Question about Akai CFTD2011 20 in. EDTV-Ready LCD Television
The power supply is not working and I need to replace this part. Please I need to know the cost .
  • 11,361 Answers
Why won't it turn on?
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Oct 01, 2015 | Vizio 65" M650VSE Full HD LED-LCD TV,...
Where can I purchase a replacement power supply fo my Sony Digital Media Player Model NWZ-E344?
Check out newegg.com they often have a wide array of power supplies at a reasonable cost for sell.
Make sure of the power supply watts and the connector type, once you have those two things search the site for a replacement.
Remember to do an internet search for discounts or coupons, as you can sometimes find codes to enter on newegg to get a discount.
Mar 17, 2013 | Sony Audio Players & Recorders
Unit hit by lightning. Replaced main fuse. Power supply works. Replaced main control unit. Both green and amber lights blink constantly
How many times does the standby light blink between each pause? Its a self-test diagnostic that will pn-point us to the source of the problem so please let me know.
Aug 18, 2011 | Sony KDL52NX800 52 in. TV
What is a replacement power supply for Area 51 Desktop NPS-750AB-1 ATX power supply ??? dont sell them anymore and need a new one - please help - thanks
Just make sure that the MAX OUTPUT that should be on a sticker with all the other information directly on your power supply is the minimum output that you require on your new purchase of an ATX power supply. Your options for replacement don't really rely on the brand of power supply, it's determined more by what your power consumption is - so a good rule is to at least get one as powerful as the one you're replacing. Also make sure that the new power supply has the appropriate power connections and the amount that you need, but the outlet in which you purchase your power supply will be more than happy to give you information about all the power supplies that they have for sale.
Nov 25, 2010 | Alienware PC Systems Alienware Area-51®...
Hello, When I turn on my PC the fan turns a few secs and than stops. I had this on another oc and the problem was the motherboard. Do I need to change the motherboard again or is there somethin gelse...
You did not specified which fan, there is several of them, and usually you do not change motherboard to fix fan, if fan on power supply stop, you need to change power supply, it is cheaper actually to exchange power supply than to replace fan, if this is processor fan, check first if it is plugged correctly to it's socket on motherboard:
1. switch off computer
2. remove power cord from teh back
3. remove side wall of the computer (left hand if you look at it from front)
4. remove processor fan from socket and then re-insert it
5. re-install wall, re-connect powercord and power up the computer
6. if this was just bad connection, you just fixed the problem :-) if this did not solved the problem, you need to purchase new fan suitable for the processor. This is LGA775 Intel processor motherboard, fan for it cost between $15.00 and $80.00 depending on the brand. You do not need to replace heatsink, I would advice replace only fan:
7. follow 1, 2, 3 and 4 then lift side tabs on the fan (over the heatsink, yo umau need little flatbed screwdriver as lever) and slide it out
8. insert new fan in exactly same position till tabs on the side click in
9. re-insert fan power supply to it's socket follow 5 and 6
If this is case fan, this is simple, proceed 1, 2 and 3, then undo screws (philips) holding fan, remove it's cord formteh socket, replace with same size fan, case fans cost from about $2.00 to about $50.00
if this is power supply, you need to purchase adequate power supply, it will cost between $20.00 up to $300.00, in your case $20.00 to $50.00 is fine... Please pay attentnion to rating and do not purchase any with less than 450w, they cost in my shop $27.00, do not bother with brandname!
Follow 1, 2 and 3
4. remove power supply from motherboard sockets, there will be 24pin socket on motherboard, look how it is oriented, replacement will fit only and only one way! remove power supply from fan supply (4 pin on the motherboard),
5. remove power supply from auxilliaries, hard disk drive, cd-rom and if any other, from them as well, do pay attention to orientation of the cables!
5. undo four screws on the back holding the power supply, support it with your hand while reomving.
6. insert new power supply (do pay attention which way it go on the back, yo uhave four screws fitting only in one way) and mount the screws
7. re-connect power to motherboard, wiggle it slightly in, do not break motherboard! same with fan power supply
8. re-connect power to auxilliaries, pay attention to sata connectors, they break easy
9. replace side, re-connect power supply and switch on computer, it should work now
Hope it did solved your problem, please do not forget to rate! This is only reward whcih we have...
Aug 23, 2010 | Computers & Internet
My Power Supply Burnt Out Can I Get It Repaired?
A power supply can't be repaired.The replacement cost is probably about what a repair would run anyway,or less.
Pick up a new one,and you also pick up a new warranty.
Good or bad,please rate my post?
Bob
Aug 11, 2010 | RaidMax RX-500S 500W ATX12V Power Supply
Need a new power supply for aspire x1200 desktop powered off wont turn on now? how much does the power suply and fan cost?
If you in the USA you can pick one up from Fry's for less than $80.00 both... Let me know how this worked for you and please do not forget to rate my service so we are able to improve on it. The rating as follows 1 the service was not related to the post. 2 the service was related but not did not help at all. 3 the service was to the point and somewhat complete. 4 the service was excellent and to the point.
Sep 29, 2009 | Computers & Internet
Power supply
Its possible that it is the power supply. If you wanted me to take a loot at it I could but you would need to remove the power supply from the TV and ship it to me. The power supply has been a common fail point of TV's, VCR's and other home electronics in the past several years. Let me know if this is something you would like to discuss further. I just need contact info.
Dec 29, 2008 | Akai LCT3201TD 32 in. LCD Television
Gateway 831 GM won't boot up no signal is showing in the begining
ram,
It sounds like the problem is either your power supply OR the motherboard. A power supply swap doesn't take long or cost much.
On the other hand, replacing a motherboard takes 30 minutes or longer and can cost upwards of $100!
Please let me know if this helps. Good luck!
Mar 01, 2008 | Computers & Internet
No picture, No sound
Hi there!
If the set is dead after the popping sound, then it has probably blown a component due to high voltage. Everything inside a tv starts with the power supply. Nothing will work unless the power supply is 100%. I don't know what your rates for repairs are in general, but the price sounds good. The final decision is yours to repair or replace. Good Luck, JUS004
Jan 24, 2008 | JVC AV-32FA44 32" TV
Akai CFTD2011 20 in. EDTV-Ready LCD Television Logo
80 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
