be booted from; in other words, it's trying to boot from a non-bootable source. This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
Other possible causes include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors, an outdated BIOS, and damaged or loose IDE cables.
How to Fix NTLDR Errors
1.Restart the PC. The NTLDR error could be a fluke.
2.Check your floppy and optical (CD/DVD/BD) drives for media and disconnect any external drives. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk, CD/DVD/BD, or external hard drive or flash drive.
Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive with Windows installed is listed first.
3.Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors.
Note: There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
8. Reseat all internal data and power cables. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
Try replacing the IDE cable cable if you suspect it might be faulty.
9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
12. Replace the hard drive and then perform a new installation of Windows XP. If all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive.
NTLDR Errors Apply To
This issue applies to the Windows XP operating system, including Windows XP Professional and Windows XP Home Edition.
Windows 8, Windows 7, and Windows Vista utilize BOOTMGR, not NTLDR.
Still Having NTLDR Issues?
See Get More Help for information about contacting me on social networks or via email, posting on tech support forums, and more. Be sure to let me know what steps, if any, you've already taken to fix the "NTLDR is missing" issue.
Jan 29, 2014 | Microsoft Windows XP Professional
Windows can't find any hard drives...when installing xp
It sounds possible that your Windows XP install CD does not contain the necessary hard disk device drivers for the drive used in your Dell Vostro laptop and you would need to load these drivers separately during the XP install when the option is given to use third-party device drivers.
Some laptops may provide options in their BIOS settings to use a compatibility mode of operation for newer SATA hard drives that will make them visible to bootable utilities such as disk imaging software and older OS install CD's.
Jan 01, 2012 | Dell Vostro 1510 Laptop
My evo610c would not start and failed the HDD self test. I installed a new hard drive. It now passes the HDD self test, but will not go past the screen that says "not-system disk, replace and try again"....
Put the Windows CD disk into the CD-drive.
Turn the computer off.
Turn the computer on, and immediately look for a message like "press F12 to change boot order", or something like that. Tell the computer to first try to boot from the CD-drive. When it boots, the installation process will start.
Jun 23, 2010 | Compaq Evo N610C Notebook
Hard drive installation problem
Yes it is possible but you need to set it up as a dual boot system with XP installed on the 2nd drive (slave drive).
Mar 16, 2009 | HP Compaq nx6110 PC Laptop
Dell GX270 Maxtor 7Y250M0
If you are getting bad block reports on your hard drive, it means that your hard drive media has suffered some degradation. It could very well be that some system files are being affected by this, thus continually triggering the problem. You may not like the suggestion I have, but it looks to me like the most solid solution (saving you hours and hours of troubleshooting).
Backup all files from your hard drive, save all of your browser shortcuts to backup files, then perform another Windows XP installation with a low level format of the hard drive. I know a PC specialist with many years of experience that says hard drives develop faulty areas over time and that every 5 years or so, it's just best to back up data from the hard drive and perform a low level format. This resets the device completely. If there are any faulty areas on the disk, they are skipped over--to the operating system, the drive will be perfectly fine.
This is not a guaranteed solution, but it sounds to me like it will eliminate a lot of possible culprits for you. Good luck.
Dec 30, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Installing Windows XP in place of Kylin OS
If you have a copy of MS-Dos should work. The hard drive needs to be reformatted. This should change the File Allocation Table (Fat) and allow you to install Windows XP. Hope this helps.
Nov 17, 2008 | Computers & Internet
Install Xp From Dos
If XP will not install from the CD or if you have a new drive with no operating system onit yet try these:
Install Windows XP from the hard drive with Windows 98 already installed:
Boot Windows 98
Insert the XP CD into your CD reader
Explore Windows XP through My Computer
Copy i386 folder to C:\
Go into C:\i386 folder and double click on winnt32.exe to launch the setup from the hard drive
Install Windows XP from DOS (ie. no OS on a new hard drive):
Boot with a Windows 98 Start Up disk
Insert the Windows 98 CD into the CD reader
Run smartdrv.exe from the Win98 directory on the windows 98 CD (file caching)
Type cd.. to back up to the root directory
Insert Windows XP CD into the CD reader
Copy the i386 folder to C:\
Go into C:\i386 folder on C: and type winnt.exe to launch the setup from the hard drive.
Oct 20, 2008 | Computers & Internet
Installing windows
1. Windows 2000 / XP maximum hard drive size 137 gigabyte limit
This one was fun. To install a hard drive larger than 137 gigabytes on your computer you need the following:
a motherboard, such as the Gigabyte GA-7N400 Pro2 which support the 48 bit hard drive addressing. Only new motherboards can be counted on to support this.
Windows 2000 service pack 3 or later. Windows XP service pack 1 and greater have this support built in. I assume this isn't a problem with Linux at all...
Shalom
Aug 25, 2008 | Maxtor Hard Drive
Dell Latitude D600 Notebook Logo
96 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
