Question about Kenmore Microwave Ovens
Our microwave stops after a few seconds and code comes up F9
  • Kenmore Master
  • 9,098 Answers
It of course depends on the model number, but here's some discussion from other boards:
F-9 on this microwave IS inverter related. There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing proceedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c.
f9 model 721.63764300
Kenmore Elite 36 " over tne counter microwave is supplied by LG made by Gold Star, made in China. It's main problem is the high voltage inverter board supplyed by Sears Parts. If you get a F-9 code on your microwave display screen and the micro quits it's probably this board. Reset the machine by pulling the power plug and waiting an hour. If it is the high voltage board is at fault it will probably fail after 45 seconds of start up. This part is really hard to get at but is less than $100. A qualified technician should be able to remove and repair this item in less than hour. Some techs will quote you $300 labor, don't buy it, it should cost a $100 or less. No need to buy another microwave.
To find helpful exploded view diagrams and get part numbers, you can just enter your full model number at the Sears parts site.
But Sears parts can usually be obtained for far less here by entering either the part number.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########.
Posted on Sep 08, 2010
4 Suggested Answers
SOURCE: Kenmore elite microwave displays F9 after a few seconds
I have the same problem. The sears guy told me that I needed a phillips screw driver and a torx adapter/driver to remove the entire microwave cover ( it slides off0 to gain acess to remove and replace the bulb.
Posted on Jan 12, 2009
  • 408 Answers
SOURCE: MICROWAVE WILL NOT HEAT. F9 APPEARS IN THE DISPLAY WINDOW
F9 indicates a problem with the door latch.  There is a safety switch that will not allow the microwave to operate if it detects the door is not closed properly.  Even though physically it may seem the door is shut, the safety switch is not relaying the message to the onboard computer.  You need another door latch switch.
Posted on Mar 10, 2009
rylee_smith
  • 8619 Answers
SOURCE: microwave
Hi
3 things can fail - the control board, the inverter board, or the magnetron. If the microwave runs for about 7 seconds with a ticking sound..then stops and shows "F-9", it is the magnetron that has failed. The fact that the unit starts and runs with the TICKING SOUND means the control board is sending signal to inverter board and the inverter board is sending signal to magnetron. Magnetron is covered by full 5 year warranty, inverter board is only 3 years.
If this is not the case then it could be a defective control board, inverter or line voltage too high.
Please do rate the solution as "FixYa" if found useful and revert for further assistance.
Thanks
Rylee
Posted on Mar 26, 2009
Microwave stays on for about 15 seconds, shuts off and shows F9 as problem.
There's quite a few different makes and models out there with loads of different codes. Please tell us WHICH make AND model microwave you have and we can check the servicing guides for you.
Dec 27, 2014 | Microwave Ovens
Microwave runs for 5 seconds then shuts down displaying F9 HELP
If the microwave runs for a few seconds and stops the touchpad might be at fault. This is not common. Generally speaking, if the microwave display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad
Oct 19, 2014 | LG Microwave Ovens
Why does my microwave stop working and flash F-9
Since this an LG microwave, an F9 error when the inverter module fails. Unfortunately, other parts could cause the inverter to read as a failure. A bad magnetron, relay 2 or door switches or the connections between the various parts could be bad. Since the microwave is starting, the switches are the least likely culprit. However, it's hard to determine if the inverter or the magnetron is bad without replacing one part. Then the other if the first repair doesn't solve the problem.
I hope this helps.
Mar 19, 2013 | LG Microwave Ovens
Hit the start button and runs for 6 sec then code F-9 can't find manual
You didn't mention your brand or model, but F9 code on an LG sometimes means either a bad door switch or a loose door switch mount.
See this file on door switches.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
Here is more info on F9 as it relates to some brands and models:
Sears Kenmore Whierlpool LG 721.63683300
"F-9 on this microwave IS inverter related. There is a service tech troubleshooting document stuffed in behind the control board cover which has some testing proceedures. My problem was the magnatron and checked out bad with the help of this document. It would run for a few seconds making clicks and then say F-9. It has been working great since I replaced the magnatron PN 6324w1a002c."
"f9 model 721.63764300
Jul 02, 2010 | LG LMVM1945 Microwave Oven
F-9 problem
Hi, generally the F9 code indicates a problem with the door latch (usually upper) or with the control board.
You can do a Google search for my text file "doorsw.txt" to help you diagnose and repair door switch trouble.
BUT - since it always stops at 53 seconds, that leads me to think you have trouble with the control unit (circuit board / controller assembly).
Once you read and digest the info on door switches, please feel free to do an updated post and I'll be happy to help you further.
It may be corrupted ROM in the control unit.
Take care
May 20, 2010 | Kenmore 64683 Microwave Oven
Mar 10, 2009 | Kenmore 63663 Microwave Oven
Humming sound, F9 and dead
Seems like I answered this, but maybe it's a different poster.
The 721 model code means it's an LG/Goldstar-made oven and F9 indicates a problem with the inverter or magnetron.
Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models.
I would suggest you contact Sears for service.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 19, 2008 | Kenmore 64683 Microwave Oven
F-9 Error after running a few seconds...
If this is a "SmartWave" branded microwave oven then F9 is an error that indicates an inverter board or magnetron has failed. Either way.. Try this...With the F9 error cleared, start the oven and listen for a ticking sound. The inverter will attempt to 'fire' the magnetron 5 times.(ticking sound). If can hear ticking, replace magnetron....Else in may be a door switch problem
May 30, 2008 | Microwave Ovens
F-9
Need to know the entire model # on the microwave.
Oct 05, 2007 | Microwave Ovens
Microwave Ovens Logo
326 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
