Question about Samsung HT-Z310T Theater System
I just got a sony 40 inch tv and i connected all wires in right place but surround sound will not play when tv is on regular channels? but will play on radio and dvd
    New Friend:
  • 152 Answers
It will only play stations that are BROADCAST in surround sound
Posted on Sep 07, 2010
SOURCE:
Sony DVD/VHS player to my TCL Roku TV
You can use the RCA style jacks, Yellow for video White for left and red for right audio OUT . Connect the TV end the same way. Note the source input number on the connectors of the TV. Turn both the TV and the Sony on. On the TV, select the input number the cables are connected to and you will see the Sony . If there are no unused places on the TV to connect to then take off the antenna/ cable wire off the TV and put it on the ANT IN connector of the Sony. Obtain a jumper cable wire long enough to reach the TV from the Sony and select either channel 3 or 4 whichever channel is not used in your area on the back of the Sony. Now turn both on and select TV as the source and put it on channel 3 or 4. Now turn off the Sony and change the channel on the TV to any other one in your area. If there is no picture, then the Sony will have to be on while watching TV.
Sep 15, 2016 | TCL 40FS4610R 40-Inch 1080p 120Hz Smart...
How too hook surround system to regular tv. Example : a football game. Thanks
Well, since the "regularTV" has no make or model number I will have to guess what outputs it has to suit your surround sound system which also has no make or model number! Using outputs that show left and right speaker channels wire each to the left and right speaker channels of the surround sound amplifier. How many, I don't know!
Jan 23, 2013 | Audio Players & Recorders
When I play a DVD in the system I can only get the surround sound out of the speakers but no voices. If I play a CD or hook it up to my tv everything is ok.I have tried a number of DVD's and all have the...
sounds like you need to surround modes. There is usually a Stereo, Dolby, DTS, "virtual surround", 4-speaker mode etc..
When you play a CD or connect to TV it likely defaults to playing stereo or virtual surround.
With real surround, almost all of the voices are coming from the center-channel speaker (normally placed closest to the TV).
Also, check to make sure the center channel is connected properly.
Aug 31, 2009 | Panasonic SC-HT930 System
I get surround sound whenever i'm playing dvd's. But how do i hookup surround sound when just watching television? I have a 46 inch Sony Bravia LCD TV and a Panasonic SA-HT700 surround sound and HD...
just plug your satellite and dvd player in to your tv. and simply take an extra set of red, white, yellow wires and us use the red and white wires to connect fron your tv output to your surround sound system's input. now you should have surround sound for everything included local tv stations from your tv antenna
Aug 28, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Surround sound not playing TV audio
you need to run red and white from your tv to the surround sound and the same from your dvd to surround sound
May 02, 2017 | Sony Audio Players & Recorders
Lg home theater to lg plasma tv
This is a typical problem with TV broadcast UNLESS you use a matrix DSP surround sound mode, most DVD audio is either Dolby digital 5.1 surround or DTS multi-channel surround sound, unless you are viewing a HDTV broadcast with 5.1 Digital sound connected from the TV to the receiver then you are probably receiving a 2 channel Stereo sound format, I would suggest that you try to set your TV input mode to a audio Dolby Pro- Logic which will yield 5.1 and should engage all speakers.
Feb 17, 2009 | LG LHT854 Theater System
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
Yamaha reciever rx-v363
Thats because if you look in the owner's manual, it declares the fact that it will only broadcast sound from hdmi to monitor not speakers. For sound out of speakers need to connect additional audio cable.
Apr 21, 2008 | Yamaha RXV-350 Receiver
Audio via hdmi
Have you tried to hook up your DVD player directly to the surround sound system? If you direct the sound through the TV, it has to pass several circuits and the quality will be lover. Just connect it right away to your sound system. :-)
May 21, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
Samsung HT-Z310T Theater System Logo
144 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
