Water on the floor after washing with the frididair gallery front load machine- bolts keep coming loose had a repair guy in a year ago and the problem is back????/ We have a lemon???/
  • 80 Answers
SOUNDS LIKE THE PUMP OUT HOSE IS LOOSE FROM THE PUMP.IF YOU GET THIS FIXED GO TO A LOCAL A/C SUPPLY STORE THEY SELL 2X2 RUBBER ISOLATORS PUT THEM UNDER THE LEGS AND THE PROBLEM SHOULDNT HAPPEN AGAIN THIS IS CAUSED BY EXCESIVE VIBRATION.GOOD LUCK
Posted on May 13, 2008
Our front load Whirlpool washer is about 9 years old and it leaks water onto the floor every time we use it. Can this be repaired and how costly is it fix?
I have a duet sport whirlpool two years old. The hose from the dispenser to the tub is frayed and broken allegedly due to worn out shocks (after two years?) The repair guy says $289 to fix a hose. Unbelievable! Could it be a design issuue?
Aug 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a frigidaire gallery front load washing machine that I purchased about 4-6 years ago. The softner will not dispense. I have taken the entire dispense unit out and have run hot water over it to try...
Add white vinegar to the dispenser and run a load. If that does not solve the problem take the dispenser out and soak it in a 50:50 white vinegar and water mixture for an hour
Sep 24, 2017 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
What is error 20 on frididaire gallery washer? Clothes just sitting not moving at all?
E20 is not an exact error code. It's indicating a possible pump out problem. Here is a few possible causes of an E20 error code:
1. Restriction in the drain pump
2. Failed pump
3. Water not pumping out fast enough (crimped drain hose)
4. Too many suds ( too much detergent or wrong kind)
5. Pressure switch (not communicating with control board)
6. Loose wire at pressure switch
7. Loose wire at pump or control board
8. Failed control board
Apr 29, 2010 | Frigidaire GLTF2940ES Front Load Washer
Drum keeps filling with water when not in use
Hi, You will need a new water inlet valve. the valve has stuck open just enough to let water trickle in. Until you can repair it, just turn the valve off at the wall. If you have not yet found your answer, let me know and I will assist you in getting part#.
I hope this helps. If so, please rate my answer so I know how I am doing.
May 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Installation after moving/ water not going in
In order to move one of the new front loading machines, the shipping bolts/supports that originally came installed with the unit must be in place to prevent damage. At this point you can attempt to make repairs yourself or, if under warranty, calling a authorized repair center for repairs. The warranty will not cover damage due to moving the machine without the bolts/supports, however having a authorized service center make the repairs will keep the remaining warranty intact.
clarkco
Feb 17, 2009 | Kenmore Elite 45986 Front Load Washer
Frididaire front load washer won't lock
I find that I need to be extra gentle or it won't lock.  Try that.
Jan 05, 2009 | Frigidaire ATF6000ES Front Load Washer
Leaks water
Okay, to check for your source of a leak, start by removing the 2 screws on the lower front panel of the machine. This will let you see inside. As you are running the washer, watch where the water is coming from. If from the front, you may have a hole in your boot (the black rubber up front) If so, you may need to replace the boot (the part comes with step by step instructions). If coming from the middle, your tub seal may be going bad. A quick fix is tighten the 12 or 14 bolts that go all of the way around your tub. This will only be a temporary measure. The tub will have to be taken apart and the seal replaced. (this is a 1 1/2 hour - 2 hour procedure for 2 technicians) If it leaking from the rear, you may have a bad tub bearing. You can remove the back panel to be certain, but usually a bad bearing will be accompanied by a roaring noise durring the spin cycle. As for the dryer leaving brown marks? Usually the front seal has been dammaged. Run your finger around the front of the drum (where it meets the front panel) the gap should be about the same all of the way around. If it is not, you may need a new front seal. (this is much cheaper and less time consuming on the dryer compared to a seal on the washer)
Jun 18, 2008 | Frigidaire GLTF1670A Front Load Washer
Kenmore elite top load about 3 years old
Check the boot for tears, also remove the lower axcess panel (Three torx screws or 7mm) and see where the water is coming from.
Sep 24, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
21 people viewed this question
Top Washing Machines Experts
