Question about Acer Aspire 4315 Notebook
My acer 4315 isnt seeing cd rom - Acer Aspire 4315 Notebook
    Guru:
  • Acer Master
  • 468 Answers
It happens when the Software that is not Windows Vista capable (such as printer software, CD burning software, and games) may have modified the registry to cause the optical drive to not function.
Please follow the steps below:
1.From the Windows Vista default Start menu, point to All Programs, Accessories, and then clickRun.
2.In the Run dialog box, type: Regedit. Click OK.
3.In the User Account Control dialog box, click Continue.
4.In the Registry Editor window, locate and then click to select the following registry subkey:HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
5.From the File menu, click Export.
6.In the File name dialog box, type: Savedkey, and then click Save.
7.Click the REG_MULTI_SZ data type UpperFilters file, and then from the Edit menu, clickDelete. When you are prompted to confirm the deletion, click Yes.
8.Click the REG_MULTI_SZ data type LowerFilters file, and then from the Edit menu, clickDelete. When you are prompted to confirm the deletion, click Yes.
9.In the Registry Editor window, from the File menu, click Exit.
10.Shut down Windows® and restart the computer.
Thanks and regards,
Anil.B.R
Posted on Sep 07, 2010
Cd/DVD ROM Isnt working properly what can I do on a Acer Aspire 4315
you have not stated the problem could be registry if you cant see your cd/dvd rom drives
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark? ! or a red x right click you will need to update the driver or
hope this helps you
Sep 24, 2011 | Computers & Internet
How to reformat my computer Acer Aspire 4315? with cd or someother way
insert the bootable disk into your cd ROM.Restart the Laptop and goto your bios setup to change the first boot to CD/DVD ROM.save it and exit.it will ask you to press any key to boot from CD/DVD ROM.press and follow the wizard instruction
Feb 06, 2011 | Acer Aspire 4315 Notebook
Bios password to boot cd
Try holding your F12 button down while booting to bring you to the Boot Order Option Screen. choose CD Rom press enter.
Feb 28, 2010 | Acer Aspire 4315 Notebook
How do I use the CD that came with my ACER aspire to download microsoft word when the laptop doesnt come with a CD player?
Find a friend with a computer that does have a CD-ROM, and a USB port. Purchase a USB memory-stick that has at least 1GB of memory.
Get your friend to copy all the files from the CD-ROM to the memory-stick, including any "hidden" files.
Then, put the USB memory-stick into your computer, and install the software.
Oct 26, 2009 | Acer Aspire 4315 Notebook
I have acer 4315 laptop and the cd rom is not working, the code 39 (device driver) is corrupted. how can i solve this, pls help me. thank you.
Hi!
I'm happy to inform you that I have already solved my problem with the assistance of acer support. I just wanna say thank you for your time. With regards to what solution I have done, I only deleted the "upper and lower filters".
More power!
best regards,
Apr 18, 2009 | Acer Aspire 4315 Notebook
I delated my cd and dvd drive how do i fix it?
ok u have a fix the cd rom in cpu and fit the power cable and IDE cable in the cd rom for both side in cd rom and mother board.. after that your cd rom working ok
Apr 06, 2009 | Acer Aspire 4315 Notebook
Acer aspire 4315 recovery cd file...
all you need to do is go to Acer Empowering Technology (the e on the left side of keyboard) and then go to Acer Recovery Management
Dec 26, 2008 | Acer Aspire 4315 Notebook
CD rom can't read CD XP
yes i think the cd rom is the problem ,use external cd drive for the re installation or you can use a flash disc
Jul 12, 2008 | Acer Aspire 4315 Notebook
Cd rom
Hiya
Look very closely at the CD drawer - you will see a really tiny hole. Push a paperclip or something similar into the hole and it should release the tray.
Apr 22, 2008 | Acer Aspire 4315 Notebook
Acer Aspire 4315 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
