I tried to remove the password that appears when I boot up my computer. I went into the bios to do this and when I restarted the computer it still asked for a password but my previous one no longer worked. I don't know how to get the password
  • 35 Answers
If you forgot the system password it is hard to retrieve it. The best thing you can do is to clear the cmos and reset it to factory default.
There is a clear cmos jumper pins on your motherboard (usually located beside the battery). In older versions of motherboards, these are 3 pins but in newer versions there are only 2 pins. In the older versions of motherboards, the 2 pins have a jumper cap during normal operation, pins 1 and 2 are shorted (number 2 pin being in the center). In order for you to clear the cmos, all you have to do is short pin 2 and 3 for a few seconds using the same jumper cap or by using a screwdriver. After shorting the 2 pins, return the jumper cap to its original position.
In new motherboards, all you have to do is short the 2 pins for a few seconds. In normal operation, these 2 pins are open.
Please turn off your computer and unplug the power cord before clearing the cmos values.
Posted on Sep 09, 2010
I have a main Password set on the labtop and i cant reset it without the password. How can i reset it?
Dear Friend,
If you are referring to the Bios Password, removed the battery and push down the power button for about 30 to 60 seconds to reset it (this apply to major brands). If it does not work, you might have to open apart and removed the bios battery for about 5 seconds.
Now, if you are referring to the Windows Password, there are many software that can help you to achieved this (Google it). Normally, in Windows XP you press down the following key combination: Crtl + Alt and press the Del button twice (during log on screen) this will bring the Log on to Windows screen where Username can be try as Administrator with no password, allowing you to get inside and change your password.
Good Luck!!!
Feb 20, 2011 | Compaq Presario R3000 Notebook
Tip
How to Boot From A Windows 7 Password Reset Disk?
<span>Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk with<b><a href="http://www.passwordunlocker.com/knowledge/windows-7-password-reset.html">Windows 7 password reset</a></b><span> </span>software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.<br />Of course, firstly , you need to create a<span> </span><a href="http://www.passwordunlocker.com/knowledge/create-win-7-password-reset-disk.html">Windows 7 password reset disk</a>, and then pay attention on how to boot from the Windows password reset disk .<br /> Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:<br /> <ul> <li>1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.</li><b>Note</b>: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys <li>2. Use arrows to choose Boot on the taskbar, select<b><span> </span>Boot Device Priority</b><span> </span>and press Enter.</li> <li>3. Set<span> </span><b>CD ROM</b><span> </span>to the first boot device according to the prompts on the right.</li> <li>4. Press<b><span> </span>F10<span> </span></b>to save and exit BIOS. You computer will restart with the changed BIOS settings</li></ul><br /> Method Two <p>If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:<br /> <ul> <li>1. Insert a Windows 7 password recovery CD in your locked computer.</li> <li>2. Start the locked computer and immediately tap and keep tapping<b><span> </span>F8</b>,<span> </span><b>ESC</b><span> </span>or other keys until the Boot Menu screen appears.</li> <li>3. Select<span> </span><b>CD ROM</b><span> </span>as the first boot device and press Enter. After that, your computer will restart with changed bios settings.</li></ul>PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.<br />By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take<span> </span><b>Windows Password Unlocker<span> </span></b>for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.<br /><b>Step 1:</b><span> </span>Download and install<span> </span><b><a href="http://www.passwordunlocker.com/windows-password-recovery.html">Windows Password Unlocker Professional</a></b><span> </span>in any availble PC<br /><b>Step 2:</b><span> </span>Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.<br /><b>Step 3:</b><span> </span>Boot from the burned the Password Recovery CD/DVD or USB flash drive.<br /><b>Step 4:</b><span> </span>Reset Windows 7 password under Windows PE.<br /></span>
on Mar 23, 2011 | Computers & Internet
Can't unlock My Essentials 1TB Hard Drive Asking for password and I don't have it.
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 26, 2011 | Western Digital My Book Essential Edition...
I forgot my password to unlocking my WD external hard drive 2 TB? How can I unlock it without loosing all my data saved?
Jan 26, 2011 | Western Digital Elements 2 TB USB 2.0...
I forget my password in u3 what can i do??????
Jan 25, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I have a Phillips PC i bought in 2006 and around a year or so i rebooted to its original state and consequently I forgot the password to the only user account. SInce then I have rarely used the PC and...
Jan 17, 2011 | Philips Computers & Internet
I forget the hdd password
Jan 15, 2011 | Computers & Internet
COMPUTER WANTS PASSWORD, THERE ISN'T ONE
It might be worth having a quick look here first:
http://www.laptop-repair.info/toshiba_bios_password.html
Resetting a Toshiba BIOS Password KeyDisk will reset the BIOS password on Toshiba laptops.
Keydisk - http://www.cgsecurity.org/keydisk.exe
** I have downloaded this file myself from the link above and scanned it with microsoft one care, it came up clean **
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
May 13, 2009 | Toshiba Satellite® A135-S2266 PC Notebook
Toshiba Tecra A8 EZ8512 Bios problem
Good day to you.
I have a toshiba Laptop with Bios Password problem. I cannot start my system anymore, cos the laptop is requesting for Bios password which I dont know or have.
Oct 25, 2008 | Toshiba Tecra A8-EZ8311 Notebook
Bios flashing.
you download the iflash utility from your manufacture website & you must burn it in cd & then you must insert the cd that s all your bios will get unlocked .....
http://www.softpedia.com/get/Security/Decrypting-Decoding/CmosPwd.shtml
download & break the password with this software ..
easiest method you can do this from the windows also if you didnt enter the boot password for your bios ....
follow the extra instructions in that link :
that s it it very easy to break if you are able to run the windows ...
any doubts reply me
i am always here to assist you
thank you
bye
dont forget to rate my solution
Jul 04, 2008 | Acer Computers & Internet
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
