Question about Sony Dvcam DSR-PD150 DV Digital Camcorder
Error message on lcd screen :for infolithium battery only"
Camera switch itself of after this messages"for infolithium battery only"
Each time I put the ac adaptor it just switch on for a few seconds and switch off showing that message on the lcd. If I try to charge the battery its not charging at all , but if I record using a battery there seem to be no problelm at all I tried to change the ac adaptor and use a new one from my other camera it still show that message and( its) the adaptor works on the other camera.
  • 21 Answers
Problem connector,DC-IN part no.1-794-637-11
Posted on Sep 23, 2009
  • srdjan ko Sep 23, 2009
    Terminal board,battery part no.1-694-411-11
Use infolithium battery pack
I believe Shahid is correct... it's probably the pins.. try this... first make sure all switches are off during the entire process (viewfinder pushed in and keeping the LCD closed, try cleaning the pins on the back of the camera with a Q-Tip and Isopropyl alcohol (91% if possible)... leave it a bit damp and push the battery into place several times to clean it's contacts too.. then let everything dry, reconnect the battery and turn it on. The problem will hopefully be all gone.
Apr 29, 2012 | Sony Video Cameras
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
While inserting battery Sony NP-FP90 in my Sony Handycam DCR HC46 , it gives error mrassage " use infolithium battery and camera switch off Pls help
You can attempt to fix an InfoLithium battery which has developed passivisation by a process of charging and discharging several times.
try this while the camera is turn off.
let me know the outcome.
May 11, 2011 | Cameras
My Sony camcorder often stops and a writing appears: "Use the infolithium battery pack" It happens either when I am recording or I am watching the tape and can happen any time, after five minutes, ten...
It sounds like you are using an aftermarket (non-sony) battery pack. The camcorder you are using probably requires the Genuine Sony 'Infolithium' Battery pack (usually in the box of the camera). If you are getting this message with the proper battery installed, i would contact SONY
Jun 17, 2010 | Sony HVR-A1E HDV Digital Camcorder
Screen message
Your battery is not making contact with all three contacts, thus making the camera believe you are not using an infolithium battery, creating the error message. Clean the contacts on the camera with isopropyl alcohol and the contacts on the A/C charger.
Apr 18, 2010 | Sony Handycam CCD-TRV608 Camcorder
I have this message in my camera : battry infolithium only
Google Translate
J'ai trouvé ce site
http://www.pechorin.com/m/2006/03/05/For_InfoLithium_Battery_Only_error_message-256813.html
Tout d'abord nettoyer les connecteurs de batterie
Si cela ne permet pas de remplacer la pile
Si cela ne fonctionne toujours pas, vous avez un problème avec la caméra.
Original English Text
I found this site
First clean the battery connectors
If that does not help replace the battery
If it still does not work you have a problem with the camera.
Jul 08, 2009 | Sony Cyber-shot DSC-T10 Digital Camera
What does "for inoLithium battery only" mean?
Is it a Sony battery. I had a similar problem on a similar Sony that I fried using an aftermarket battery or at least that is what Sony said caused it. Especially if it is an info battery.
Jun 28, 2009 | Sony Cyber-Shot DSC-P50 Digital Camera
"SONY 'InfoLITHIUM' SYSTEM" Error
when I opened up the camera, the tape part of the cassette was hanging out. I tightened the tape and reinserted the cassette. this seems to have fixed the problem. hope this helps.
May 07, 2009 | Sony Handycam DCR-TRV19 Mini DV Digital...
For Info Lithium Battery only
I was having the same problem with a sony GV-D1000 which I don't even use a battery with. I use an AC adapter. Someone suggested that the contacts might be dirty, so I unplugged the small connector that plugs into the back of the deck and wiped it hard with my t-shirt. It seems to work fine now. SO try cleaning the contacts (wherever your adapter or battery connects with the deck or camera.)
Aug 11, 2008 | Sony GV-D1000 Mini DV VCR
When I place my infolithium battery into my Sony Cybershot camera, it doesn't work. It works for about 5 seconds, and then the words: infolithium battery only flash and the screen goes black and the...
Camera doesn't get Info Signal from battery thats why gives such message. One solution is to deattache battery for couple of hours and try again.
2nd is that camera has hardware problem and requires qualified technician to repair it though its not big repair.
Jun 01, 2008 | Cameras
Sony Dvcam DSR-PD150 DV Digital Camcorder Logo
765 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
