Question about Hayward SAND FILTER, PRO SERIES
I just bought a used but nice hayward sand filter for my pool to replace a older defilter. I want to say i am pretty expierenced with pools and plumbing but this somthg. Connected everythg 40 lbs psi ,blows top off and cant get correct suction . You can disconnect out let and watch whole filter assembly expand what s up?
    President:
  • Hayward Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
Put the valve in recirculate mode and see what happens. Does the pump run normally? If so the sand bed is likely clogged. Did you replace the sand? Another possibility is you have it connected to a pump that is too big for the filter. The tag on the filter should give a maximum flow rate the filter can handle. Be sure your pump is not exceeding it. It is common to see the tank “swell” once the pump is turned on. As long as you stay below the 50psi max you are fine. If you are unsure about flow rates please reply in a comment with the pump information so we can try and determine that for you.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Sep 07, 2010
When I was filtering the pool the sand from the sand filter is blowing sand into the pool
That means that you have a cracked lateral in your pool filter. You will need to replace the lateral, which should stop the sand from entering your pool through the return line.
Jul 10, 2011 | Hayward SAND FILTER, PRO SERIES
Hello, when i vacuum my inground pool using a hayward filter....it cleans the pool but the next day sand forms on the bottom of the pool...this was a constant problem last year....what may be causing this?...
If sand is getting back into the pool, the strainer in the filter is broken or out of place. The filter has to be disassembled, sand must be removed and the strainer must be inspected for cracks or leakage. New parts are available from most pool supply stores.
Gary
Mar 05, 2011 | Hayward SAND FILTER, PRO SERIES
I have an inground pool with a Hayward S220T Pro Series Sand Filter. During normal operation, I am getting sand in the pool, through the inlet vents. I am wondering what the problem could be. I suspect the...
You would be correct; replace them with part number SX220DA and you should be all set. If the sand is older than 3 seasons, replace it too while you have to empty the filter.
Aug 23, 2010 | Hayward S220t Top Mount Pro Series Sand...
I have water leaking from under my hayward pool filter...any suggestions?
Try consulting the the owners manual for these pool filters. They have a pretty good trouble shooting guide and it should be able to help you correct your problem.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 29, 2010 | Hayward SAND FILTER, PRO SERIES
After replacing the sand in a sw256t swimpro
Try the owners manual for these pool filters. It has some really useful troubleshooting guides that should help you get this figured out.
Apr 29, 2010 | Hayward Pro Series 18" Above Ground Pool...
Sand is coming out of our Hayward filter and into the pool through the side return jets. How can we fix this?
One of the lateral fingers on the inside was cracked. Once we replaced this with a new one the problem ws solved.
Jun 10, 2009 | Hayward SAND FILTER, PRO SERIES
Replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
