Question about Roper REX4634KQ Electric Dryer
Roper Electric Dryer model # rex4634kq2. Dryer wont heat & timer never moves. What should I check first. I do apartment maintenance so I am familiar with water heaters, ac, electrical, etc but washers and dryers I dont know. Please help. Any and all help is greatly appreciated. Thanks Joe
    President:
  • 1,218 Answers
Good day,
The timer will not advance if the heat fails. That's normal.
The most common items to fail are the heating element and a small thermal fuse both of which are located on the back of the machine.
You'll need a VOM meter to check both. The thermal should check out at zero ohms. The leads to the heating element which is located in a canister on the right side should read less then 35 ohms.
The Thermal fuse looks like this.
It's usually one of the 2 but there are other limit tstats in that area that you might want to check.
Here's link on changing the element.
http://www.applianceaid.com/wp_element.html
Make sure you have 230 volts to the machine as well.
Posted on Sep 07, 2010
Our roper dryer does not get hot and does not shut off. The timer does not move.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][
Sep 16, 2011 | Roper Dryers
My roper dryer model rgx5634kq2 wont heat. the glow bar comes on and then goes off, other times the glow bar comes on and there is a flame, the timer only advances for certain cycles as well.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 08, 2011 | Roper RGX4634KQ Gas Dryer
My Roper Electric Dryer is not blowing hot air plus the timer is not moving. What could be causing this?
timer motor(wires burnt or contacts) located in the upper back of dryer. here is a website that tells how to test, it is on the bottom of the list. Good luck Tim:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
Nov 27, 2010 | Roper REX4634KQ Electric Dryer
Roper gas dryer does not heat, timer does not move, runs continuously, can the timer malfunction cause dryer not to heat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | Roper Dryers
Roper dryer timer will not advance and there is no
It wont advance because the heater isnt functioning.
Check to see element reading then temp. thermoststs normally found on heater body.
Jun 06, 2010 | Roper REX4634KQ Electric Dryer
Model WED5300SQ0 not heating and timer not working
Well with moving it around and all it could have any number of things happened. If it wont tumble, no lights, no heat or anything check that the plug has 240volts to it. then check the wiring going into the dryer may have broke wires or anything like that. but I would check the plug first if it has no power what so ever. If you check the plug and it doesn't have power check the breaker to see if it is tripped.
Sep 03, 2009 | Whirlpool LER5636P Electric Dryer
Timer wont advance will not heat
you either have a tripped curcuit breaker or your heating element is blown. If the timer cannot sense that the heater is in the curcuit it will not advance check your curcuit breaker first. flip it on and then off and let me know if you have heat
Jun 02, 2009 | Roper REX3614KW Electric Dryer
Roper Dryer
i have the same dryer it runs but doesnt heat and the timer wont move. its only 3 yrs old
Nov 28, 2007 | Roper REX3614KW Electric Dryer
Roper REX4634KQ Electric Dryer Logo
82 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
