Question about Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm
Just bought a used legend and it seems to be In good shape. It needed a new bag. Bought one today and began using it. It picks up fine but after a little while it ends up o it's side and stays there. Any ideas how to keep it rolling?
  • 990 Answers
Their should be a ballist weight inside the unit in the bottom. Be sure that is in place. Then check all the floats and be sure they don't have any water in them. Also make sure your hose leingth are correct.
Posted on Sep 07, 2010
We just bought a GE dishwasher today and it seems like the cycle never ends.We have silt in our water, can this affect the autosense?
Mine use to go forever because my water wasn't hot enough. The dishwasher would heat the water up to a higher temperature before it began to wash the dishes.
Feb 24, 2015 | GE Dishwashers
With vacuum on but not using, motor began to load up--whine began to rise--then sudden free flow and terrible smell emitted...thought the bag had failed and a shot of dog hair and dust reached the motor,...
This sounds like your motor going. If it winds up then down it could need new motor brushes or a new motor. Also, if the smell is kind of rubbery it could simply be the powere nozzle belt. Hope this helps, Chris
Feb 21, 2011 | Kenmore 27514 Bagged Canister Vacuum
It wont pick up with a new bag in and it seems to **** back in
Check if there is something stuck in the the suction tube, telescopic wand or in any of the parts involved. I had the same problem due to a number of chocolate wrappers stuck in the wand. I almost went and bought another one, luckily i had the sense to ask the salesman at sears the same question and he put me on the right path. The suction tube and wand are detachable from the unit, so you should be able to unplug the parts and check. This is the same solution if you motor is running fine but you have lost suction and\or bag shows full when it is not. Hope i am saving someone some money by stating the obvious here, just the way the sears salesman helped me.
Nov 07, 2009 | Kenmore Magic Blue 24195 Bagged Canister...
Vacuum doesn't ****
Assuming the unit (motor) runs ok and since it used, you may need to disassemble it and check the suction right at the motor. Sometimes there is a filter screen in front of it that can plug. The motor impeller could be partially obstructed or dirty, reducing the vacuum force. The bag should be the correct one for the unit or suction can be lost if it doesn't fit correctly.
Mar 28, 2009 | Kenmore 23612 Progressive PowerMate Bagged...
Etrex legend has stopped picking up satalites.
I have had this problem occasionally and if you use Restore Defaults it appears to fix it. Using the front button go to Main Menu, Setup, System, move left and press the button button. Before I did this I just used to leave it a few weeks and it would suddenly be working again.
HTH
Peter
Mar 04, 2009 | Garmin eTrex Legend Cx GPS Receiver
Just Bought Today ;(
The problem is probably not the throwout bearing. Noise from throwout bearings act just the opposite, you only hear them when you push in the clutch pedal. Noise when the clutch pedal is released only is either a bad pilot bearing (probably oilite bushing) (the bearing/bushing in the middle of the flywheel that supports the transmission input shaft), or bad transmission bearings (will happen sometimes but is unlikely because in neutral, with the clutch pedal released, tranny bearings spin, but are not really under any load, but in some cases they might be the cause of the noise anyway)
Aug 28, 2008 | 1993 Acura Legend
I bought a Hoover Wind Tunnel in January 2008. At first it worked great though very noisy. Now it will not pick up small fuzz on medium shag carpeting. I have checked the bag, the filter, the belt, and...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=563001
Generic problem for all Vacuums
posted by smithcarolj1 on May 01, 2008
I bought a Hoover Wind Tunnel in January 2008. At first it worked great though very noisy. Now it will not pick up small fuzz on medium shag carpeting. I have checked the bag, the filter, the belt, and obstructions and there are none. Plus the noise level has increased. What is wrong?
I am very dissatisfied.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Sorry you are having a problem, using the Hoover Windtunnel is a very good vacuum. Reading youre description, the belt is one of the main reasons you are not picking up the small fuzz on a medium shag carpeting. The belt change on the average , if you have one or 2 belts should be changed every 4 to 6 months as a rule, and the brushes need to be in good shape as well, if those two are working well you may have a bad seal on the motor or a broken fan blade(s) and that would decrease suction and you would need to replace the fan. Also check the gaskets if they are broken or damaged or pinched and letting air through the suction will leak out. These are some of the items to check for, so feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
Not seen by pc
You would have to use irivers manager software, or change the firmware so Windows can see it.
Feb 18, 2008 | iRiver iFP-790 MP3 Player
Short Battery Life
just today figured out that the battery supposed to be at least 17 hours and i bought it before 2 years too and even when i bought it was my battery left only for 2 hours and until today i thought it is supposed to be like that.
Jan 10, 2008 | Sony NW-A1000 MP3 Player
ABOUT THE CX8400 EPSON WHAT IS MY PROBLEM I NEED HELP
Same problem. just bought the cx8400 today. I'm running the imac 10.5. It's feeding endless amounts of paper and can't cancel the job. Please let me know if you've found a solution. NO FRIGGEN PAGE SET UP option.!!!!
Dec 13, 2007 | Epson CX8400 All-In-One InkJet Printer
Pentair White/Gray Legend Platinum Automatic Pool Cleaner - Ll105pm Logo
82 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
