Question about Euro-Pro 1260DX Mechanical Sewing Machine
Need a manuale for threading sewing machine
Need the manual for threading machine up!
  • Gail Whitnall Sep 26, 2008
    The top thread of my singer basic sewing machine does not hold any tension. The top thread makes loops. I have tried all ways of re threading but no use. Even when the tension is turned to 9 the is no tension on the top thread
Give me step by step instructions to thread my machine please and thank you
Posted on Sep 20, 2008
SOURCE: need manual for 11301 barbie sewing machine
1. Attach a spool of thread to the machine with the upper spool pin and spring. When you pull on the thread, it should unwind from the spool counterclockwise. Pull the thread from the spool, through Thread Guide 1. Next, slide it between the two discs of the thread tension dial.
2. Pull the thread through the guides in this order. down through Thread Guide 2, down through the Thread-pulling bar, to the left through Thread Guide 3 and down through Thread Guide 4.
3. Raise the needle using the Handwheel and bring the thread through the eye of the Needle from left to right.
As you go right to left across the top of the machine is the threading pattern and then down through the thread pulling bar ( it moves back and forth across the front of the machine as it runs) and then down the arm to the needle. Use a thread bobbin on the spool pin at the begging of the threading process. This machine does not use spools of thread.
Hope this helps.
Posted on May 30, 2008
  • 323 Answers
SOURCE: how to thread sewing machine
Yes, but it is a good basic machine.
Here's how to thread it:
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} all machines thread the same. TTN tension, take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
Sewman7
Posted on Mar 20, 2009
  • 10 Answers
SOURCE: white 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Manuals for all types of sewing machines can be downloaded from sewingmanualss.com.
Posted on Jul 31, 2008
  • 240 Answers
SOURCE: How do I thread my Singer 7422?
I suggest you do a search on youtube on how to thread a sewing machine and choose a video showing a similar machine as there are really only about 3 basic types of machine as regards the threading.
Some of these instruction videos are very good and you will find it much easier than explanations. However-the important thing is that the thread must go between the tension discs by your tension regulator and do make sure you have a good need le in the machine, inserted correctly.
Posted on Jun 22, 2009
SOURCE: Bernina Bernette 65 sewing machine
I had the same problem. I'm a novice sewer. I just bought my machine. It did the samething, tension didn't work, the thread kept knotting up underneath, and the fabric kept curling up in the back.
I adjusted the tension knobs to no avail. Then it kept bothering me that it was curling up. I then decided to set the dials back to where the factory had them and adjusted the presser foot just a hair counterclockwise and I haven't had anymore problems.
The other day the needle almost broke because the tension was tight on the thread. You have to make sure that the needle is at it's highest point to get it to release the fabric so you have a thread tail.
This is my first purchased machine. I had a New Home years ago that was given to me, however it blew away in the tornado of 1991 in Kansas and I never replaced it. I really do love this machine. I don't believe I will ever want another.
Posted on Nov 11, 2009
Need a Nelco sewing machine mod 4102F manual.
  1. http://www.sewusa.com/index.htm try finding it on this website. maybe you will get lucky.
Jul 30, 2017 | Sewing Machines
I need the manual instru tions for euro-pro x 420
This is where to find what your looking for. http://www.sewingpartsonline.com/euro-pro-sewing-machine-instruction-manuals.aspx
Sep 04, 2016 | Euro-Pro Sewing Machines
I need to wind thread the bobbin for a husqvarna viking 500 computer sewing machine
Download your manual here: http://www.pdfsdocuments.com/husqvarna-viking-500-computer-sewing-machine-manual.pdf
Feb 02, 2016 | Husqvarna Sewing Machines
How do I thread an Elgin Model s1112 sewing machine?
Manual for elgin sewing machine model S1112 - Fixya
www.fixya.com/.../t13703624-manual_elgin_sewing_machine_model_s...
Jul 21, 2012 - I need a manual for an elgin model S1112 sewing machine. Posted by .... the thread stuck when m starting to saw on Elna 120. Jan 22, 2016 ...
Viking engineered 1958 "Elgin 2468" - Introduction - YouTube
? 14:20
https://www.youtube.com/watch?v=xr2ypU4vz1Y
Oct 15, 2012 - Uploaded by CowCountryVintageSewing MachinesAndRestoration
Sewing machine won't pick up bobbin thread ' hook timing fix - Duration: 6:08. ejc1210 387,297 views. 6:08 ...
NICE ELGIN SEWING MACHINE 1.5AMP STRAIGHT ...
? 2:32
https://www.youtube.com/watch?v=HB0nwDN_Fzc
Dec 21, 2010 - Uploaded by NIFTYTHRIFTYGIRL RAYNA MORGAN
NICE ELGIN SEWING MACHINE 1.5AMP STRAIGHT STITCH ... Viking engineered 1958 "Elgin 2468" - Two ...
Elgin sewing machine model s1112 manual - Google Docs
https://docs.google.com/document/.../edit Google Docs, Sheets, and SlidesSewing machine manual elgin sewing machine model s 1112 ebay. Sewing ...Sewing machine manuals and free threading diagrams from sewusa. Sewing ...
Thread: Elgin Sewing Machine - Quilting Board
Jan 24, 2016 | Sewing Machines
I need a manual for a JCPenney Model 6601. Or at least how to thread it.
Back in my 7th grade home ec class (I'm 52 yo now), our teacher told us that all machines thread basically the same and I never forgot that and it has served me well through the years. No matter what brand of machine, or level of machine (from little girls first one, my embroidery or my heavy duty industrial leather machine) they have all threaded the same:
Thread spool
thread guide
thread guide
tension
take up lever
thread guide
thread guide
needle
(the number of thread guides may vary)
Best of luck and happy sewing!
Dec 13, 2014 | Sewing Machines
How do you thread a koyo sewing machine model number k 1201
I found one site willing to let you download a user manual for $10.00
DOWNLOAD Koyo model 1201 sewing machine manual smm526pdf Machines name...
However many machines are much the same. Youtube has video's showing how to thread sewing machines. Maybe one of them is close enough to your machine that it will work.
sewing machine how to thread YouTube
sewing machine tutorial YouTube
Change the search terms for whatever you need.
Sep 21, 2014 | Sewing Machines
Need manual for model 5825c for threading
i was able to find it at www.ifixmachines.com
Oct 18, 2009 | Singer Electronic Sewing Machine
I need a manual for a kenmore sewing machine.
hi there,
manuals for kenmore on internet go to search box type " Kenmore sewing machine manual"or you can shown actual threading,dial tension adjustment etc.,...on www.youtube.com
on search box type "Kenmore sewing machine repair" happy sewing,regards
Jul 05, 2009 | Kenmore Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Euro-Pro 1260DX Mechanical Sewing Machine Logo
231 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
