Question about LG DLG2525S Electric Dryer
Dryer keeps stopping - check filter light on
The filter inside the dryer is clean - but the dryer keeps stopping and blinking check filter light is on again. Help - I've got 5 loads of laundry to do today!!!
  • rosie43 May 13, 2008
    I pulled the filter out again and vacuumed down in the slot. Then I pulled the dryer out from the wall and sort of straightened out the vent thing (our laudry room is very small so there isn't much room for the vent thing). I also washed out the filter too. Whatever I'm done - it's working! Thanks for the tip though - it might have been that all along!
For Sgt 48 - You are not reading the original message very well - The original help question didn't say they saw check filter at the beginning or end of a dry cycle they indicated that the dryer STOPS MID DRY and says check filter - this is not a friendly reminder, it is indicating something is wrong and the filter needs to be completely cleaned out (and past the filter down in the interior of the dryer) and if that does not work then you need to also check the dryer hose for kinks, lint build up, etc. Lastly, reset the dryer by unplugging it (or flipping the breaker) for a minute or so and hold down on the start/pause button for 8 seconds while it is unplugged (this will reset the error code for check filter, among other things).
Posted on Feb 07, 2010
  • micsolcon Sep 01, 2014
    Turned off the breaker, held in the power button for 10 seconds and turned it back on. Works great!
  • 770 Answers
Make sure you havwe seated the filter backin there properly all the way down check that and let me know
Posted on May 13, 2008
    Champion:
  • 210 Answers
You did not read the manual did you? Don't worry most people don't. The check filter is just a reminder to 'check your filter' it comes on when you turn on your unit and at the end of every load. Nothing to worry about.
Sgt 48
Posted on May 31, 2008
GLEQ2152ES0 dryer stops after ten minutes and then blinking lights on the right of the side panel. The lights that blink simultaneously.
The dryer is telling you what is wrong with it. Count the number of flashes the drying, cooldown, pressaver and clean filter light are flashing then count the number of times the control/start light is flashing. That will give you the error code number.
Dec 04, 2016 | Dryers
LG Dryer - Check Filter Blinking Light is on and the filter is clean but my dryer won't come on?
The check filter light is just a reminder. Goes off once dryer starts. Dryer not working has nothing to do with that reminder. Check to see if belt is broken. When it breaks, it stops motor from working. Just take top off and tug on belt.
Dec 01, 2016 | LG Dryers
Check filter light blinking will not start only beeps what to do please help
Probably a lint buildup on the sensor. Need to clean the entire lint system. Should be able to remove the plastic frill if the lint filter is inside the drum. Remove the two screws and clean out all the lint then pull the dryer out remove the vent hose. Run a vacuum hose or reach up i to there and pull out the li t. Then clean out the vent hise...a broom handle works if it's a straight shot.
Oct 11, 2016 | Kenmore Dryers
The clean filter light was flashing but it stopped after I cleaned the vent but still won't heat, Is there another vent/filter in this dryer?
the blinking filter light is just a reminder, not connected to anything. goes out when you start cycle. however, if the dryer overheated then it may have blown the thermistor fuse. check out appliancepartspros.com or repairclinic.com for how to videos and parts.
May 23, 2016 | LG DLG5988 Gas Dryer
Keep getting warning "check exhaust" on a new gas dryer. All exhaust is clear. What's going on?
The CHECK VENT duct blockage sensing system detects and alerts you to blockages in the duct work that reduce exhaust flow from the dryer. This light does not indicate any problems with your dryer. If this light blinks, it indicates that your home's exhaust system/duct work has a serious restriction
Every time the dryer is turned on, the CHECK FILTER LIGHT WILL BLINK, as a reminder to make sure the filter is clean. Always make sure the lint filter is clean before starting a new load; a clogged lint filter will increase drying times.
The Kenmore Elite dryer has a sensor that detects poor exhaust venting, and when it does, a light flashes on the control panel. This warning light does not include a mechanism to stop gas flow, but if it is allowed to flash for an extended period, poor venting may cause the dryer to overheat. As a result, a fuse might blow and disable the gas valve or ignitor. You can prevent this by diagnosing the reason for the flashing indicator light as soon as possible.
In many cases, LINT has built up somewhere in the exhaust pipes.
Check under the lint filter. Pull it out,look inside the slot it fits in, and clear all lint from this area.
Is it possible you have used the WRONG VENT MATERIAL?
Check your vent to make sure it is 4 inch rigid or semi-rigid metal ducting. If your venting is plastic or flexible foil, replace it before using the dryer.
Check your vent hood outside. You may have a restricted or damaged vent hood. It must be clean and free of lint buildup. Check the damper and make sure it opens fully and easily and is free of lint.
I know you said you have no elbows, but I have posted the pipe run lengths with and without elbows. Keep in mind this is with 4 inch rigid or semi rigid metal ducting.
Measure the length of your exhaust system and count the elbows. Use the chart below to see if your duct is too long. If it is too long, have the duct routed to another location that is within the venting guidelines.
0~90 degree elbows=65 ft of 4 inch rigid metal duct.
1~90 degree elbow=55 ft of 4 inch rigid metal duct.
2~90 degree elbows=47 ft """"""""
3~90 degree elbows=36 ft """"""""
4~90 degree elbows=28 ft """"""""
You should always use duct tape or metal tape on all joints, NEVER USE SCREWS, as screws capture lint inside the pipe.
One more note. Lots of people overlook the fact that fabric softeners can build up on the lint filter over time. This buildup can restrict the airflow through the filter reducing dryer efficiency and lengthening drying times. After removing lint, if the filter looks dark or dirty when held up to the light, follow these steps to clean:
Use hot soapy water and a stiff brush to clean
the filter.
Make sure the filter is completely dry before
reinstalling it and using the dryer.
NEVER operate the dryer with a wet lint filter.
Oct 29, 2014 | Kenmore Dryers
Dryer check filter light keeps blinking and dryer will not start cleaned lint filter and nothing happened display on control board blinks when dryer is turned on and that's about it can you assist dyer...
There is a reminder light to "Check Lint Filter" near the lower right of the cycle knob. It will come on every time the power button is pushed. After cleaning the lint filter, if the "check lint screen" light does not go off, it is likely that the touch pad control will need replacement.
Jan 09, 2011 | LG DLE0442 Electric Dryer
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
LG DLG2525S Electric Dryer Logo
3,668 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
