Question about Canon PowerShot SD870 IS Digital Camera
My camera won't focus. It turns on fine (other than a little bit of grinding noise when starting) and does not show any errors in the LCD but it won't focus on anything. What is the problem and the solution?
  • 152 Answers
Better off getting new camera
Posted on Sep 07, 2010
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Our fuji finepix s9600 has started coming up with an error message "focus error", even if you set it to manual focus, any ideas?
If you say that the camera was making a grinding sound before it quit working the grinding noise should have been looked at then, cameras do not make grinding sounds if they are working properly. the sound is the drive unit going bad and that is why you are now getting the focus error because the drive unit has quit working completely !!!! It is now time for the shop.
Jan 19, 2013 | Fuji Finepix S9600 Digital Camera
Camera lens won't shut
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error" (older Canons), "ACCESS" error (Sony), "Zoom Error" (Fuji), "Lens Obstructed" (Kodak), "lens error, restart camera" or just "lens error" (nearly all camera makers lately use this variation). Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
Jul 28, 2012 | Samsung Digimax S500 Digital Camera
Canon powershot sd790 won't focus
There is probably dirt in the camera that restricts operation, the other concern is damaged gears, camera is trying to focus.
Mar 19, 2012 | Canon PowerShot SD790 IS/ IXUS 90 IS...
I turn on the camera and it starts to focus in and focus out making a noise and then appears ''lens error''..
The gears in the lens housing is grinding because of grit build up, it must be taken apart and cleaned in order to get it back to proper operational standards.
Feb 06, 2011 | Cameras
I have a Casio Exilim EX-Z33 and i dropped it a while ago and it continued to work (kind of, the images were a bit blurry). i took a picture five minutes ago and then turned it off. the lens went in but...
Sounds like the focus motor came loose - you need to take it apart and repair the gear that drives the lens assembly for focusing. The noise you're hearing is the motor trying to focus but since the lens cannot focus it continues to run and signals an error.
Feb 03, 2011 | Cameras
Weird noises when it's on and zoom button noise picked up on vid
change auto focus to single focus mode,
since it is on continuous auto focus on default, it would focus all the time so you don't need to click half way before taking a picture
Mar 22, 2010 | Kodak Easyshare M341 12.2MP Digital Camera...
FOCUS ERROR
I also had this problem. When starting the focus error alert came. Trying to move the focus button also triggered this. When I turned it off, the lens did not pull back.After being close to trowing it away, I used a little bit more force than before and turned the lens manually. I heard a click, and than it worked again. PS: Follow this tip on your own risk.....
Mar 11, 2008 | Fuji FinePix F410 Digital Camera
Pictures appearing black- olympus FE 170
You checked the obvious, lens cover? (sorry had to ask) any grinding noises when you take a picture or focus\zoom?
Aug 26, 2007 | Olympus FE-170 Digital Camera
SD200 E18 Error
E18 is the error that comes when when the lens is stuck, so if the lens is stuck out, turn off the camera, carefully turn the lens until you hear a small clicking noise, then turn it on. I had the exact same problem, and that fixed it for me
Jun 23, 2007 | Canon PowerShot S400 / IXUS 400 Digital...
Soft clicking-grinding noise
i think that you have the full-time auto focus on.
go into the menu and turn it of and all should be fine.
seekreep from Edinburgh - Scotland.
Jun 10, 2007 | Olympus C-7000 Zoom Digital Camera
Canon PowerShot SD870 IS Digital Camera Logo
66 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
