Question about KitchenAid Kitchen Ranges
What does F2:E3 mean on my KichenAid Superba Range?
5 Suggested Answers
  • 149 Answers
SOURCE: whirlpool rf385 with error codes e3 f2
F3 - E2 Oven too hot Replace oven temperature sensor
Posted on Mar 24, 2010
  • 1891 Answers
SOURCE: I have a Whirlpool electric
E 3 code And the F 2 code tells us that the oven has over heater . and to correct this problem replac the oven tempt prob . ( you could have melted wires or shorted wires also . ) if the probe replacement does not correct problem hte the clock will have to be replaced also .. mm hope this helps . feed back pls ..
Posted on Dec 05, 2010
  • 2341 Answers
SOURCE: YKGST307 SUPERBA range works very well, except
if the stove works fine until something else is turned on,it sounds like you have an electrical problem with the house.run a seperate line for the stove from the breaker box,it sounds like you have to many things running off of that one circuit
Posted on Feb 10, 2011
Testimonial: "was helpfull"
allbrands
  • 600 Answers
SOURCE: I have kitchenaid Kerc700 electric range that had
Hello, Thank You for using FixYa. I will be helping you today.Kitchenaid F2-E3 means a button was held down too long if you push cancel and it comes back you would have to replace the glass console. Thats assuming its F2-E3 and not E3-F2
Thank You and please rate my answer if it was helpful..
Posted on Jun 12, 2011
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
on Apr 24, 2015 | Kitchen Ranges
Tip
F5 - E0 Door Switch
Two digit codes:
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Range displays code of F4 and stops working
F4 Oven temperature sensor (RTD) shorted Replace Oven temperature sensor (RTD)
The F2, F3 and F4 codes refer to problems with the oven temperature sensor or the keypad. If you see the two-digit F2 code, it means your keypad has shorted and the ERC must be replaced. The four-digit F2-E0 code means that the oven temperature is too high. Test the door lock and the relay operation, and correct as necessary. A two-digit F3 code means an open temperature sensor or thermal fuse, so those parts must be replaced. A four-digit F3-E0, F3-E1, F3-E2 or F3-E3 code or a two-digit F4 code means that either the oven is registering as too hot or the temperature sensor has shorted. Either way, the oven temperature sensor must be replaced.
Hope helps.
Jun 14, 2011 | KitchenAid Kitchen Ranges
I have kitchenaid Kerc700 electric range that had the code F2:E3 show up on the display. What does this mean?
Jun 12, 2011 | KitchenAid KERC700 Electric Kitchen Range
YKGST307 SUPERBA range works very well, except when regular washing machine starts working downstairs. Then stove panel starts to beep for 5-20 min ( till i unplug it from electrical outlet) indicating F2...
Feb 10, 2011 | KitchenAid KGST307 Gas Kitchen Range
Error F2E5 on Kichenaid oven
F2 - E1 Keypad cable unplugged1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Apr 01, 2010 | KitchenAid KERC507 Electric Kitchen Range
Kichenaid...superba how to wire
black is hot and white is neutral, let me know if this info helps.
Feb 23, 2010 | Dishwashers
Display screen says E3 F2. What does this mean?
The F2 on whirlpool ranges means the oven temperature sensor is defective, you`ll need to replace it.
**Disconnect any power to the unit before attempting any self service please**
The part number is 8053344 and retail's for approx. $30-$40US.
It should look like this just so you know, and with an ohm meter should measure approx. 1100ohms at room temp.2677baf.jpg Hope that helps, let me know please. Good luck.
macmarkus :)
Nov 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Open Questions:
Kitchen Ranges Logo
80 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
