Question about GE DVL223EBWW Electric Dryer
Why is my drier not getting hot and taking longer to dry clothes
    President:
  • 3,074 Answers
The vent hose may be crimped or clogged. remove the vent hose off the back and feel for hot air. Hope this helped tim
Posted on Sep 07, 2010
SOURCE: Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Posted on Oct 05, 2008
TheMobilian
  • 8220 Answers
SOURCE: Wont dry very fast
Nope change the control thermostat mounted beside the skinny white fuse on the blower housing.
Posted on Jan 30, 2009
  • 744 Answers
SOURCE: Dryer taking longer to dry clothes
For a gas dryer:
Assuming the dryer is working properly and the control cycles are ok, look for things like a restricted venting system which inclides the exhaust, lint screen, etc. This would be the large pipe connected to the dryer exhaust that vents outside.
If it's an electric dryer, there could be issues with heating elements, thermostats, a control board, the timer, etc. Also check for any excessive lint build-up.
Posted on Apr 12, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint tdc 30 not getting hot enough to dry
Remove and clean all filters, and make sure you have the correct heat setting selected
P[lease rate my solution.
Thnks.
Posted on Nov 16, 2009
jsrock516
  • 5911 Answers
SOURCE: dryer is not getting as hot taking longer to dry
If your dryer is STILL heating, but your dryer is showing signs of heavy condensation or longer dry times, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks, clogs, or excessive bends. As the dryer exhausts, moisture from your clothing is circulated with the warm air. If you have any restrictions in the exhaust system, the moisture will collect inside the ducting and drum. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state, or having improper air flow, will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards.
If you do determine you have an internal component problem, the next link can give you some helpful advice on how to troubleshoot a dryer with a no heat problem: http://www.fixya.com/support/r3574266-thorough_dryer_advice http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat If you have any questions, please post back and let me know. I hope you find this information helpful.
Posted on Sep 15, 2010
How can I reduce the humidity of the air expelled from the dryer?
If the aire being expelled is humid then this suggests that the unit if working fine. if clothes are still damp then maybe give them a second spin before putting in the drier, or dry them for longer. Also try putting less in the drier and drying in two loads.
Oct 19, 2014 | Miele Novotronic T230C Electric Dryer
Thor washer/dryer combo not drying properly. What is capacity of machine?
Whilst 'combos' will 'wash' a full load of clothes, they are not so good at 'drying' a full load. Since there must be a 'tumbling space' inside of the drum, into which the clothes can fall during the drying cycle.
In a 'nutshell' one 'wash load' equals 'two drying loads',
That's the price you pay for having a space saving 'combo' machine instead of having a 'washing AND a drying machine.
Add to that the fact that most 'combos' are 'condenser driers', as opposed to 'free flow outlet driers',
The consequence is that it takes far longer to 'wash and dry' a load of clothes in a 'combi' as oppose to two separate machines
Aug 21, 2013 | Washing Machines
Doesnt dry very well. takes about two days for clothes to dry completely.
If your drier is getting warm. You need to check the vent hose and the vent to the outside for a restriction. If the vent hose is stopped up, she will not dry proper, the hot moist air can not get out of the drum and just keeps it all inside. Now if is not getting hot, you have an electrical problem with the heater coils, that may take a tech. to come out and fix for you. Hope this helps Fix ya up.
Apr 26, 2011 | Dryers
My drier gets warm but not hot???whats wrong....I check exhaust system cleaned it and vent system too. power is normal I put it on express drying too and warm not hot?
Most electric driers have two heater coils, inside that provide heat to dry the cloths. Wires like in a light bulb only bigger. I suspect one of these coils is burnt out and thats why it is only getting warm not hot. Also be sure to remove the hose from the back of the drier and check for a restriction there.
Oct 08, 2010 | Kenmore 63942 Dryer
NOT DRYER CLOTHS LIKE IT USE TO TAKING MUCH LONGER
Check for clogs in the vent air line. If dryer lint or some obstruction is slowing the air flow it will take longer to dry clothes. Also the dryer may not be getting hot enough. Check to see if the clothes feel hot or warm when you reach inside. If it feels hot enough it is likely an issue with air flow. heat and air flow are required to dry clothes.
Oct 02, 2010 | Frigidaire Electric Dryer
Drier runs hot
A pretty common problem with these wonderful dryers is the fact that they have a plastic blower wheel. Over time the hole the shaft attaches to gets worn out and causes the wheel to slip. This makes it take longer to dry the clothes and overheat. Restricted airflow due to bad blower. Seen it many times.c3d4a43.jpg1bd8fba.jpg44ca933.jpg97a9c4a.jpg
Jul 24, 2010 | Maytag HYE3657A Electric Dryer
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Wont dry very fast
Jan 30, 2009 | Kenmore 62602 Electric Dryer
KENMORE DRYER
the only thing that can burn in a drier is lint most of the time if lints building up in a drier depending on age its because of poor venting if the drier heats but it takes longer than an hour to dry clothes you have a vent restriction but every few years you should take it appart and clean it out now kenmores drums run on rubber wheels and like a car they get flat spots in them so they roar and bump when they first start but should get quiter as you run more loads during the day
Dec 29, 2007 | Kenmore 63942 Dryer
Neff washer/drier
soap drawer is just a slide fit - give it a good yank. for the dryer, take the top off and there should be a mainifold across the top with stats mounted on it. one or two may be re-settable stats ie have a little button in the middle which press to reset. if this works, cause of stat popping out is usually a lint blockage in the dryer manifold
Apr 28, 2007 | Neff V4380X0 Front Load Washer / Dryer
GE DVL223EBWW Electric Dryer Logo
70 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
