Question about Home
Instructions for operating SuperFlow PF-35 sand filtered swimming pool system no longer manufactured by Pac-Fab, Inc but was working when I purchased the home. I have not used it for 3 years. I am trying to get it working for a granddaughter now staying with me.
  • 33 Answers
SOURCE: What is normal pressure at pool sand filter when pump is running?
This is normal pressure! As the filter becomes more dirty you will see the pressure get higher 15/20 it's time to backwash!
Posted on Jan 27, 2009
  • 297 Answers
SOURCE: Sand Pool Pump dosent pump water round when on filter????
under the head that you spin for yor settings is a gasket.you must take out all the bolts on the head to replace it.it is called a spider gasket.it should cost you about 8 0r 10 dollars at any pool place near you.
Posted on Jul 20, 2009
  • 83 Answers
SOURCE: I pushed in the air button on our pac-fab jetted
outside ring on button turns, just turn and let air in and it shud pop out...
Posted on Nov 20, 2010
Aerosurgen
  • 55 Answers
SOURCE: swimming pool pump runs at
It sounds like it may be time to change the sand or DE media. After time the sand and or DE media tends to get packed down reducing the water flow and increasing the pressure.
Posted on Jun 15, 2011
  • 372 Answers
SOURCE: Swimming pool Hayworth s240 sand filter suction is wimpy can it be old sand causing the problem?
The filter may be clogged. If you have a multi-port valve that you use to backwash, set it to "recirculate" and see if your suction improves. If it does then the filter needs to be cleaned out. If there is no difference the issue may be a clogged impeller or some restriction in the suction line. Has the pressure been running high?
Posted on May 19, 2013
Is there a step-by-step how to change the sand in a pac fab super flow sand filter model pf35.
Try Googling (pac fab)(pf35)(manual) without parens for instructions.
May 19, 2017 | Pool & Spa
Tip
How to Choose the Right Swimming Pool Filter?
There is a lot of confusion about various filters, many different opinions, and several important facts to consider. The first is that a pool can be properly maintained with any of the filter systems available: Sand, Cartridge, or Diatomaceous Earth (DE). Here is a brief description of each type:
SAND FILTERS
Water is pushed through a bed of filter sand and removed through a set of lateral tubes at the bottom.
The filter area of a sand filter is equal to the area of the filter itself.
For example, a 24" filter will have 3.14 square feet of filter area. Only the top 1" of sand is actually used to filter the water. The principle behind this filter is that water is pushed through the filter sand, somewhat like an espresso machine. Dirty water goes in the top and clean water exits out the bottom. As the filter sand becomes plugged with debris from the pool, the pressure increases on the filter and the water flow drops. In order to clean the filter, you just run it in reverse and dump the waste water; this is referred to as "backwashing" the filter.
How to Choose the Right Swimming Pool Filter Pool filter reviews
on Jun 20, 2017 | Intex Krystal Clear Model 635 Pool Filter...
Pac fab sp710 filter control (old)
yes new spider gasket careful you might have to glue it in
Sep 23, 2013 | Pentair Pac-Fab 2" DE Filter Multiport...
Filter stopped working
I would agree...
they are just a Toy! Sorry, I don't mean to be sarcastic, but that is how they are manufactured, not designed to last.
My customers come into my store all the time asking for pump replacements, and if they don't want to upgrade to a Real Pump and Filter, then I send them to:
Warranty Return Policy
To purchase another replacement toy,, like:
  • Intex
  • Wet Set
  • Krystal Klear
  • Cloud
  • Fun n' Sun
  • etc
and you get this...
When the pool s are purchased from walmart, kmart, target, etc
But...
If you can find it in your budget to upgrade, you can still use the same vessel, upgrade to a real filter & pump package set.
like this one:
Hayward S166T92S Pro Series 16 Inch 1 Horsepower Top Mount Sand Filter...
Don't replace with the picture above.
Sep 11, 2013 | summer escapes 16 x 48" Frame Pool
May 19, 2013 | Pool & Spa
The plastic where you screw the clear plastic lid on top broke on one side so the lid does't clamp down. Is there a way to repair this or replace just the tub part without buying a whole new pump? The...
PAC-FAB / Pentair Dynamo pool pump parts, Discount parts for PAC-FAB Dynamo pumps
This site shows a separate part for the strainer body, but I'm not sure it is separate.
Call them with your model number and they can tell you if it unscrews and sell you the repair part that you need.
Worse case, you might have to see if you can remove the entire pump casing and purchase that.
Gary
Feb 26, 2011 | Dynamo ABOVEGROUND POOL PUMP - 1.5HP -
Brought a used hayward pool. no instructions on how to set up the pool. help
Here is a copy of the users manual for these pool filters. It has detailed pictures that should help you get the filter up and running in no time!
http://www.backyardcitypools.com/images/hayward/swim-clear-manual.pdf
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
Intex Easy Set 530 Gallon Swimming Pool Filter Pump does this keep your pool clean when running all the time?
No, the filters/pumps are much to weak. Not only is that filter too small for the pool but it is a cartridge filter which is the cheapest form of filtration. I hate to break it to you but a good pump/motor/filter is going to cost you around $600-$800.
Jul 05, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
Home Logo
564 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
