Question about Canon EOS Rebel XSi Digital Camera
I just bought the camera rebel xsi 3 month ago ,my problem is when I take a picture I get an err 01 it said . communication between the camera and the lens is faulty clean the lens ,,but i clean it so many times its still get the same err...but when I twist the lens half way it work but the picture s not clear what I do ??? thank you
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 07, 2010
Canon Rebel XT Err 05
Hi. Take a look at the below link, it may be your solution.
Canon Rebel xsi Err 05
Feb 21, 2014 | Canon EOS Digital Rebel XS / 1000D IS...
I have a Canon XSI Rebel that I bought new 2 years ago. For some reason when I'm in AV mode I cannot seem to get the ISO down to 100. Is there a setting that I may have missed? When I have the cam
The AV mode is for setting the aperture (ie Depth of Field).
To change the ISO setting turn the Mode dial to the P position and then turn the Main dial (next to the shutter button) to the ISO setting you require.
Apr 08, 2013 | Canon EOS Rebel XSi Digital Camera
Err 01 Communication between the camera and lens is faulty
Most of the Time when this happens it's the curcuit board inside the lens that bad from use, Needs to be replace by a repair Tech! Try a different Lens to confirm that! TCCameraRepair.com
Jan 27, 2018 | Canon Digital Rebel XSi Digital Camera
My Canon EOS Rebel XS only takes pictures indoors (ERR. 01)
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
May 14, 2017 | Canon EOS Rebel XS 35mm SLR Camera
How to repair err 01 on canon 1000d "Communication
So, have you cleaned the contacts? Remove the lens and using a cotton swab lightly dampened with rubbing alcohol, clean the contacts on the lens and the camera body where they meet.
Oct 15, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Canon EOS Rebel XSi pop up flash won't "pop down"
Do not Tape it down, If the flash is pooping up all the time take it to a good Camera repair shop to have the catch replaced. At the same Time you may consider getting a full service done.
Dec 26, 2009 | Canon EOS Rebel XSi Digital Camera
Err 01 on Rebel XSi
shutter struck, if the battery has no enough charge the shutter motor will not rotate fully,charge the battery and try.
Aug 31, 2017 | Canon Digital Rebel XSi Digital Camera
Canon 450D, ERROR 99 only when flash pops up
Err 99 usually means your lens contacts are dirty either on the lens itself or on the camera.
To isolate the cause of the issue, do the following: -
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert only a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99" message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99" message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99" message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99" with a different Canon lens attached, then the camera is faulty and should be serviced.
Mar 31, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EOS Rebel XSi Digital Camera Logo
151 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
