Question about Uniden Cordless Phone exai398i
Clunking sound in phone
I purchased my phone about seven months ago. One night, I forgot to put the headset back on the base. From then on, there has been a clunking sound on the phone that is obvious to people on both ends and it is there no matter how many channels I try.
I thought about getting a new phone, but my husband's voice is on the answering machine and, since he passed away on January 5 of this year, I would like to keep it there if possible
Thank you for any help you can give me.
Susan
  • susan1336 May 13, 2008
    The answering machine, which is also the base of the phone, is where it has always been. Isn't it a bit odd that there would suddenly be something wrong with the location the day after I left the receiver off the base all night?
  • susan1336 May 14, 2008
    I removed the battery and then put it back in (since you didn't say anything about replacing it, I didn't think you were suggesting that) and, when I turned the phone on, the sound was even worse.
    I DO like the idea of getting another phone and using the same base; I just didn't know if that would work or not - and I REALLY appreciate your suggestion that I record the answering machine message so that I will always have it. That was a very good, and a very sensitive suggestion - and greatly appreciated.
    Sergeant:
    Champion:
  • 256 Answers
Please change position of your phone (answering machine), because of some magnetic field there will be some sound…
Posted on May 13, 2008
  • 3,037 Answers
You could get another of the same phone and use it with the existing answering machine.
One thing to try is to remove the battery from the phone itself, not the answering machine and see if it resets back to normal, if not let me know and I will look further into this.
And I'm sorry to hear about your husband. May I suggest recording that answering machine message so you will never loose it.
  • Benjamin Patri
    Benjamin Patri May 14, 2008
    yes, you can get the same exact phone and use the base you already have which I suggest you do and what you did with the battery is exactly what I suggested. Something just must have broken with the phone. The easiest thing would just be to replace it and be on your way.
    Let me know if you have any further questions, otherwise have a good day
  • Benjamin Patri
    also, please don't forget to rate my solution when you are satisfied
I changed my password 10 months ago to my gmail account a
Go to forgot password and create a new one. You should be able to verify it from there. As long as you know simple things like your first and last name you should be able to get into it!
Sep 17, 2014 | Google Gmail
Clunk sound{ loud} when going over bumps and dips: Especially when turning right, sounds like something under the car is going to break in half! Stabilizer bar came loose a few months ago, and was not put...
The stabilizer bar could be your problem however, since the clunking sound occurs when you go over bumps and dip it sounds to me that your problem is a bad or broken strut or strut mount. I would suggest that you check all of your struts. If a strut does break off it can potentially cause you to loose a tire while driving . I hope this helps you out, and good luck.
Aug 27, 2011 | Ford Escort Cars & Trucks
Static on Telephone Base Unit
Try powercycling the basephone and remove the battery from the cordless phone, wait for 10 sec and then reconnect the battery, after that connect the power to base phone,probably it will fix the issue.if your phone have the option to change the channel,try changing the channel to 11 or 6.try and get it fixed.
Mar 26, 2009 | Panasonic KX-TG1033S Cordless Phone
My lg shine speaker phone dont work
for ther flip phone i just put it to the half point to where it does work and then opened it a little more and put it back a little and then kept doing that untill it was fully open and now it works. =]
Feb 23, 2009 | LG Shine CU720 Cellular Phone
GN Netcom heatset buzz
I had this problem a few months ago, make sure the small wheel on the side is set on A. (if you look closly at the wheel there are very small and hard to see letters on there.) this should get rid of the buzzing.
Jan 28, 2009 | GN Netcom (9120-48) Wireless Headset
Digipower bluetooth headset used with cell phone
I broke my headset and need to send for repair. Where would I send this product. I have the didgpower headset model #HFBLU-HI
Jan 26, 2009 | Radio Communications
No one can hear me when I call out or have a call come in but, I can hear them. This just started a couple of days ago. I've had this bluetooth for several months now
I had the same problem, and my solution was a new phone and/or new bluetooth headset...It was very odd how it started later though...incompatibility.
Jun 25, 2008 | Plantronics - Bluetooth Headset Plus Base...
Connecting headset to phone
Setup the Plantronics CS60 wireless headset as follows:
  • Locate the 2 ports on the bottom of the CS60 charging base. One has an icon of a "full telephone" and the other has an icon of a "hand receiver."
  • Unplug the hand receiver from the base of your existing telephone and plug it into the "hand receiver" port on the CS60 base unit.
  • Then take the short cable that came with the CS60 and plug it into the "full telephone" port on the base of the CS60.
  • Plug the other end of the short cord into the hand receiver port of your telephone (where the hand receiver just was).
  • Make sure the AC Power is plugged into the wall, and then you can adjust the configuration settings.
To be able to hear or speak through the handset, either place the headset back into its charging cradle or press the call control button on the side of the headset. The talk indicator light on the base should go off and no sound will come through the headset.
Note: Make sure that the cables are connected correctly and the handset cable is connected to the base of the CS60 base.
Jun 16, 2008 | Plantronics CS60 Professional Headset
Uniden Cordless Phone exai398i Logo
82 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
