Question about Garden
Looking for a Manual to a GE motor 1 HP 115/230V Model 5KC38PN2534CX for a pool pump
  • 848 Answers
SOURCE: A/C fan motor burnt; I replaced it, and it will not keep runing very long.
It sounds like you'll probably need a capacitor .......
Posted on Jul 22, 2008
  • 89 Answers
SOURCE: Pool pump motor wiring issue
IF THE SCREW ABOVE IS IN THE METAL MOTOR HOUSING IT IS MOST LIKELY THE GROUND. GREEN WIRES ARE ASSOCIATED WITH GROUND IN ALL ELECTRICAL APPLICATIONS. YOU SHOULD BE SAFE IN HOOKING THE GREEN TO THE SCREW. HOPE THIS HELPS, JODY
Posted on Apr 12, 2009
  • 177 Answers
SOURCE: air in my jacuzzi pool pump
It sounds like air is entering the system through the clear dome (filter access) on the pump. Check the o-ring directly underneath the clear plastic dome. CAUTION: Be sure to isolate the pool from the pump via in-line shutoffs prior to loosening the dome lid. Sometime cleaning the o-ring and coating it with petroleum jelly helps the unit seal better.
Posted on Aug 03, 2009
  • 548 Answers
SOURCE: Pump is making "harsh" motor noise.
if its a grinding noise you hear it may be that the bearings have gone bad or it may be an armature problem either way it needs a rebuild or a new pump and you shoul;d call sears to ask of which may be cheaper
Posted on Aug 26, 2009
Testimonial: "Thanks for your quick reply and comment."
miket756
  • 2702 Answers
SOURCE: Hayward Self-Priming Pump with AO Smith 1 HP 56J
the pump must not have any air leaks in the suction side of it,, or it will just **** air and not water,,, water is very heavy you see, however i think its the impeller in the pump thats the problem,,,you should try to put water in the out let of the pump so you fill the pump with water first if its dryed out it may just wear out the impeller before it starts to **** water up, if this still dont work turn off the stop **** and strip out the pump to look at the impeller any wear on it and it will need a new one fitted
i hope this has help you, good luck
Posted on Nov 20, 2009
Will emerson T63AVDDC-1656 motor replace a JANDY FLOPRO 1 HP MEDIUM HEAD SWIMMING POOL PUMP FHPM1.0 115/230v SINGLE SPEED? Thanks!
what you are looking for is a 1 hp square flange motor, and yes that one will work, as long is it the same hp as the origanal moto that came on the pump ! you might consider having the old motor rebuilt, search your area for your local pool pump motor repair guy to insure that it gets done right.
Dec 21, 2014 | Jandy Pool & Spa
Looking for the h.p. of my pool pump.
There should be a label on the motor and should look something like this.. There, you will find the horsepower of the motor... H.P. 1/4, 1/2, 3/4, or 1?????
Aug 10, 2011 | Intex Automatic Salt Water System for ...
What spa pump replaces the Sta Rite model # K48M5A3
That model number you gave is the motor model number. I can however tell you that motor is a 1.5hp motor. So if your just looking to replace the motor make sure you get a 1.5 hp, with the same service factor as the old one. If your looking to replace the whole pump, then technically any 1.5 horse pump will be fine, but there are several factors you should consider. For example if your running popups, or water features, you want a medium or high head pump. There are many different makes and models of pumps out there, so you have many choices. without knowing your application, hard to recommend a replacement. Also depending on your local, suppliers in different parts of the country will carry different equipment. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 13, 2010 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I HAVE A HAYWARD SUPER PUMP SELF PRIMING MODEL : C48L2N134B1 1 1/2 HP 115/230 VOLTS IT IS BROKEN AND I WANT TO KNOW WHAT MODEL I SHOULD BE BUYING TO REPLACE IT WITH. THE MODEL NUMBERS ARE DIFFERENT...
What is broken in your motor? Don't count it out until you have your pool place give it a check. If it is dead, get a 1 1/2 Hayward Super Pump just like the one you have.
Thanks for your interest in FixYa.com
Aug 11, 2010 | Hayward Super Pump 1 1/2 - Hp for In...
How do you get the impella of a jacuzzi lr swimming pool pump
looking at he face of the impeller turn counter clockwise, with a large set of CHANNELLOCK 20" Pliers Channel Lock Model 480 cost about $70.00 there is a notch on the back of the motor shaft for ether a 1/2 or 7/16 open end wrench to fit in to hold the rotor from turning. warning ! these pumps are hard to find parts for so you want to have the right tool so you don't break anything. your best bet is to bring it to your local pool pump motor repair guy and have him do it, if its just the seal you are trying to replace it should be a $20 job
if'n i was any help vote ... thanks ..jay .. and prime the pump after a repair !
Jun 08, 2010 | Jacuzzi MAGNUM POOL PUMP 1-1/2 HP MAGNUM...
How many horsepower does the krystal clear model 635 pool filter pump have
IF YOU PLAN TO REPLACE THIS PUMP , LOOK FOR A HAYWARD 1/2 HP SUPER PUMP. THERE CHEAP AND TUFF . USE YOUR OLD FILTER.. THAT MOTOR IS AROUND A 1/2 .. LOOK AT THE AMPS IT USES, ITS ON THE MOTOR . SAY 15 AMPS IS A 1HP AT 115 VOLTS
May 25, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Can you tell me what kind of torque a 1 1/8 hp 115 ac ge motor has?
Thank you for posting your question here on Fixya.com.
Not a GE but the numbers should be very close...
Load (% of horsepower) Torque (OZ-FT)
0.25 7.0
0.5 12.0
0.75 18.0
1.0 24.2
1.25 36.6
I believe what you meant was that you have a 2 speed, 1 HP high, 1/8 HP low motor…these numbers are for the high speed.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Mar 13, 2010 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Looking for a diagram on a hayward pool pump electrical wiring model super 11
What specifically are you looking for (beside the fact you asked for a diagram)?
It should be setup for 220 Volts ... the only thing inside is a start cap.
Can you tell me more? I maintain 5 2 and 1 1.5 hp such pumps.
Oct 14, 2009 | Hayward Super Pump 1 1/2 - Hp for In...
Pump is making "harsh" motor noise. Is there any maintenance I can do to help it or is it just going bad? Pump is a Craftwman 1 1/2 HP - Self-Priming Model 390 262901 code 1G04F - Motor model C48M2A14
Aug 26, 2009 | Craftsman 1 - 1/2 Hp Pool Filter Pump
Garden Logo
282 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
