Question about Dryers
The inginator is glowing for about a minute then it is going out, it isn't heating up and I was told unless the inginator is broke it isn't bad, please advise me what else it could be
  • Dryers Master
  • 43,501 Answers
You were told wrong...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 07, 2010
Bottom oven does not start
I HAD THIS SAME PROBLEM THIS WEEK. MY REPAIRMAN TOLD ME THE GLOW BAR IGNITOR ARE BAD TO GO BAD. EVEN IF IT STILL GLOWS IT PROBABLY ISN'T PUTTING OUT ENOUGH GLOW TO OPEN UP THE SAFETY GAS VALVE. I THOUGHT MY PILOT LIGHT MIGHT BE OUT, BUT THEY DON'T EVEN HAVE ONE FOR THE OVEN/BROILER IN THE BOTTOM OF STOVE, BUT IT DID HAVE ONE FOR THE TOP BURNERS.
YOU CAN WATCH SOME YOU TUBE VIDEOS OF HOW TO FIX THE GLOW BAR IGNITOR FOR THE OVEN AND LEARN MORE--HOPE THIS HELPS..
Jan 23, 2015 | Ovens
Kenmore gas dryer #41793142300 electronic start doesnt heat up
if you first have heat and then like 10 to 20 minutes later no heat you could have bad gas coils,on most gas dryers there's a plastic cap you can pop off on the front panel so you can look in and see the ignitor,if at first the ignitor glows orange and the flame lights then after a few minutes the ignitor glows orange and the flame doesn't light you have bad gas coils,they are located on the top of the gas valve,easy to change.part number 5303931775 go here and look at part 71
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-41793142300/0582/0151200/R0310102/00005?blt=06&prst=0&shdMod=41793142300
Mar 25, 2013 | Dryers
My gas dryer isn't getting hot, I was told it was probably the ignitor, I took a continuity test and got a reading of 80 ohms on my glow plug, I don?t know what a normal reading is for a glow plug....
if the ignitor is lighting or glowing its fine,, what you need to check are the thermostats in the rear of the machine, look here for what they look like and ways to test them
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Jun 14, 2011 | Dryers
The pre heat is taking a long time over 30 minutes
SOUNDS LIKE THE IGNIGHTER IS GOING BAD, OR GLOW ROD. OPEN THE BOTTOM DRAWER AND WATCH THE AND SEE WHEN YOU TURN THE OVEN ON HOW LONG DOES IT TAKE TO GLOW BRIGHT, THE GAS BURNER WILL NOT START IF IT DOSNT GET A READING FROM THE GLOW PLUG
Dec 24, 2010 | Ovens
My dryer isn`t get hot. What should i do? kenmore-400. I live in Pembroke Pines. Florida
heatman101
Dec 18, 2010 | Kenmore 400 6943 Dryer
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
My oven quit working, I can smell gas and the glow rod (not sure if thats the right name), is heating up, but not igniting the gas. At one point it would light, but go out after a few minutes.
Just because it glows that does not mean it is not bad...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 28, 2010 | Kitchen Ranges
When my mdg 6000bww is turn on heating element glows, flame ignites, then flames goes off within 5 minutes. After waiting approximately 15 to 20 minutes, until it seems to cool down can restart and goes...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
I do see an orange glow at the bottom. No heat
its a bad ignitor
the glow should be almost white hot
this heat is what opens the gas valve
dont go looking for a fuse
Oct 03, 2009 | GE JGBP24 Gas Kitchen Range
Dryers Logo
35 people viewed this question
Top Dryers Experts
