Question about Yamaha YST-MS50 Computer Speakers
I need the subwoofer cable which connects to the right speaker
Im trying to hook up a paradigm pdr-12 to my tv and xbox 360 and need an idea of how to do this the right way so it only plays the bass and nothing else
Hello there this subwoofer has a built in crossover variable from 50hz to 150hz which means that any signal you feed it the sub it will ignore anything but bass anyway.
As for the connection it is made quite difficult if you don't already have an amplifier powering your other speakers, usually home cinema amplifiers have a low level pre out for subwoofers, for which you would just need a phono to phono cable.
However if it doesn't and you have any type of amplifier with at least 2 separate left and right speakers you can connect the wires from these into the subwoofer and it will output the bass from these 2 channels.
Another option is to use a mono to stereo (2 to 1) phono cable where the 2 connectors at one end connect to a tape or record output on your amplifier and the single phono at the other connects to the subwoofer, the same would go if you have a red & white phono (RCA) output on your TV you could also use this to power the sub, in the worst case scenario you could use a single to single phono or rca cable to connect one of the output channels (left or right) on your TV to the subwoofer however this would mean that the subwoofer would only output bass from either the left or right channel.
Hope this helps
Kind Regards
Ant
Aug 26, 2011 | Audio Players & Recorders
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
I have no idea how to connect these speakers all I have is the wires for the 5 speakers and a power cord for the sub any help please?
You have not mentioned -- connect it to what ???. Assuming that its an AV receiver. Start by connecting the front three speakers to the the amplifiers speaker sockets labeled Left front / Center / Right Front. These are connected using three short wires. Then connect the two surround speakers using the pair of long speaker cables. You will need a RCA to RCA cable to connect the subwoofer to the Receivers subwoofer preamp out.The subwoofer also requires an A/C wall socket to power it.
Mar 08, 2011 | Cerwin Vega AVS-5.1 System
Unable to receive optimum output. The bass is totally flat !
Hi, ok the Bose Acoustimass III system consists of two small cube speakers and one subwoofer unit called the Acoustimass bass module. If the subwoofer stops working, three points can be the cause of the failure. The Bose Acoustimass III is a passive system, meaning the speakers do not power themselves, but instead are connected to a receiver or amplifier. Thus, the amplifier, the speaker between the amplifier and the subwoofer, or the subwoofer itself could be the issue.
Things You'll Need:
* Amplifier
* Speaker cable
* Extra subwoofer
Instructions
Disconnect the speaker cable from the back of the Bose Accoustimass bass module and connect it to a subwoofer that is known to be working. If the subwoofer works, the bass module needs to be replaced.
Disconnect the speaker cable from the back of the receiver or amplifier you are using and from the back of the subwoofer in Step 1.
Connect a speaker cable that is known to be working between the back of the receiver or amplifier and the back of the Accoustimass module. If the module starts working, then the cable was the issue.
Disconnect the speaker cable from Step 3 from the back of the amplifier or receiver, then connect the cable to the subwoofer port on the back of an amplifier or receiver that is known to be working. If the subwoofer works, the receiver was the issue. If the subwoofer still does not work, verify that the speaker cable is in the subwoofer port of the receiver/amplifier and that the cable is connected securely to the subwoofer.
If you think you did the connection properly,Fine... If not you can use the manual from the below link and know how to connect it properly..
products.bose.com/pdf/customer_service/owners/og_am5iii.pdf
Have a nice day..
Feb 19, 2011 | Bose Acoustimass 5 III System
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
I have Harmon Kardon AVR 25 ii receivers and I have attached it to Bose 701 front speakers and three other Bose surround speakers and an subwoofer. All the speakers work except for right speaker, I need...
To locate the problem...a) Cable
Test if right cable is ok, by interchanging the rt/left cables.
b) Test Bose right speaker
Connect the Bose right speaker to HK's left channel. Works? Then Bose right speaker is ok.
c) Test HK's right output by connecting the left Bose speaker to HK's right output.
Does not work?
Jun 16, 2009 | Audio Players & Recorders
HK395 Speakers/Subwoofer Cable
Jul 26, 2007 | Dell HK395 Computer Speakers
Yamaha YST-MS50 Computer Speakers Logo
64 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
