Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
The top thing taht spins to clean from top does not spin
  • Frigidaire Master
  • 43,501 Answers
When my wife started complaining about her dishwasher not getting the top rack clean this is what I found and I wrote a tip about it...
Dishwasher Spray Arms not Spinning
heatman101
Posted on Sep 07, 2010
I have an E1000 error with my Canon MF4320-4350, i've read that its a laser error, how do i get it fixed?
Yes error E100 is the laser alright. The only thing you can do to a laser is clean it and oil it. OIL you say? Well the error does not define what in the laser has gone wrong. Most laser mirrors spin like a spinning top. The shaft sits in an upside down top hat. Usually dust gets in the top hat and slows down the spinning mirror. Strip the laser and remove the spinning mirror. Clean the top hat and shaft and place a very very small oil drop in the top hat (I use model train engine oil as its so lite). It should spin freely by hand. See how it spins before you strip it. If this does not cure the fault and cleaning the mirrors, then a new (expensive) laser is required.
Aug 09, 2011 | Office Equipment & Supplies
Top spin thing not spinning during wash cycle. Wash cycle taking longer than normal.
Have the same problem. Have taken everything apart and cleaned out thoroughly all the way to to the pump, valves, drains, plumbing lines but the top spin atomizer still does not spin. I suspect it has something to do with these two silver balls found in one of horizontal pipes leading to the turbo zone. I couldn't figure out how these balls shift within the compartment and suspect one or both are blocking the flow of water and sacrificing the top spin atomizer since its the furthest away from the pump. Hope to find a solution as to how to lock these in place and allow the free flow of water.
Jan 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Top spray arm won't spin. No clogs. Water runs fine. Arm just won't spin. Will spin freely if I move it
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Nov 18, 2010 | Kenmore Dishwashers
The top cleaning bar will not spin---water is moving through it but it wont spin--the bottom cleaner spins fine---took it apart and there is not blockage in either of the cleaning bars
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
heatman101
vvbn
Mar 24, 2010 | Whirlpool DU1055XTSQ Built-in Dishwasher
Dishes on top shelf not cleaning
heatman101
4w56er
Mar 02, 2010 | KitchenAid 24 in. KUDP01DL Built-in...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I saw the water leaking from a large metal part that spins around. Its behind the motor and...
My Maytag washer model #:sav515deww is leaking underneath during the spin cycle. I took off the 2 front panels. I have been told taht it is a bearing and a seal that are out. Replacement parts cost approx $90.00. Unit is 5 years old. Is it hard to fix? Thanks
Dec 10, 2009 | Maytag SAV515DE Top Load Washer
Whirlpool LSR8233eq top load washer won't spin most of time
Hi, It sounds like your spin basket drive is going bad. Even tho you cleaned the brake, the pads get worn down enough they will not grab. The only other thing I can think of is the bloch that sits on top the basket drive shaft and lockes the inner tub. Sounds like you have done/checked everything else.
Please let me know if I can assist you further.
Vic
Jun 20, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washer will not spin, during rinse & I'm assuming spin cycle
throw pin in trash..shipping pin..spin problem..if motr runs and unit agitates suspect transmission or clutch on top of transmission
Nov 27, 2008 | Roper RAX4233PQ Top Load Washer
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
116 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
