Question about Garmin GPS
I have unplugged my Garmin, which I just purchased two days ago, and turned it off, but it doesn't go off, just stays at "Loading maps". What do I do
  • 3,083 Answers
Take it back for an exchange. Looks like a firmware/software problem, but could be a hardware fault, also. If you run it by a Car Audio Installation facility, they can usually tell you what's going on, and whether there's a simple fix or not.
Myself, I don't trust things that don't work out of the box. Sometimes, in the case of complex devices, it's a setting, but these devices should power up and load, and turn off when you want them to.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 07, 2010
My garmin nuvi 255w keeps freezing up at loading maps screen...i have tried the hard reset but that doesn't work, when i push on the bottom right corner and start the gps, it doesn't even make it...
There is a hard reset button under the sticker at the bottom of the unit. It is located directly under the check mark on the sticker. Once you get it going fully charge the unit then go to the Garmin website and register and update your 255w. I will attach the link to the Garmin Site. Thanks for using FixYa
https://my.garmin.com/mygarmin/registrationGettingStarted.htm?productType=auto&categoryType=AUTO
May 29, 2011 | Garmin nuvi 255W GPS Receiver
Garmin 265w i turn it on and it stays on the screen that says loading maps did the 15 sec reset same HELP!!
you have same maps on sd card and on garmin internal memory and garmin became confused when you turn it on
Dec 16, 2010 | Garmin nuvi 265 Car GPS Receiver
When It is turned on, it stays stuck loading maps. what is wrong with it?
http://www.garmin.com/garmin/cms/site/us/support/searchsupport?search_key=STAYS ON LOADING MAPS
Oct 23, 2010 | Garmin nuvi 1200 Car GPS Receiver
Garmin 1300 stuck on maps loading frozen I have a GARMIN nuvi 1300, running off a car cigarette lighter type charger, it was working fine for weeks, I got in the car, started it up and the nuvi is STUCK on...
I had the same problem with a 1300 unit and a car charger. After holding power button for 10 seconds it would begin to start, but get stuck while saying "Loading Maps." and then it would shut off again.
I fixed it by plugging the unit into a computer USB port. It then did it's PC connection startup as usual, which leaves a connection icon on the screen. I gave it a minute and then unplugged it from the PC. It then restarted and booted up properly.
Hope this helps.
Apr 10, 2010 | Garmin nuvi 1300 Car GPS Receiver
Garmin Nuvi 1250 stuckin "loading maps" screen
I just plugged my 1350 in (had exact same problem) into computer and deleted the GPX (trip log) and it finally started back up. Deleted all of the favorites and such but it working again.
Feb 05, 2010 | Garmin nuvi 250W GPS Receiver
255w in a loop - loading maps, then restarts...can't recharge
Use a USB connection to your computer and let it charge for three hours. Also download updates while your at it. Cigarette lighter charger is not efficient
Dec 20, 2008 | Garmin nuvi 255W GPS Receiver
I have a Garmin 350 that won't load maps and stays frozen what can I do to fix problem
Have you tried a software upgrade. Talk to Garmin, they were pretty helpful when I talked to them.
Oct 07, 2008 | Garmin nuvi 350 GPS Receiver
SHUTDOWN
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Jul 12, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin is stuck at loading maps
I had a 200 W Nuvi with the same problem. Luckily it happened with the first 3 months, so i could return it to Garmin under warranty for a free replacement
Jun 17, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Map loading
Nope, the data will stay there, you just insert the SD card, use the wrench symbol/select map/select about/ tick the Australia map on/the usa map off/ and you're garmin just went Aussie.
Apr 23, 2008 | Garmin nuvi 350 GPS Receiver
GPS Logo
12 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
