I had a hp 900 inkjet and the problem is it doesnt print at all, it always feed and suddenly stop in the middle of feeding then the green light continue to blink..pls help
  • 67 Answers
At the outset it appears to be the problem of either the paper roller or the kind of paper being used.
So, to begin with, open the rear access door of the printer, after you unplug the power from the back of the printer.
Now, clean the paper roller with damp lint free cloth and after about 10 -20 seconds, close the rear access door .. and replug the printer.. you can then reinsert the ink cartridge as well ..
this should resolve the issue.
Posted on Sep 07, 2010
Printing on two labels
lets start with the basics.
Do a calibration of the label to the printer : -
1/ Turn off the power
2/Press and hold the feed key
3/ Turn on power and wait for the green feed light to flash twice.
4/ Release the feed key
5/ The printer should feed and print the configuration.
Now press the feed key and the label should feed and stop at the gap.
If this does not work , then let me know via this page.or contact me at the link below
trev
thermal labels printers co uk
Mar 06, 2014 | Zebra TLP 2824 Printer
Paper stops half way
Please check for torn piece in the carriage which is causing the error
Jul 06, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
The paper feeds fine, but then jams half way thru. Its like it keeps feeding when it should be printing, then stops and jams
i have the same problem with my hp 900 inkjet...i tried to google but i can't find any answer on how to solve this problem :(
Jan 18, 2011 | HP PSC 1610 All-In-One InkJet Printer
HP deskjet 3845 will not feed paper to print. Is the green light suppose to blink? Not sure where paper needs to go to get proper feed
Paper goes in the bottom tray. Take a small stack and place it in the bottom tray and push it in until it stops. It will feed out of this tray, print it and output it to the top tray.
Jul 12, 2010 | HP Deskjet 3845 InkJet Printer
My HP laserJet 2200DN doesnt feed paper when printing.
it could be hardwre problem.. you need printer technician to replace some broken parts
Aug 25, 2009 | HP LaserJet 2200dn Printer
Both paper feed and power lights flash after printing several pag
lean head-eject ink ruler & clean point of contact betwin cartridges and head-ink unit.
Aug 07, 2009 | HP DeskJet 970cxi InkJet Printer
Printer stopped working Epson C86 and red middle light button on
The red middle light is the paper feed indicator. If it is on, it means the paper feed is (or the computer thinks it is) jammed. Remove all paper from the hopper and make sure all bits of paper are removed from the feed mechanism. Press the paper feed button (the middle one) a few times during this process to try to feed through any jammed pieces. If this doesn't work, you have an internal jam or broken feed system, or your main board has gone haywire.
Any further investigation requires you to remove the printer top cover, which you may or may not feel like tackling. If you don't, take your printer to a technician, or sell it on E-Bay for what you can get. If you do, post a new comment to this effect and I will provide a tutorial on removing the top cover. It's not difficult if you know how.
Apr 10, 2009 | Epson Stylus C86 InkJet Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
Always feeds a second sheet
You may need to repalce your pick-up roller and your stop roller
Mar 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Paper jam light is on
Hi! I have the same issue. The only solution I still use: select print from document with no paper in the hp's feeder. Let the printer go on "paper out" message, now put the paper into the feeder and press the print button on the printer. Success!
Oct 05, 2007 | HP Photosmart 7450 InkJet Printer
137 people viewed this question
jasbo
jasbo
