Question about Dishwashers
Water is'nt draining - Dishwashers
  • Dishwashers Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Sep 07, 2010
I HAVE A FRIGIDAIRE, Mo#FRT18IL6JB3, WATER IS COMING INTO THE BOTTOM OF FRIDGE AND NT TO THE DRAIN PAN, I CLEANED THE DRAIN HOSE AND IT STILL IS NOT DRAINING, Thanks Dave
Your make up water solenoid valve is leaking by its seat and needs to be replaced. You should be able to find the replacement on searspartsdirect.com.
Sep 28, 2014 | Frigidaire Refrigerators
I have to replace my well pressure switch alot
Replace with a heavier duty switch. Make sure expantion air tank has air and nt water in it. If water logged drain and repressurize it.
Feb 10, 2014 | Plumbing
Carrier 38TZA036320 evaporator coil
Hello, sounds like a blocked drain line or cracked condensate pan. Try cleaning the drain line first with a wet/dry vac at the outlet of the 3/4 inch pvc line, if this does not help you will need to have the drain pan repaired or replaced.
Jul 04, 2012 | Heating & Cooling
How to change cool'nt in a VE commodore holden
to change the coolant in any engine you need to firstly remove the bottom radiator hose when the engine is cold not when the engine is hot and drain the whole system.
You then need to get some coolant from your local supplier and it will tell you on the container the proper ratio of water to cool it. Once you have put to cool it in top up the system with clean water.Regards
Feb 19, 2012 | Cars & Trucks
My dishwasher does'nt drain, how can I fix that?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 08, 2011 | KitchenAid 24 in. KUDP01IL - Multiple...
Had water in fuel light come on.I followed the service manual and drained water from bottom filter. Truck ran for a few miles and light came on again. I drained it two more times with the same result,...
Try using a can of seafoam with your diesel fuel if there is any water in it this will take care of it.Get your fuel at another station just in case they did'nt change their filters like they're suppose to.
May 17, 2011 | Ford F-350 Cars & Trucks
The machine do not complet the cicle.in the regular cicle, the machine finnish washing but do nt let out the water and the cicle stop at this point
have a look and see if outlet pipe is kinked not allowing water to drain, failing this you may have a blockage in the pump system
Dec 17, 2009 | Washing Machines
Water not draining
take the cover off the inside off the dishwasher and remove the food scraps and roate the wire around and even use the palm of your hand as a plunger
Jun 22, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
Water coming out of the drawer
Sorry I do not have an answer for you...I have got a similar problem. Just before spinning water pours out of the dispenser drawer. Checked water pressure, drain holes etc seems ok. If you do get an answer would appreciate you letting me know. Thanks
Oct 18, 2006 | Hotpoint Aquarius WD640 Front Load...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
