Question about Texas Instruments TI-83 Plus Calculator
My ti-83 plus has a pattern of vertical lines that come across the screen when i press enter a few times and there is a section of the screen that is completely blank and does not pick up any numbers when i type them in.
SOURCE: entering a cubed root into a ti-83 plus
math button and there is a symbol for cubed root
Posted on Aug 26, 2008
  • 32 Answers
SOURCE: TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
Posted on Sep 16, 2008
SOURCE: TI-83 Plus Silver Edition problem
Use a paperclip (tiny hole on back of caculator) and reset.
JC
Posted on Sep 20, 2008
SOURCE: Find the antilog on the TI-83 Plus for finding pH in chemistry problems
how do i find the anilog on my calculator i have a texas instrument ti-30
Posted on Oct 15, 2008
  • 7993 Answers
SOURCE: my TI-83 plus calculator doesn't work
As battery gets drained, the screen contrast dims. But when you change batteries, some times the contrast is reset to some low value and the screen appears dead: it is so light that you do not see anything, and you think the calculator is malfunctioning. This is the most frequent reason users think the calculator refuses to turn ON. And I hope that is the case now.
To correct that, you must increase screen contrast: draken the screen a bit. To do so
  1. press [2nd] key and release it.
  2. Press the Up arrow and HOLD pressure.
  3. Keep pressing the arrow key until screen is dark enough.
If that solve your problem that is good, rate the post accordingly.. If that does not, do not get irate and berate the post. Post a comment here describing what you did and what message (if any) calculator returned, and I will give you further diagnostic steps.
Posted on Jan 21, 2010
Ti-83 when I type something on my calculator an E comes up. On my answer Example 200+500 and I press enter and I get 500E0 what can I do
Your calculator's display is set to Engineering notation.
Press MODE. Use the arrow keys to highlight "NORMAL" on the first line and press ENTER. Highlight "FLOAT" on the second line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Oct 16, 2012 | Texas Instruments TI-83 Plus Calculator
Equations
You can't simply enter 7x+9=30 into the calculator, there is a way to calculate what the x is but its been a few years since I've done these..
Oct 03, 2008 | Texas Instruments TI-83 Plus Calculator
I have an old TI-83 and there are vertical lines across the screen which have dead pixels, I assume. Can this be repaired or do I have to buy a new one.
While someone skilled in electronics may be able to fix it with enough time, the cost in time and labor would far outweigh the cost of a new calculator.
Feb 28, 2011 | Texas Instruments TI-83 Plus Calculator
My ti- 83 plus answers always come in thousands place. example: 1+1= 2 but my calculator says 1+1=2.000
Press MODE to bring up the mode screen. Use the arrow keys to highlight "FLOAT" on the second line and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Feb 01, 2011 | Texas Instruments TI-83 Plus Calculator
I WOULD LIKE TO SET UP MY TI-83 P FOR STANDARD NOTATION
Press the MODE button to enter the mode screen. Use the arrow keys to highlight "NORMAL" on the first line, press ENTER. Highlight "FLOAT" on the second line, press ENTER. Press 2ND [QUIT] to exit the mode screen.
Jan 29, 2011 | Texas Instruments TI-83 Plus Calculator
I'm using a TI-83 Plus calculator. Halfway through my screen there is a straight line preventing me from using the top half of the screen. No matter what I do I can only use the bottom half. Is there...
You've got the split-screen turned on. To turn it off, press MODE to open the mode screen. Use the arrow-keys to move to the second-to-the-last line, highlight "FULL," and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Jan 27, 2011 | Texas Instruments TI-83 Plus Calculator
How to find the polynomial roots in TI-83 Plus
One way is to use the Polynomial Root Finder and Simultaneous Equation Solver app.
Press the APPS key, then select PlySmlt2 and press ENTER. Press ENTER to get past the opening screen, then select "POLY ROOT FINDER" and press ENTER. Select the order of the polynomial and other settings as desired. Press F5 (the GRAPH key) to go to the next screen. Enter the polynomial coefficients, then press F5 to solve. The next screen will show you the roots (unless you selected real roots and the polynomial doesn't have any real roots).
If you don't have the app installed, you can download it from
http://education.ti.com/educationportal/sites/US/productDetail/us_poly_83_84.html
Jan 20, 2011 | Texas Instruments TI-83 Plus Calculator
I can't get my TI-83 Plus to stop providing answers in scientific form.
Press MODE to bring up the mode screen. Highlight "NORMAL" on the first line and press ENTER. On the second line highlight either "FLOAT" or the number of digits you want to the right of the decimal point and press ENTER. Press 2ND [QUIT] to exit the mode screen.
Be aware that if the answer cannot be displayed in twelve digits or if the magnitude is less than .001 then the calculator will always display the value in scientific notation.
Jan 13, 2011 | Texas Instruments TI-83 Plus Calculator
When a number is entered, i.e., 2, six or seven times, vertical lines come up on screen. And, when "Y=" pressed, illegible letters come up. Please help?
try to clear the ram
2nd Alpha S enter enter
you should get a message when the ram is cleared
if you will not get the message then is a hardware failure
if you want to fix the unit let me know
ecrdn@yahoo.com
Jack
Oct 23, 2010 | Texas Instruments TI-83 Plus Calculator
How do i graph a vertical line?
If you just want to draw figures (not graphs) on the calculator you should use the [Draw] command.
Press [2nd] [PRGM] (DRAW)
Select [4:Vertical]
Command echoes on main screen as Vertical
Enter the x-value where you want the line drawn (ex: 2) and press ENTER
You will get a vertical line at x=2.
Mar 17, 2010 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
220 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
