Question about Microwave Ovens
Hi There, I have fridge that does not cool enough, and the freezer is not making ice, I am thinking it needs gas, how can I refill my fridge? where I can buy all I need to do this
  • Microwave Ovens Master
  • 43,501 Answers
Here is a tip that I wrote about how to add refrigerant to a air conditioner or cooling system
How to add Freon to a Air Conditioner or Refrigeration System
heatman101
Posted on Sep 07, 2010
The freezer is working but not the fridge fridge onm top freezer below I think it my be the thermostat
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 09, 2011 | Microwave Ovens
Freezer is cold, but ice is forming on the bottom vent and fridge is warm and water droplet on the wall between freezer and fridge
heatman101
Aug 15, 2011 | Microwave Ovens
Sub zero 532 fridge is not cooling porperly but freezer is fine
Top of Form
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Jul 09, 2011 | Microwave Ovens
I woke up this morning to my refrigerator humming and not working. It is 5 years old. The freezer seems to be just fine. Help! It is stainless steal model PFSS5NFWASS
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
So try this test from the outside and make your observations so that we come to the solution.
Jun 13, 2011 | Microwave Ovens
FREEZER GATHERING TOO MUCH ICE
Check out these tips...they can help you figure out what is going wrong withyour refrigerator Refrigeratornot Cooling or Fridge not Cooling
heatman101
Apr 21, 2011 | Microwave Ovens
I have a 2 year old LEC T2856w fridge freezer and the fridge keeps freezing everything, it seems to be warmer at the top and makes a wall of ice on the back
That sounds like an a refrigeration engineer is required as if the gas pressure has dropped, it will no longer cool properly.
Mar 07, 2011 | Microwave Ovens
My Panasonic refrigerator NR-B420T is not cooling, however the freezer part still cooling.
Top of Form
Since there is cooling on the freezer the fault can be the defrost timer. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Jan 05, 2011 | Panasonic Microwave Ovens
My refigerator and freezer are not cooling enough
You could call for service. It is commonly possible that there was a loss of gas, or the thermostat is defective, or the compressor is weak. The refridgeration service man should be able to check for all of this.
Jerry G.
Apr 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
