Question about GE Kitchen Ranges
What is error code F1? Can I fix it myself? - GE Kitchen Ranges
  • GE Master
  • 1,711 Answers
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Oct 04, 2010
What does an F-1 code mean on the display? washer will not start.
power problem
  • Whirlpool Fault Codes - AppliancePartsPros.com www.appliancepartspros.com > Appliance Repair Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • Washer Diagnostic& Repair - F1 Error Code power supply ... www.youtube.com/watch?v=BAVS9mI3JLQ
    • BY APPLIANCEVIDEO.COM
    • 4 MIN
    • 65K VIEWS
    2014-02-07 · Troubleshoot your trusty Whirlpool Top Load Washer that has these following symptoms: F1 Error Code At: http://www.appliancevideo.com To ...
  • Whirlpool Cabrio f1 error and how to fix it https://whirlpoolcabriof1error.wordpress.com Control board W10189966 will work with the Whirlpool model numbers listed at the bottom of this page. These models include the Maytag Bravos and Kenmore Oasis.
  • whirlpool F1 code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • 68 POSTS
    • FIRST POST: 2008-07-28
    2009-09-29 · Discuss whirlpool F1 code in Washer Repair. "whirlpool cabrio washing machine displays f1 code. have already pushed cancel and restart to no avail.
  • Cabrio Washer by Whirlpool F1 Error Code - Facebook www.facebook.com/CabrioWasherByWhirlpoolF1ErrorCode Cabrio Washer by Whirlpool F1 Error Code. 793 likes. Got the F1 Error Code? Tell your story! Share ALL your issues with this washer to warn others...
  • Whirlpool Fault Codes - Appliance Help Online appliancehelponline.com/whirlpool.html Whirlpool Range / Stove / Oven Fault Codes: Failure Code: Fault Code Description: Solution: 4 Digit Failure Codes (for 2 digit codes see below) F1 - E0
  • May 04, 2016 | Whirlpool WTW8200YW Cabrio Top Load Washer
    How do I fix my oven door keeps locking up and F1 comes up and starts beeping
    Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
    Aug 27, 2015 | Ovens
    Fix f5 e 1
    F1 - E0 EEPROM communication error 1. Disconnect power for at least 30 seconds.
    2. Re-apply power and observe for at least one minute.
    3. If code re-appears, replace control board (also called ERC or clock).
    Note: Applies to all F1-E... codes except F1-E3. F1 - E1 EEPROM checksum error F1 - E2 UL A/D error(s) F1 - E4 Model ID error F1 - E5 Calibration shifted F1 - E6 Latch signal mismatch error F1 - E9 Stack overflow F1 - E3 Wiring harness cavity size does not match previously stored value The "Cavity Size Select" jumpers in the wiring harness indicate a cavity size different from that which the control was previously configured for. Check the jumpers in the harness to make sure they agree with the actual oven size.
    Jun 05, 2015 | KitchenAid Architect II Superba EQ Series...
    Error code f1 e3
    Try this out,
    FAULT ERROR: F1 E3NOTE:Make sure harness to P1 connector is correctly installed
    per wiring diagram before performing the following steps:
    STEP 1 Power off and wait 5 seconds.
    STEP 2 Power on and wait 5 seconds.
    STEP 3 Press the following keys:
    CONVECTION - CONV. BROIL CLEAN BAKED GOODS 190 TIMER SET
    NON-CONVECTION - CLEAN STOP TIME 0 OVEN LIGHT 1
    STEP 4 Press START.
    STEP 5 Make sure Timer ID is the same as the oven.
    STEP 6 Press CANCEL to exit.
    Nov 27, 2012 | Kitchen Ranges
    I keep getting an F1 error code on my top load Whirlpool Cabrio HE washer. I do what the manual says to do which is to hit the Pause/cancel buttom and then start....I continue to get the F1 error code for...
    There is a recall for the Cabrio F1 error code issue. I had mine fixed for free. They will have to replace the control board. You will need to call 1-800-253-1301 and tell them that your Cabrio washer is having the F1 error code and you read on the internet that Whirlpool has been making repairs. Have your model number, serial number, and purchase date ready for the person on the phone. The guy that repaired mine also replaced the washboard at the bottom for free...just ask the tech about it when he is there.
    Dec 07, 2009 | Cars & Trucks
    Amana slide in range F1 error
    f 1 code is the electronis range control failure.. ( clock ) it's not a hard job . turn off power!!! open the control panel - screws under edge/ the clock is held with 4 small screws . remove the wires one at a time ( don't mess them up or wala the new clock is up in smoke .. ) install wires one at a time all terminal are marked . reinstall / plug in / reset time and oven will work .. mm hope this helped.
    Dec 04, 2009 | Washing Machines
    F1 error code on Kenmore Oasis He
    Per Sears. To fix the problem. Unplug the washer for at least 10 min then push pause or stop 2 times and this will fix the problem.
    Mar 25, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
    KitchenAid KESS907 Electric Range E1 F1 Error Code
    F1 E1, replace Electronic Range Control.
    In other words, the controller board has failed.
    Jan 29, 2009 | KitchenAid KDRS807SSS Dual Fuel (Electric...
    F1 error on cabrio washer
    http://www.petitiononline.com/cabrio08/petition.html
    Aug 05, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
    F1 Error code
    i just had this same issues happen after running the self clean cycle. f1 error, fan would come on, fan would turn off. its not the control board, its the temperature probe. I picked up the part for 40 bucks and put it in myself. plugged the stove back in and it was good to go. the old temperature probe's wires melted during self clean. note to self: clean you over the old fashion way with some elbow grease.
    Mar 30, 2007 | Kenmore 46123 Stainless Steel Electric...
    Kitchen Ranges Logo
    290 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
     Fix Your Board
    Fix Your Board
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
