Question about Amana Refrigerators
I just moved into an apartment that has a side by side amana 22 refrigerator in it. The freezer section is fine everything is frozen and the tempeture is where it should be. The fridge side however, is having some majort tempature fluctuations. THe top half of the fridge side is barely warm and the butter that is in the tray on the door is very soft, but when I pulled a bunch of parsley from the crisper drawer today it was frozen. Can you tell me what might be going on with out fridge.
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Sep 07, 2010
Freezer door not sealing at bottom right side
if you removed the inner section of the door for the drying process then it is possible that the door has warped and you have locked it in that shape on installation of the inner section
loosen off the screws and twist the door so that it touches all the way around , then retension the screws
make adjustments at the hinges after that
Jul 09, 2017 | Amana SXD524VW Side by Side Refrigerator
Everything in the refridgerator is frozen,
Can you hear the refrigerator cycling on and off or is it running continiously? It it is not cycling the cold control/thermostat is defective.
Oct 08, 2012 | Amana AFI2538AEB (256 cu ft) Bottom...
Our refrigerator is not cooling at all. The freezer is working fine, but no cool air is getting to the refrigerator section. A couple of weeks ago, this problem happened after the freezer had started...
Some fridges only cool the freezer and an evaporator fan motor moves cool air from the freezer to the fridge side. If this fan doesn't spin very freely then it may need to be replaced. You should also pull out the fridge and see where the drain hose is connected to the inside of the fridge, try pouring hot water down the hose to see if it is open. It may be clogged with a pea or some food or frozen. If your fridge is really full, make sure there is nothing in front of where the evaporator fan blows air into the fridge. Make sure that the adjuster flap is open in the fridge section.
Oct 31, 2009 | Refrigerators
Amana model SXD25QA3W. Not cooling. Compressor runs.
Low on refrigerant which is R 12. EPA has stopped the manufacture of it and it is priced out of sight.
You have a leak and will need it fixed. Compressor is about $300-400 list. You don't want to go there.
Good luck but likely 15-17 years old....... New one ???
Aug 17, 2009 | Amana SXD524VW Side by Side Refrigerator
Compressor working but Fridge and Freezer not cooling - Amana
It sounds like the same problem my brother is having with his. I took it apart and found that the fan that moves all the air for cooling is not working. This fan is behind the bottom panel in the freezer side, and sorry you do have to take everything out to get to it.
May 11, 2009 | Amana ARS266ZBS Side by Side Refrigerator
Amana side by freezer fan frozen will not run
Fan not operating could be caused by the excess frost buildup in the freezer coil. Defrost problems are related to a failure of the timer, heater, or defrost thermostat. Locate the timer and rotate the clutch head screw clockwise until you hear one audible click. That puts the system into defrost mode. If the system restarts after 18-22 minutes your problem is in the heater circuit. Heater and defrost thermostat is located behind the back wall of the freezer section.
Jun 29, 2008 | Amana ACD2232HR Side by Side Refrigerator
Water stopped dispensing, still makes ice
Yes Teri, you can.
What has most likely stopped the water is that it has frozen in the line coming into the back of the freezer section. You simply need to turn the box off and do a good cleaning. during the time that the box is off, the water line will have time to thaw. Put everything back together, turn the box back on and give it a try.
May 25, 2008 | Amana SXD524VW Side by Side Refrigerator
SZD27MW - Freezer Fan not working - temp runs 40 midway in freezer
Voltage is either 240V or 110V either way it is stamped on the fan motor. You have a sensor controlling the fan and heater which could have gone open circuit and on some cabinets they use the neutral through the heater to bring in the fan so you could have a heater gone. You can bypass the sensor but this should not be a long term solution as it is a safety mechanism. Hope this helps.
May 26, 2007 | Amana ASD2326HE Side by Side Refrigerator
Freezer cool, but Frig section is not cool
Volman, take a look in the freezer section and see if you have a heavy build-up of frost on the back panel. You want to take the evap cover off and see if the evaporator is frozen up. If so, your refer did not go into defrost and cannot move the air over to the refer side. If this is the case you will have to defrost that evaporator completely. On these Amanas the culprit is usually the bi-metal which sits on the evaporator. Look at it and see if it's buldged. The part number for the bi-metal is ro131661. If you defrost the evap your refer will start cooling again normally until it freezes over again. This will give you time to replace the bimetal....Catriver...post back.
Aug 21, 2006 | Amana ARS9266BS Side by Side Refrigerator
Refrigerators Logo
70 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
