Question about Sony VAIO VGN-NR185ET Notebook PC - Wenge PC Notebook
Touch pad How do I turn off the touch pad so I don't hit it by accident?
Go to "Control Panel" go to "VAIO Central" go to "Keyboard and Mouse" go to "Built-in Pointing Device" double click "Built-in Pointing Device" uncheck box "enable/disable touch pad" VOILA!
Posted on May 23, 2009
  • 37 Answers
During startup press F2 and you will enter the bios setup utility. There you can change the optio of touc pad to off.
Be carefull while changing anything in the bios setup utility.
Posted on May 13, 2008
Touch pad not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Acer Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 04, 2012 | Computers & Internet
I have accidently turned off my lower keys on the touch pad of my Dell latitude d420.Please advise.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
May 27, 2012 | Dell Computers & Internet
I was just working on my laptop using my touchpad mouse. I'm sure I accidently hit a button but I didn't think I did. Well anyways, the pointer stopped responding and the orange light in the top...
many touch pads have a switch that you can toggle on and off to turn the touchpad on and off. It is usually in the immediate area of the touch pad.
May 11, 2011 | Computers & Internet
My Emachines E625's touchpad has stopped working. What can I do?
it stopped working how.. its not powering at all? if yes, try to remove battery, put in power adapter and try to power it. if it powers, plug in battery while machine is on.
May 04, 2011 | Acer Aspire 3000 Notebook
Touch pad doesn't work
Determine What's Wrong
laptop'smag-glass_10x10.gif touch pad basically provides the functionality of a mouse for a desktop PC, typically with two buttons located just below it acting as the left and right click buttons on a desktop computer. A touch pad may be damaged by excessive use or foreign substances such as water, dirt or food items.
Hit the "Windows" button on the keyboard and then use the right-left keys (or hit 'C') to open "Control Panel." From there, again use the right-left keys to get to "Mouse" and then hit "Return."
Use the right-left keys to toggle between the tabs and open each to investigate whether any boxes had been improperly clicked by accident that cause the touch pad to become unresponsive. But if any of these steps fail to remedy the problem, then the touch pad may need to be repaired or replaced.
Repairing/Replacing TouchpadA touch pad assembly cost $100 or more and that's not including replacement installation. Hiring a specialist to replace a damaged touch pad, including parts and labor, may easily cost $200. Unless the laptop in question is worth well over $1,000 and the touch pad is deemed a necessity, such repairs are rarely worth the cost.
Attempting to replace the touch pad without certain expertise in laptop assembly may be dangerous and/or destructive. Also, getting a replacement part that's not compatible with the laptop may have catastrophic results, including irreversible damage to the laptop.So just attach a mouse to it so you can work easily.Please rate me if this solution works for you
Thanks......Have a great time.
Jul 28, 2010 | Computers & Internet
Touch Pad and mouse buttons
try it with toggle keys it may be work
May 03, 2017 | Sony VAIO VGN-N130G/W Notebook
While I type, often the cursor moves to the poit where the mouse icon is locatde, as if the touchpad has been pressed.
yeah you have touch sensitivity set to high in the touch pad and your wrist is hitting the touch pad. go your touch pad settings in the control panel and turn it down til when your wrist brushes it, it doesn't move the mouse.
Mar 23, 2010 | Dell F3534 Touchpad
Acer aspire 5517 touch pad not working.
Also on this laptop you can hit Fn+F6 to enable or disable the touchpad as well there should be a touchpad disable button to the right of the power button that can be very easy to accidentally press.
Mar 15, 2010 | Acer Aspire 5315 Notebook
Coby mp3 player touchscreen wont work
to fix this problem go bak to calibrate and the screen will go blue and in the corners you will see a cross hit the crosses in order in 3 sec or less and the mp3 will go back to touch screen! if it works let me knoow via email gaudettemichael3@gmail.com
Dec 25, 2009 | Audio Players & Recorders
Touch pad not responding
Try resetting ur phone by holding the red and green buttons while hitting the reset button on the bottom with the stylus. All the information u have saved in ur phone will be lost but it will work afterwards.
Jul 07, 2008 | HTC Touch Cell Phone (Unlocked) - Soft...
Sony VAIO VGN-NR185ET Notebook PC - Wenge PC Notebook Logo
323 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
